Old June 28th, 2012, 11:56 PM   #1
cuong-nutz
cuong-nutz's Avatar
Ninja 250 Rotella T6 oil analysis
Just got back lab results today and here it is:
Scenario of my oil change:
I changed the oil after I had gotten home from work so it was still hot. Unfortunately the sample was first catch (as in right as it came out of the drain hole). Not sure how this affects accuracy of results. I think I had some grime on the drain bolt that might have fallen into the sample. It started sprinkling as I was doing the oil change so I noted that in the report. I also noted that I rejetted the bike and it's possible that I could be running in the rich side. Sample was poured into a clean glass jar until the shipping container came in the mail.
I bought the bike brand new, heat cycled and ran the piss out of it for break-in.
There are some variables I need to rule out, so I'm going to shoot the lab an email to get some clarifications as to other possible leads on the high iron and aluminum content. As you may know, MFG recommends use of 10W40 instead of 5W40 which is what T6 is. I'm wondering if the thin cold weight is accelerating wear.
HalfFast Racing Team
Old June 29th, 2012, 05:11 AM   #2
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
How do you order this kit?
Old June 29th, 2012, 05:16 AM   #3
Mountain Dew
Ambrosia.
Mountain Dew's Avatar
Motorcycle(s): 1974 Honda CB550K0 W.I.P.
It's not a kit. You take a sample of your oil to an oil diagnostic station. Kinda like a pee test for your bike.
Life's better on the Mountain.
Mountain Dew is offline   Reply With Quote
Old June 29th, 2012, 06:48 AM   #4
dubojr1
dubojr1's Avatar
Free kits: http://www.blackstone-labs.com/free-test-kits.php
Coung: Thanks for posting this man. T6 for now has become a suspect on whether or not I want to continue using it. Our break-ins are a bit different as a did heat cycle but I was pretty easy on mine for the first 300-400 miles and then progressively increased the spirited riding over the next 250 miles.
The aluminum count is a bit concerning. I'm trying to imagine what you could have dropped into the oil from the drain-plug that would have this number so high.
One other concern is the silicon count. This indicates poorer filtration conditions (compared to the average) of the air entering the engine. What air filter are you using and what are your maintenance intervals for it?
On a positive note the TBN on the T6 is good. This indicates that the oil is still in good usable condition right? Report says you had 4,200 miles on it but I assume since the aluminum count is so high that the lab is suggesting to reduce the interval to 2k pending further analysis.
I'm really at loss of what to do here. I have ~2,700 miles on my current change and intended on changing again at the 5k interval. I'm now wondering if I want to go ahead and have an analysis done and change it to Amsoil or just run it pending my own sample & oil analysis.... Low mileage motors for these bikes can be had for a few hundred dollars too so I'm not sure how much all the worrying and testing is really worth.
I think I'll order a kit and pending your update, I'll then decide what I want to do.
Old June 29th, 2012, 07:13 AM   #5
FrugalNinja250
I googled "oil diagnostic station dallas" and we don't seem to have anything like that around here.
Old June 29th, 2012, 07:34 AM   #6
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Motul engine oil FTMFW!!!
Old June 29th, 2012, 07:46 AM   #7
dubojr1
dubojr1's Avatar
After some further reading on the internet mind you... I can't seem to find any other reports that show T6 to be a lesser quality engine oil. I did read too that the Blackstone "average" is not a good source to compare because it based on oil submitted by bike vs. maybe mileage on oil.
Old June 29th, 2012, 07:47 AM   #8
dubojr1
dubojr1's Avatar
Proof?
Old June 29th, 2012, 07:48 AM   #9
dubojr1
dubojr1's Avatar
You have to have a kit to send back to the lab unless you have a lab in your area.
Old June 29th, 2012, 08:04 AM   #10
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
thats really coool !
Now if only I could buy something worth worrying about . hmmmm
Old June 29th, 2012, 08:18 AM   #11
Boom King
So, where's the reverse?
Boom King's Avatar
Generally the lab results that people post in various forums for T6 are pretty positive. It's difficult to take results from a single sample from one user and draw a wide-sweeping definitive conclusion about a particular oil; especially from a sample with concerns about possible contamination. You can switch back to 10W40 and send that for lab analysis just to make sure that something else isn't going on with your engine.
Old June 29th, 2012, 08:27 AM   #12
dubojr1
dubojr1's Avatar
I fear Coung may in fact have an engine/transmission issue.
Old June 29th, 2012, 08:36 AM   #13
cuong-nutz
cuong-nutz's Avatar
I changed out my stock air filter maybe a month or two ago and have been using Wix oil filters. There's still plenty of additive left in the oil as indicated by the TBN so doing oil changes at 5k shouldn't be a problem. I just got to figure out where all the aluminum is coming from.
