Old December 14th, 2008, 05:58 PM   #1
brian997
Master of the ZZR
brian997's Avatar
Motorcycle(s): 2005 Kawasaki 250 ZZR
DIY: Pregen Fender Chop/Flush mount turn signal mod
I am starting this thread as a dyi for anyone with a pregen 250 who wants to do a fender chop. I know, you are probably saying, but the older 250s don't have big fenders. Granted the engineers did make it look stylish, I think it still leaves a little to be desired.
This mod goes hand in hand with turning the rear fish bulb turn signals into flush mounts.
Here is what the back end looks like to start:
First I am going to turn the rear signals into flush mounts.
Then I am going to make a custom fiberglass fender which will serve 3 purposes:
1) Hold the license plate
2) Be large enough storage under the seat to hold the owners manual, registration/insurance, a roll of tape, flashlight, disc lock, and a bottle of water (maybe 2). AND Keep it all dry.
3) Look better.
I am going to update this thread in about three weeks with some more photos, progress, etc. I plan to finish this mod by mid february (I go to school full time, so that is my first priority). If you have any questions, feel free to ask away If you have any comments/ideas, I'm more than willing to hear them.
brian997 is offline   Reply With Quote
Old December 14th, 2008, 06:45 PM   #2
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
You're a bamf I'm totally digging on your ZZR more and more! Be sure to take muchos pictures! I was going to post how I did MY fiberglass FE, but I think it'd stir up too much, "Where did you get that", "How did you do that?","What is the mixture ratio of the resin?","How did you..." Anywho here's my 2 cents on it:
One thing I could suggest is making a foam mold to form the spandex mold over:
You can buy packs of these foam bricks and they're easy to shape in weird ways.
The foam is really easy to work with. I used a hot glue gun to attach a little bit more to the bottom.
Like a dunce I neglected to cover the foam with anything (like aluminum foil). This entailed me having to later scrape the foam from the back of the fiberglass
Stretch some cheapy spandex over the whole thing. I planned a hole in the back for access so everything came together there.
Brush the whole thing bit by bit with resin. It'll look horrid, but later on with much sanding and body filler it'll smooth everything out...
Once you remove the foam from the cured spandex I put piece of aluminum sheeting to reinforce such things as the turn signal holes, license plate mount, and the attaching holes up top.
Then simply cut strips of fiberglass CLOTH and cover the backside of the spandex! Go buck wild in there with the fiberglass. It's light weight so if there is overlapping it's not going to kill on weight or anything. When all's said and done THEN you can tackle the sanding of the outside and adding bondo to level things out.
I should probably get better pictures of it as I've since sanded it a little more and re-sprayed it with paint instead of primer ... In retrospect I would've liked the back to have slopped up more to meet up with the tail, but oh well
VeX is offline   Reply With Quote
Old December 14th, 2008, 06:52 PM   #3
brian997
Master of the ZZR
brian997's Avatar
haha :P I like the wikipedia pages quote about it:
This model came to Canada as the Ninja 250R between 2000 and 2001, after which it received a new name: ZZR-250, in line with the -H model's name elsewhere in the world, where it had existed since 1992. This motorcycle has few parts in common with the -F model, though it shares the same engine (with different casings). It sports a lateral aluminum frame, different fairing (designed to make it look sportier), larger (17") wheels, an adjustable rear shock absorber, adjustable brake and clutch levers, a smaller drive sprocket, computer-controlled timing advance, and a revised electrical system.
And thanks for the pics of your fiberglass DYI. I was planning on using the foam block method with some felt. It should be interesting. The only fiberglass work I've done before was patching a boat :P
This should be pretty rewarding
Old December 14th, 2008, 08:20 PM   #4
VeX
That's me!
VeX's Avatar
Fiberglass is good stuff. You can REALLY half ass it and it mearly makes a little more sanding and all later Making REAL molds for CF is a PITA though as it has to be prefect It looks nice in the end, but takes forrrrrever!
Just make sure you get cloth style fiberglass and not the matte style (that you'd use to patch a boat ). I look forward to your pics!
Old December 14th, 2008, 10:42 PM   #5
brian997
Master of the ZZR
brian997's Avatar
Yeah I'm excited! I'm going to start fiberglassing in mid january, after the flush mount mod is done... should be a good time haha :P
Old December 17th, 2008, 08:50 PM   #6
sprale
Dead-thread Necromancer!
sprale's Avatar
Motorcycle(s): K5 V-Strom
I always thought the ZZR-250 should have succeeded the EX250... the new '08+ really falls short. Though I've never ridden a ZZR either, it has much cleaner styling.
2007 Kawasaki Ninja EX250 ZG250 Quarter-Concours commuter Gone
2005 Suzuki V-Strom DL1000 Big Black Vee future hack?
sprale is offline   Reply With Quote
Old December 17th, 2008, 11:29 PM   #7
brian997
Master of the ZZR
brian997's Avatar
yes I agree... kawi really dropped the ball on the rear fender... it looks a bit like a gixxer I thought (when I first saw it)...
but I like the side fairing of the '08 better than my ZZR... just something about being about to see more of the engine is nice
Old March 21st, 2009, 08:05 PM   #8
brian997
Master of the ZZR
brian997's Avatar
I just thought I'd resurrect this thread :P
I never did this mod. I tried, but NOTHING could get the paint off, and I've visited a few junk yards and haven't found the same pieces yet.
Also, the incredible unavailability of fibreglass made this project die before it started
Old March 29th, 2009, 09:37 AM   #9
jonb08
jonb08's Avatar
Motorcycle(s): 2007 EX250
Ok take a look at this: http://forums.ninja250.org/viewtopic.php?p=59764#59764
With these instructions you should be able to eliminate that ugly thing off the back of your bike and integrate your turn signals into the empty pods on the left and right of your brake light. Read the thread and you'll see that the empty pod covers are painted and this guy was able to get the paint off. Then all you'll have to do is make a license plate bracket.
jonb08 is offline   Reply With Quote
Flush Mount Turn Signal DIY n4mwd 1986 - 2007 Ninja 250R Farkles 37 June 23rd, 2014 05:38 PM
Flush mount turn signal Angel 2008 - 2012 Ninja 250R Farkles 4 June 12th, 2014 08:41 AM
WANTED: Black AsianCycle flush mount turn signals for pregen Ninja iplante Items Wanted 15 November 21st, 2013 05:46 PM
Flush Mount Turn Signal Options - Need Advice bbjminardo 2008 - 2012 Ninja 250R Farkles 14 February 19th, 2013 07:27 PM
$15 ZX-6R LED Flush mounts/integrated tail mod/mini-mirrors & fender chop =) speedgsx98 1986 - 2007 Ninja 250R Farkles 9 March 27th, 2011 10:19 PM
