Old December 24th, 2008, 04:37 AM   #1
g21-30
g21-30's Avatar
Keihin Needle Spreadsheet
Some of you may be interested in modifying the attached for use with the aftermarket jet kits. Enjoy!
Old December 24th, 2008, 11:22 AM   #2
Good find. Does this apply to our bikes?
Old December 24th, 2008, 12:13 PM   #3
g21-30
g21-30's Avatar
As best I can determine, our carbs fall under the "FCR" column classification in the following chart:
http://www.keihin-us.com/list.htm
It looks like Kawasaki and Yamaha are the only manufacturers using the CVK designation; however, the "K" in CVK normally refers to Kawasaki. The needle sheet for FCR references much larger jets. I'm hoping one of our members (more dedicated than I am) might be able to expand the needle sheet. Meanwhile, I will continue the hunt.
Before I forget, kkim, Merry Christmas to you and yours, along with all our fellow ninjettes on this forum. Last, but not least. we must'n forget that BLACK definitely is FASTER than green!
Old December 24th, 2008, 12:23 PM   #4
g21-30
g21-30's Avatar
More Info from Keihin
This pdf confirms our carbs are the FCR type and lists the jets.
http://www.keihin-us.com/am/_media/pdf/jetlist.pdf
This link covers factory tuning of the carbs:
http://www.keihin-us.com/am/tuning/
Old December 24th, 2008, 12:24 PM   #5
merry xmas to you, Sam. Maybe the new year will bring clarity to your senses on which bikes are truly faster. Until then, keep sipping the eggnog to drown your sorrows of having the wrong color bike!
Old December 24th, 2008, 12:34 PM   #6
HKr1
IC2(SW)
HKr1's Avatar
FCR's are Flat slide CR's.
Hardware Size Spreadsheet? TBC 1986 - 2007 Ninja 250R Tech Talk 3 August 16th, 2014 05:54 PM
keihin main jet Q?? cuz 2008 - 2012 Ninja 250R Tech Talk 3 September 10th, 2011 08:27 PM
Keihin Needle Jet size ztrack157 2008 - 2012 Ninja 250R Tech Talk 7 July 29th, 2009 11:01 AM
keihin racing catbs bikeboyben14 2008 - 2012 Ninja 250R Tech Talk 7 July 26th, 2009 11:00 PM
