May 21st, 2012, 07:11 PM | #1 |
Join Date: Apr 2011 Motorcycle(s): 2010 Ninja 250r Track bike, Honda CRF250r Dirt bike Posts: 137
how to fix bent footpeg frame mount?
hi everyone. so today i crashed my bike at the track. it was a minor lowside at about 50mph but all the bike did was slide. after looking at the damage, i saw that where the rearsets mount to the frame is bent. i do not know how to fix this because i am afraid i will snap it off if i try to bend it back... and frames are expensive! so can anybody give me some advice on how to fix this?
May 21st, 2012, 07:17 PM | #2 | |
May 21st, 2012, 07:45 PM | #3 | |
May 21st, 2012, 08:07 PM | #4 |
The casted stay/bracket may if you use it for leverage, but I doubt the frame will. That's why I would take it off and thread something else in there.
May 21st, 2012, 08:20 PM | #5 |
oh im not worried about the rearset because its toast! haha. i just want the frame tab back to normal so the new rearset will mount on straight. i guess i will just bend it back into place then.
May 31st, 2012, 08:59 PM | #6 |
alright so i tried to bend the mount back...it didnt work... both of the bolts snapped off in the frame because it just twisted the bolts around. so i have to find a new way to approach this. and this really sucks because i have to fix this before my race on sunday.
May 31st, 2012, 11:26 PM | #7 |
Join Date: Aug 2010 Motorcycle(s): Ninja 250r 2009 Posts: 396
So the frame is already bent? That's how I see it from your description, rearset mount is bent? Vertical part of the frame with those 2 plastic plugs in it?
A picture would help I suppose. I do not think you can fix that so easily. The real issue is how to fix it without messing up the geometry of the entire frame after you dismantle the bike. If this is what I think it is, no racing on sunday. |
June 1st, 2012, 09:25 AM | #8 |
David,
I have done it on my pre-gen using a 12" adjustable wrench in the way the schematic shows. Very easy, no consequences for the frame.
June 1st, 2012, 06:22 PM | #9 |
You fixed the bent the passenger peg mount this way? I've done this on other fairing mounts (upper fairing stay). I find it easier to put a short bolt in and then tighten the adjustable wrench over the head and tip of the bolt before bending. It may be even easier with rearset adjusters because it will bend both at the same time to maintain alignment.
Last futzed with by CZroe; June 2nd, 2012 at 03:04 PM. |
June 2nd, 2012, 07:31 AM | #10 |
Yes, I have used that method to fix, not only the passenger's peg mount, but the rider's peg mount as well.
That one was bent rearward after my last fall. Then I used the wrench horizontally and twisted the frame. No heat has been necessary; the steel is low carbon and it doesn't crack due to deformation. The bolt system may work, but I believe that it puts too much bending stress on the small diameter of the bolt. If the bolt is a low degree, it may snap.
June 2nd, 2012, 03:09 PM | #11 | |
June 3rd, 2012, 09:23 AM | #12 | |
Had a lowside @ the track that bent my left rearset footpeg a couple of inches forward. Most of it was deformation of the bolt that mounted the peg to the plate, but some of it was the two mounting points for the plate to the frame. I wound up using 6 tie-downs in my truck bed to stablize the bike, and a come-along hand winch. Wrapped some cable around the footpeg on the mount I needed to straighten (for leverage, the peg was slag anyway), ran the it across the frame (between the rear shock & rear tire) to the come-along on other side and tied in the opposite end of the come-along to a tree. Tighten, check. Tighten, check. Repeat. Worked like a champ. Wish I'd taken pics, so I could show but I was so focused on not destroying things that I completely forgot until I was putting everything away. Now to fix the rear footpeg flange a bit more simply
June 3rd, 2012, 10:28 AM | #13 | |
June 3rd, 2012, 06:23 PM | #14 | |
Yeah... I was really bent outta shape that I downed her, and moreso that my frame sliders & rearsets turned it into a tumble & made things much worse. The insurance guy was like "oh, these bikes are cheap, you wanna get a new one, maybe a 600, right?" My initial reaction was "@#$% you man, this is the perfect color and they don't make it anymore. I love THIS bike, not some replacement." What I said was more like "thanks, but I'd rather repair it if possible" Just finally finished repairs this last week, and she's lookin HOT again
June 5th, 2012, 05:57 PM | #15 |
Join Date: Aug 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 771
I had the same issue. What I did was put the stock rearsets on and slowly apply pressure on the heel guard until they started moving. You don't have to be real super delicate, but don't do anything crazy like use a hammer or anything...
July 25th, 2012, 10:12 PM | #16 |
Did the same to my bike, had a good slide at the track, 25mph, pushed the brake rearset mount area in. I"ll take some photos. I had to bend it back at the track by screwing in some bolts and slowly pulling it forward, enough so the rear brake would clear the frame.
Pretty much everyone at the track had the same problem, rearsets that were all tweaked in from crashes. Someone suggested making a small backing plate, use longer bolts for the rearsets to give some more meat to bolt into, distribute the force on a crash. Last futzed with by htdub; July 26th, 2012 at 05:09 PM. |
Bent Engine mount bolt | oompa | General Motorcycling Discussion | 2 | April 15th, 2015 08:27 PM |
Bent frame, what do? | oblivion007 | 2008 - 2012 Ninja 250R Tech Talk | 30 | March 18th, 2014 09:53 PM |
repairing bent rearset mount | cbzdel | 2013 - 2017 Ninja 300 Tech Talk | 14 | April 18th, 2013 03:03 PM |
Best Method to Fix Bent Handlebar | tony7kp | 2008 - 2012 Ninja 250R Tech Talk | 14 | May 15th, 2012 07:49 AM |
Bent Frame....What would you do? | Jono | General Motorcycling Discussion | 36 | March 18th, 2012 12:48 PM |