Edit: forgot about my viscosity testing.... I called them and they said that it could be excessive pressure which is shearing the oil and thus reducing the viscosity. I don't fully understand it but I'll go with it.
Last futzed with by cuong-nutz; June 29th, 2012 at 10:27 AM.
Old June 29th, 2012, 08:47 AM   #14
dubojr1
dubojr1's Avatar
I'm using a mix of WIX and K&N oil filters with a K&N air filter. What air filter did you change to?
Last futzed with by dubojr1; June 29th, 2012 at 09:48 AM. Reason: spelling
Old June 29th, 2012, 10:25 AM   #15
cuong-nutz
cuong-nutz's Avatar
I changed to an Uni panel filter. I'm not really worried about all the aluminum found at the moment but what worries me more is that my viscosity degraded which brought it down to a 30 grade oil. I'm going to send another sample in at 3k and see what results I get.
Old June 29th, 2012, 10:42 AM   #16
dubojr1
dubojr1's Avatar
I seen the numbers for that but I wasn't clear on how to interpret them. Can you explain?
Old June 29th, 2012, 02:31 PM   #17
cuong-nutz
cuong-nutz's Avatar
I think Bob would explain it better than I would:
http://www.bobistheoilguy.com/effects-of-shearing/
Old June 29th, 2012, 07:37 PM   #18
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
As little oil as this things takes I may change it at 2k anyways
Old June 29th, 2012, 09:01 PM   #19
cuong-nutz
cuong-nutz's Avatar
A very good statement there Since T-6 is still a cheap synthetic and oil solution and I could just shorten the oil change interval and still come out on top on oil compared to other motorcycle specific synthetic oils.
Here's a good read for those who want to learn more about oil lubrication properties pertaining to sports bikes:
http://www.sportrider.com/hands_on/h...oil/index.html
http://www.sportrider.com/tech/146_0310_oil/index.html
Old June 30th, 2012, 09:43 AM   #20
LoneRonin
LoneRonin's Avatar
Motorcycle(s): 09 Ninja 250r
did you notice any difference in engine noise after switching to T6? My bikes been having a ticking cam chain when I first start it up but goes away when the engine is warm. I think it has something to do with the oil, it has a different viscosity when cold but same when its warm compared to 10W40
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound
LoneRonin is offline   Reply With Quote
Old June 30th, 2012, 12:36 PM   #21
cuong-nutz
cuong-nutz's Avatar
I didn't have any noise issues with the bike with the change. If anything, you may want to switch to a thicker weight moto specific oil and see if there's a change.
Old June 30th, 2012, 05:33 PM   #22
LoneRonin
LoneRonin's Avatar
yea..I was running Motul 5100 before, going to switch back to that.
Old June 30th, 2012, 09:08 PM   #23
blackoutt
blackoutt's Avatar
Motorcycle(s): 08 R6, 08 250R
Shortening change intervals isn't a bad idea. It then comes out to whether amsoil is cheaper in the long run at a longer interval. Don't take my word for it, I run Rotella T (not T6) for max of 2k miles.
YEAH BUDDY!
blackoutt is offline   Reply With Quote
Old July 1st, 2012, 08:59 PM   #24
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
I run amsoil. Switched to synthetic at 1k miles. Was planning on using T6 but my local CarQuest had a special on the Amsoil. I only use Wix filters.
Planning on changing at 5k intervals.
LoD575 is offline   Reply With Quote
Old November 5th, 2012, 08:17 PM   #25
rusninja
Ninjette wanabe :D
rusninja's Avatar
Motorcycle(s): white 300 :D
best motor oils?
Well im not quite there but i am excitalily plaining my first oil change at 3k miles and im halfway there? Anyone here ever use motul 300v Is it good and worth it?
VROOOM vrooom >.>
rusninja is offline   Reply With Quote
Old November 5th, 2012, 08:20 PM   #26
dino74
dino74's Avatar
Been a fan of Shell's Rotella T6.
About $22 for a gallon at Walmart.
CVMA #55
Old November 5th, 2012, 08:45 PM   #27
Jono
Jono's Avatar
Shell Rotella T6. Duh!
Old November 5th, 2012, 08:47 PM   #28
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Dis.
I ran Amsoil 10w-40 once and switched to Rotella T6 for both the 250R and ZX6R, can't beat the price when you can get it for ~$20/gallon.
menikmati is offline   Reply With Quote
Old November 5th, 2012, 09:25 PM   #29
/merged with an interesting Rotella thread
Old November 5th, 2012, 10:49 PM   #30
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Ruslan, yes I'm using it and from my point 300V is more then worth its money.
Shifting is much much better and very smooth and if you search in the web they say it even should give you a lil more power.
Old November 5th, 2012, 10:53 PM   #31
Fancy oil gives your bike more power?
