Old May 5th, 2012, 02:38 PM   #1
Graugaard
Graugaard's Avatar
Motorcycle(s): Ninja 250r
My new Blinkers have 3 wires
Hi there! I got some new blinkers after my crash since the old one broke.
But they got 3 new wires, (+/- and ground?) They look like this:
Then it would be: RED = (+) | Black = (-) | White/Black = Ground
Am i right so far?
Now the plan was to cut the old wire and then use an Soldering iron to connect new and old +/- so i easy can connect it with the clip-on mechanism, but what do i do with the ground? (if it is ground). Could i just leave it hanging?
thx.
Btw the ninja blinker wire has a green and black/yellow wire. Is green for positive (+) and black/yellow for negative (-)?
Graugaard is offline   Reply With Quote
Old May 5th, 2012, 04:04 PM   #2
chikenstrips
chikenstrips's Avatar
Motorcycle(s): ninja 250r
look in the instructions that came with the blinker
chikenstrips is offline   Reply With Quote
Old May 5th, 2012, 04:14 PM   #3
Graugaard
Graugaard's Avatar
no instructions unfortunately.
FIXED IT. was the black/white which was negative and black is ground.
Old May 6th, 2012, 09:58 AM   #4
trevor_shiggs
trevor_shiggs's Avatar
is one wire for a running light?
2010 Ninja 250 Danmoto Carbon Slip On,Factory Pro Jet Kit,K&N R-0990 Air Filter,10000K HID's,Carbon Fiber Shogun No Cut Frame Sliders & Swingarm Spools,SSR Lowering Links and more....
trevor_shiggs is offline   Reply With Quote
Old May 6th, 2012, 10:03 AM   #5
TeamGreen
TeamGreen's Avatar
Motorcycle(s): 2008 250 Green, 00 R6
Yeah.
TeamGreen is offline   Reply With Quote
Old May 6th, 2012, 08:30 PM   #6
Truckian
Truckian's Avatar
Negative and ground are the same thing, in this, and many cases, anyway. Likely one wire goes to a dimmer filament for a marker light, a brighter filament for a turn signal, and the third wire is ground/negative.
Truckian is offline   Reply With Quote
too many wires on the battery eddiekay 2013 - 2017 Ninja 300 Tech Talk 5 May 12th, 2014 08:07 PM
What are these wires for? djjontran 1986 - 2007 Ninja 250R Tech Talk 8 July 3rd, 2013 12:01 PM
help me map gauge wires into harness wires Kangxi 2008 - 2012 Ninja 250R Tech Talk 9 April 18th, 2012 06:08 PM
Unsheathed wires? arcman 2008 - 2012 Ninja 250R Tech Talk 5 November 24th, 2010 07:58 AM
Unconnected wires jola 1986 - 2007 Ninja 250R Tech Talk 12 July 10th, 2009 07:23 AM
