January 1st, 2009, 04:24 PM | #1 |
Clip Ons... Who's Got em???
I know there are some of you that have clip ons on your bikes. Care to share what you used and how they are mounted?? What works... what doesn't... how the bike feels after the change... etc, etc, etc. Details, man, details!
Any input provided would be appreciated. The information I've seen regarding this mod has been scattered and sometimes not too reliable. |
January 1st, 2009, 04:41 PM | #2 |
Join Date: Dec 2008 Motorcycle(s): 2008 Ninja 250R, CR125R Posts: 191
Good topic, I have been looking at these...
January 1st, 2009, 04:42 PM | #3 |
FORMER MOTORCYCLE RIDER
Join Date: Dec 2008 Motorcycle(s): Rode an 08 250r then rode an 08 ZX-6R until i totaled it on 7/10/10 Posts: 758
Cajun covered it very well on the 'Other Forum'
Post #16 Ladies and Gents i give you clpons http://www.kawiforums.com/showthread.php?t=121551 Parts 2007 Suzuki SV650s handlebars Rod Bearings for shimming to fit forks Barends purchased at CheapCycle.com My thoughts I haven't got them dialed in all the way yet.It got cold. If you lean foward on a stock bike and grab the brake and clutch levers, that is about how much more you will lean foward. You will have more weight on your hands and my turn in feels much lighter. Almost twichy. Might have been because tires cold or low inflation. I haven't checked it lately. I have only put about 75 miles on after changing them. You will pinch your fingers on full lock turns I'll update in the spring. Last futzed with by CRXTrek; January 5th, 2009 at 11:27 PM. Reason: Add link if it's Ok |
January 1st, 2009, 09:40 PM | #4 |
Track Junkie
Join Date: Dec 2008 Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike Posts: 602
i've got the vortex clipons on my bike. we had to drop the forks maybe an extra 1/2 inch to have enough fork leg sticking out above the triple tree for them to mount to. i've ridden it up and down the street and it feels pretty good. you can mount them under your triples as well, but i don't think you'd be able to clear body work without a lot of modification. even mounted on top might require a little trimming (at least it did on my hotbodies fairing).
i didn't ride the bike stock much, and i haven't been out on it much with the new parts either, so i can't give a lot of good feedback. i can say that the body positioning with the clipons and the woodcraft rearsets feel pretty good so far though. (if this image is too big, let me know and i'll edit)
Las Escobas -- Track Bikes Save Lives JonBroom.com |
January 3rd, 2009, 08:24 PM | #5 |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 2505 Posts: 98
what is the need for the clipp on's....noob question
January 3rd, 2009, 10:26 PM | #6 |
For me it was the look,more like a sportbike,and getting
my head down behind screen more out of the wind. Also if you crash and bend them them you can replace just the bar for about $15. Except for the bars i have. Which are one piece Suzuki SV650s stock bars. Hand position view with both bars on at once |
January 3rd, 2009, 10:49 PM | #7 |
Track Junkie
the main reason is body position. it puts you in a more aggressive stance for the track. they're also much better to crash. if you don't clamp it down too hard, it'll just move stuff when you crash instead of breaking or bending. CRX is right too, much easier and cheaper to replace a bent tube.
usually i'd say they're only needed for the track, but i think the stock bars on the 250 and 650 are kinda nerdy, so if it was me i'd put them on my street bike too if i had one.
January 4th, 2009, 01:20 PM | #8 |
someone had mentioned that you might have to cut to for adjustment on the plastics, is that really needed and thanks for the info
January 4th, 2009, 04:31 PM | #9 |
That's me!