Only if you consider how much lighter your wallet is. Rus, use whatever the hell oil you want. I use Rotella T6 because it's easy to buy and it seems to last longer for me mileage-wise. ymmv. But traditional cheapo oil that's only $8 a gallon will do just fine as well.
The important part is remembering when you do oil changes, and doing them regularly.
Old November 5th, 2012, 11:07 PM   #32
menikmati
Sounds more like a placebo effect. Fresh oil from any manufacturer will feel smoother.
My wallet sure felt lighter when an oil change with Amsoil cost 3 times as much as one with T6. The cost effectiveness of T6 also gives me more of a reason to change my oil regularly instead of trying to stretch my miles in between changes.
Old November 5th, 2012, 11:10 PM   #33
How much does an oil change cost with the Amsoil? I pay about $20 for a gallon of T6, which lasts me 2 oil changes, with a touch leftover. Buy a filter, and it comes out to about $15/oil change. Not bad in my books. I change it every 3000-3500 anyways.
Old November 5th, 2012, 11:13 PM   #34
menikmati
It's around $12/quart and I bought it online so I had to pay shipping and it averaged to $15/quart.
EDIT:
Looks like Motul 300V is also a pricey oil, it's up there with Repsol 4T fully synthetic racing oil and Mobil1 4T racing at around $15/quart or ~$50-60/gallon.
Old November 5th, 2012, 11:51 PM   #35
LoneRonin
LoneRonin's Avatar
No need wasting money on 300v. For a 250 the 5100 is more than enough
Old November 6th, 2012, 01:25 AM   #36
Somchai
Freedom for Germany
Yes, at least your right the cheaper oil is good enough, sure for driving on the roads in America you don't need racing oil because you have the speed limited for 100 km/h (66 mph). On the race circuit this may be a good idea.
But for Germany that's very different because there's no speed limit and also the setups in engines, ignitions and fuel-systems from speed-limited countries you can not compare to the setups for Germany, but I think that's what you already know.
So forgive me when I talk with my german experiences in mind
Old November 6th, 2012, 07:35 AM   #37
Synthetic oil will resist break down at extreme heat, and do better at cold starts, but that does not mean that it is necessary to pay a ridiculous amount for some fancy race blend and claim that it makes more horsepower. The high temp and cold starting properties of synthetic are why I use synthetic oil (T6), but I'm not going to pay obscene amounts for Motul when there's a significantly less expensive option that has been proven with many riders to work just fine.
background on synthetic oil:
http://en.wikipedia.org/wiki/Synthetic_oil
edited because it's not worth arguing
Old November 6th, 2012, 07:52 AM   #38
02337
Motorcycle(s): 03 ninja 250
I'm a believer in t6, I see that you tested this on a new bike? With the piston rings embedding and grooving into the walls I wonder if that caused the aluminum count? I doubt the block is aluminum but I'm wondering if the rings are aluminum?
If this was oil done on the bike for the first time I'd be hesitant to draw conclusions from this just due to the fact that so much is happening during the break in period and I know with cars running break in oil after a rebuild or regular dino oil is preferred for setting the rings.
I've done multiple tests with my car, I do a lot of work on vw's/audis and when I switched to rotella t6 in my personal car I noticed an oil psi gain of 5 at idle (10psi to 15) and at 3k it went from 40 psi to 50ish.
The oil also smells different from most oils has a sweet smell(especially if it burn) very thing I've read is great on it in the European car world even trying to find bad reviews aren't too readily available.
And for the price vs motul I save quote a bit as the car takes 5qts.
My $.02
02337 is offline   Reply With Quote
Old November 6th, 2012, 02:28 PM   #39
wow. such a high aluminum content? maybe the 5 weight cold viscosity is making all the oil drain from the head and causing extra wearing on the head?
note, the cylinder walls are iron, the rings are steel and the head is aluminum.
Old November 6th, 2012, 03:39 PM   #40
flynjay
flynjay's Avatar
Considering the oil would drain from the head when the bike is hot so at 40 weight and the fact that the cold viscosity will never be less than the viscosity at hot temperatures, I don't see this as being a high probability.
Rotella t6 temps/ interval? oil change cessus 1986 - 2007 Ninja 250R Tech Talk 12 April 8th, 2013 06:34 PM
Shell Rotella T6 5W-40 Synthetic Motor Oil $11 after $5 MIB (1 gal.) mfresh Motorcycle-related 0 March 3rd, 2013 07:59 PM
Shell Rotella Oil randomwalk101 General Motorcycling Discussion 23 September 19th, 2010 07:34 PM
Rotella T oil = 15$ jonthechron Motorcycle-related 10 September 19th, 2010 07:28 PM
Super Deal!!! For you guys running Rotella T6 Oil dubojr1 Motorcycle-related 19 June 10th, 2010 11:42 AM
