Old August 16th, 2012, 08:13 PM   #1
Bob2010
Bob2010's Avatar
So I found this hose...
I searched and googled. This is the best picture I could find since I tried to re connect it already
So doing the undertail install on my bike a week ago (full exhaust and jet kit) this hose was just laying in engine bay
Now I saw a big, possibly plastic , nipple facing up towards top of bike. It appears to be ontop of the motor. So I put the angled part of the hose back on it.
Don't really know where the other end goes. Who knows how long it's been like this
What does it do? Anything bad result from having this open to atmosphere?
Guess I could tear apart the other bike, since it is 100% stock....
Thanks in advance
2010 Red Ninja 250
2009 Black Ninja 250
Last futzed with by Bob2010; August 17th, 2012 at 03:55 AM. Reason: Whoops iPhone auto correct errors
Old August 16th, 2012, 10:12 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Check on top of your carb toward the front right in the middle, do you have a plastic tube facing strait up that wobbles forward and back slightly. If so that hose goes onto that tube bent side forward and the rear just vent back under the seat. As to what it does, well I'd like to know the same thing.
Old August 17th, 2012, 03:56 AM   #3
Bob2010
Bob2010's Avatar
Ok. Ill see what I can do after work. I'll grab an actual pic of it , see if that helps
2010 Red Ninja 250
Old August 18th, 2012, 01:41 PM   #4
mkulchar
mkulchar's Avatar
Motorcycle(s): 2010 250r ninja
that looks like the overflow hose that comes from the top of the carb and it just hangs down towards the ground. Extra fuel that is in the carbs is pushed tho that hose goes out on the ground.
mkulchar is offline   Reply With Quote
Old August 18th, 2012, 03:50 PM   #5
flynjay
flynjay's Avatar
Does it have a plug in one end? If so, I'd say it's the airbox drain line (for excess crank case oil).
Old August 18th, 2012, 04:11 PM   #6
the picture you provided doesnt give enough detail to tell what hose it is. you need to know where it comes from to be able to tell where it goes. but just a guess it looks like the kleen air hose
Old August 18th, 2012, 04:41 PM   #7
Bob2010
Bob2010's Avatar
I know. It's a vauge picture as i already tried to re install it. You are right. It's facing up by the carbs. I have the other end facing down with the overflow lines from the radiator. Thanks!
2010 Red Ninja 250
Where does this hose go? eric78 1986 - 2007 Ninja 250R Tech Talk 3 May 11th, 2014 06:40 PM
what is this hose? 91satanslegend 1986 - 2007 Ninja 250R Tech Talk 13 November 4th, 2011 11:28 AM
Name this hose WAGESLAVEesc 1986 - 2007 Ninja 250R Tech Talk 10 August 18th, 2011 09:47 PM
What is this hose? caps 2008 - 2012 Ninja 250R Tech Talk 5 June 30th, 2011 04:58 PM
Question About a Hose Mc2 2008 - 2012 Ninja 250R Tech Talk 11 August 22nd, 2010 07:33 PM