Join Date: Nov 2008 Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR Posts: 454
Sometimes this laptop pisses me off when I go on a long tangent and then magically it 'clicks' on something and goes off to another URL So AGAIN:
You shouldn't have to do any notching on the plastic cowling if you retain the factory master cylinder. Since the style master cylinder I'm using connects on the bottom it makes some contact with the clip-ons. Anywho: It's pretty! As for my clearance issues: With this style clip-on (as opposed to the SV650 clip-ons) the bars are moved roughly 1" forward. This in turn makes the levers come close to the wind-screen on the extreme turns. This isn't so much of a problem unless you're trying to do something like the 'box' on an MSF course That and in my case: With the banjo fitting mount on the bottom of the master cylinder I had to notch the black plastic cowling to clearance it. Sometime in the near future I'll contour some fiberglass around the hole and make it look like it's factory made Since there's no way this style clip-on would mount underneath the top-triple tree mount I had to put it above. The damned thing is tall! Albeit the fork tube is still maybe 1/4" down the clip-on, the clip-on overs 1-1/8" of the fork tube! It's really really sturdy on there. Overall I raised the fork tubes 1/2" + 10mm because it seemed like a good idea. Initially I took it out and warmed up the tires a bit. The whole setting position is a lot more sport oriented! It felt a lot more natural going around turns and probably since I dropped the front the 5/8" it does turn faster. I went on the free-way and everything felt stable at 80mph (un-corrected it was like 86-87mph). I'm very pleased with the results! I'll wait a week or so before I start doing any twisty-action to get used to the set-up, but I anticipate it. In the meantime I'm waiting for my f'ing pads to come in, new grips and rubber expansion nuts so I can retain bar-ends. |
January 4th, 2009, 04:44 PM | #10 | |
What overall height difference from stock did you find worked best? I heard on another forum that 1.5" difference (lower front/raised rear) works best. |
January 4th, 2009, 05:38 PM | #11 |
"VEX" are the clip-ons you have installed the vortex? they appear to be diffrent from the SV650's you had postd on the other link kf
there was another thread that had a race bike with the clip-ons installed under the tree and i think he said WoodCraft was in the works for getting some made for our bike, correct me if i am wrong. |
January 4th, 2009, 05:59 PM | #12 |
That's me!
These are the only pictures of my clip-ons I've posted. Mine are not the Vortex ones (That's Broom). By the looks of it the Vortex ones are a bit shorter in height then mine and would explain why mine don't fully grasp the fork tube.
There's a couple of people with the SV650 clip-ons and those can go underneath the top-triple tree clamp as they have an 'L' shaped design so the actual bars wind up level with the Vortex ones. Woodcrafts would be nice, but I'm sure they wouldn't be cheap I think Richard was the one that said he was going to try out Woodcraft rearsets, but not the clip-ons. I could be wrong |
January 4th, 2009, 06:38 PM | #13 |
Vex,
thanks for posting the pics. you can lower the forks about 1" w/o problems and it will quicken the steering a bit w/o making the bike unstable on the highway. That's the amount mine was lowered with the front lowering kit I installed. |
January 4th, 2009, 07:14 PM | #14 |
Track Junkie
i forgot to mention that another advantage to clipons is the ability to shift weight from front to rear or vise-versa. the lower you put your clipons the more weight you shift to the front.
January 4th, 2009, 07:20 PM | #15 |
so, that would apply to rearsets as well?
January 4th, 2009, 07:21 PM | #16 |
Track Junkie
yup
January 4th, 2009, 07:27 PM | #17 |
January 4th, 2009, 07:53 PM | #18 |
That's me!
^^^ Hahhah that's a great smiley. I didn't mind decreasing the trail (it quickens up steering to put it in easy phrasing), but I didn't want to sacrifice stability. That's why going down about 5/8" seemed kosher. Going down the full inch would fully expose the fork tubes for the clip-ons, but like I said they are TALL clip-ons. They are on there and aren't going anywhere and possibly affecting stability to make the clip-ons fully mount doesn't seem necessary.
January 4th, 2009, 08:08 PM | #19 |
And I'm saying that when I lowered mine an inch, it didn't affect highway stability like I thought it would, too.
