Old July 4th, 2012, 08:52 PM   #1
newninja123
newninja123's Avatar
Motorcycle(s): 2012 black Ninjette
Yoshi slip-on silencer doesnt fit?
what the ****? Not cool yoshi...
after the whole morning spent on the installation... I look at the silencer, and think, oh yeh this'll be easy.. then BAM... gets stuck... i rotate it and wiggle it, but its not going in any further.... Anyone else have this issue?
this is the silencer insert.. Its the correct model, from the information i've gathered....
cheers...
Ride safe, be safe..!
newninja123 is offline   Reply With Quote
Old July 6th, 2012, 08:04 AM   #2
shiroganeshinobi
Motorcycle(s): 2010 250R SE
cheers...
I aligned the silencer hole and used a rubber mallet to bang it in. You should be able to rotate silencer a bit if you can grip the plastic ring sturdily or try and pull it out and try again.
shiroganeshinobi is offline   Reply With Quote
Old July 8th, 2012, 09:22 AM   #3
ride2rideagain
total N00B
ride2rideagain's Avatar
The Yoshi silencers are very snug, you'll have to align the hole where the screw goes in to hold in place and then bang it in with a rubber mallet. If you don't have a rubber mallet, cover the silencer with cloth and use a regular hammer lightly. Have done this for multiple Yosh installs.
ride2rideagain is offline   Reply With Quote
yoshi slip on james250ninja 2008 - 2012 Ninja 250R Tech Talk 2 September 19th, 2011 07:44 AM
Should I shim for a Yoshi slip on? wtfh4xx 2008 - 2012 Ninja 250R Tech Talk 27 June 6th, 2011 06:15 PM
WTB: Yoshi CF Slip-On red Items Wanted 1 April 21st, 2011 07:14 AM
question on Yoshi slip-on kashun84 2008 - 2012 Ninja 250R Tech Talk 0 August 17th, 2010 07:02 PM
Headers for YOSHI Slip on. shporsche Items Wanted 5 June 1st, 2009 07:37 PM