I'm not saying to lower yours, just don't not lower it because of anticipated straight line instability... it doesn't happen. |
January 4th, 2009, 08:47 PM | #20 |
i've seen so many pics i might have gotten them mixed up but i know for sure that "vex" has a miller welder in his left rear view
January 4th, 2009, 08:50 PM | #21 |
welder is used to keep his bike together as it's been apart waaay too many times!!!
January 4th, 2009, 09:06 PM | #22 |
That's me!
Phew! I'm glad the welder was in the rear view mirror...
Last futzed with by Alex; January 4th, 2009 at 09:12 PM. Reason: pic attached |
January 4th, 2009, 09:25 PM | #23 |
January 5th, 2009, 12:53 PM | #24 |
Join Date: Nov 2008 Motorcycle(s): '09 Ninja 250R Posts: 518
LOL!
How much money do those Vortex clip-ons go for? |
January 5th, 2009, 12:56 PM | #25 |
Track Junkie
looks like around $150
January 5th, 2009, 02:33 PM | #26 |
So the only clipons that work are SV650 ones?
EDIT: Looks like the sv650's I've found are 41mm, how'd you guys get yours to fit? Been searching ebay for 36mm models, came up with... http://cgi.ebay.com/ebaymotors/Motor...2em118Q2el1247 What do you think? Last futzed with by Erin_S; January 5th, 2009 at 03:35 PM. |
January 6th, 2009, 12:23 AM | #27 |
January 6th, 2009, 12:26 AM | #28 |
I believe he got his clipons on Ebay... the same place he sold his hot water kettle.
January 6th, 2009, 12:34 AM | #29 |
January 6th, 2009, 02:34 AM | #30 |
That's me!
I'm busted eh?
http://cgi.ebay.com/CLIP-ON-HANDLEBARS-FORK-36MM-EX250-NINJA-CLIP-ONS_W0QQitemZ250297368968QQihZ015QQcategoryZ35587QQtcZphotoQQcmdZViewItem ^^ That's where I got mine, although I'm thinking 37mm might work a little better as the tubes are really about 36.55mm in diameter. |
January 6th, 2009, 02:37 AM | #31 |
I've never heard someone refer to anything as about 36.55mm. Sure it wasn't about 36.54 mm, or maybe about 36.56 mm?
Time for me to get to sleep for about 7 hours, 12 minutes, and 36 seconds.
January 6th, 2009, 02:40 AM | #32 |
That's me!
Oh whoops! Sorry I meant 36.5mm. I got excited about hitting 'm' twice I must've hit the 5 twice as well
January 6th, 2009, 05:22 AM | #33 |
Vex....Did ya get some more riding in with the new setup ?
I can't wait for warmer temps. I'd ride layered up, but still the tires won't grip for sh*t and there is snowmelt compound on all our roads |
January 6th, 2009, 05:33 AM | #34 |
That's me!
Nothing above and beyond the local back-roads. I think I might do some exploring later today?
January 6th, 2009, 09:42 AM | #35 |
Track Junkie
at least you guys have the chance to ride....
the offseason sucks when your bike is a track bike
January 25th, 2009, 01:30 PM | #36 |
Wood craft's are now available
http://www.woodcraft-cfm.com/Scripts...dproduct=18129 |
January 25th, 2009, 02:01 PM | #37 |
Me want
January 25th, 2009, 05:11 PM | #38 |
忍者
Join Date: Dec 2008 Motorcycle(s): None Now - Used to have an '08 Ninja 250R Candy Blue Posts: 151
when someone buys the Woodcraft clip-ons and installs them, please post some pics so we can all drool over it!
January 25th, 2009, 05:18 PM | #39 |
Track Junkie
mine are on their way, but i won't have the bike back from the tuners yet
might be a couple weeks before i can post up picts.
January 25th, 2009, 05:21 PM | #40 |
Woodcraft clip-ons V.S. Kitaco clip-ons | tjb0012 | 2008 - 2012 Ninja 250R Tech Talk | 41 | June 20th, 2011 05:35 PM |
