Old September 12th, 2012, 03:41 PM   #1
Swynefloo
Motorcycle(s): ninja 250r
Really need help, bike running poorly
Hi everyone, I'm pretty new to bikes and mechanics as a whole, but I know the basics. I've got a '98 and it was sitting for a long while before I bought it. I pull the carbs apart a few times to clean everything out extremely well, put it back together alright as well. The person put on a muzzy exhaust system (very loud, I dislike it) and K&N air filters. When I first got it, it ran extremely poorly, but after cleaning out the carbs and running some seafoam through it, it will actually run. I've played with the jets to try and get the right mixture but I'm still not sure if it's okay.
The bike starts fine, idles fine, and will rev fine while in neutral.
The main problem I'm having is that while I take the bike out, it can start off fine, but whatever gear I'm in, if I give it too much throttle (3-3.5k rpms) it just won't do anything and it'll sound like it's bogging and wants to die. If I hold it in that position after maybe 5 seconds it'll actually take and then shoot up in rpms
What could possbily be causing this? The bike as it stands now is pretty much un-ridable as I can't even get past 30mph.
Thanks for reading, any advice is helpful! Also please keep in mind my finances aren't too in the green, as school has just started for me, so I'll need the cheaper alternative to any fixes you might suggest!
Swynefloo is offline   Reply With Quote
Old September 12th, 2012, 03:45 PM   #2
dirty nasty
Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F
IDK, but I'll gladly trade you my stock airbox and exhaust setup for yours. That's one way to get rid of your problems and you'll have the satisfaction of knowing all your problems are placed on me as I struggle to figure them out. I'm serious.
If you don't accept my offer, first thing I would check is if the carbs are sync'd, mixture screws and idle speed set properly, then the needles. What throttle range does this happen in? Idle, 1/8, 1/4, 1/2, 3/4 or WOT? What ranges does this not happen in?
dirty nasty is offline   Reply With Quote
Old September 12th, 2012, 04:02 PM   #3
Swynefloo
I'll have to think about that offer haha, but the air box as I understand is a serious pain in the butt.
It idles fine, if I rev it in neutral (or with clutch held in) it'll rev normally. However, as soon as I'm actually in gear and riding, right around 3-3.5k~ rpms it'll just bog and not take. The carbs are synced, I made sure of that when I had them taken apart. The throttle acts normally (for the most part) from idle speed to about 3-3.5k rpms. Keep in mind I can't get past this range of rpms no matter what gear or how hard I pull the throttle, UNLESS I keep the throttle there for about 5-7 seconds and then it'll very slowly pick up the speed
thanks for responding!
Old September 12th, 2012, 04:05 PM   #4
lgk
what jets were in the carbs?
check your plugs, i think your running lean.
Old September 12th, 2012, 04:11 PM   #5
Swynefloo
Hey what do you mean by what jets? Stock? And what would cause it to run lean? The jet screw adjustment?
Old September 12th, 2012, 04:15 PM   #6
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
You need a bigger set of jets like 104-108 dynojets
AFM #676
Supersports are for n00bs
Old September 12th, 2012, 04:34 PM   #7
Swynefloo
Is that a fact or an opinion?
Old September 12th, 2012, 04:39 PM   #8
dont listen to jiggles. you are describing a rich condition. but being a 98, its very possible its caused by valves clearance needing adjustment. the muzzy and the intake should be making it a bit leaner so my vote is on valves. if that doesn't help try dropping the needle one slot.
Old September 12th, 2012, 04:40 PM   #9
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I thought he said stock jets
AFM #676
Old September 12th, 2012, 04:43 PM   #10
Swynefloo
I do have the stock jets in still, I'm very new to this still and I hadn't put on the pipes or the air filters.
How do I drop the needles one slot exactly?
Old September 12th, 2012, 04:45 PM   #11
Jiggles
Jiggles's Avatar
MOTM - Apr '13
You're positive the jets are stock and the PO didn't switch them out?
AFM #676
Old September 12th, 2012, 04:46 PM   #12
98 refers to the year. current jet size makes no difference. carbs change over time, needle orifices become oblong from normal needle wear letting in more gas. higher flow intake and exhaust should be leaning it a bit. all signs point to valves or float height, captain.
Old September 12th, 2012, 04:47 PM   #13
he said he disassembled the carbs multiple times.
Old September 12th, 2012, 04:50 PM   #14
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Hokay mang. Full exhaust + k&n Intake + stock jets =
Guess anything is possible with a little carb magic
AFM #676
Old September 12th, 2012, 04:51 PM   #15
Swynefloo
Yeah I'm 98% sure they're stock, the PO wasn't that clever of a dude and said he did no carb work.
Old September 12th, 2012, 04:53 PM   #16
muzzy slip on is not full exhaust. and k&n intake is not pod filters
Old September 12th, 2012, 04:55 PM   #17
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Damn
AFM #676
Old September 12th, 2012, 04:57 PM   #18
lgk
i assumed it was pods because the offer was made to switch pods for a stock box.
Old September 12th, 2012, 04:58 PM   #19
good point. as little-T-bone tells me, i need to take reading comprehension classes.
Old September 12th, 2012, 04:59 PM   #20
Swynefloo
they are pods sorry for confusion
Old September 12th, 2012, 05:18 PM   #21
its probably the pods fault. i would get jets and spend some time tuning. there are plenty of guides to how to tune on the board... i think i even wrote a long one that is stickied in the DIY thread
but you probably still need to do the valves.
Old September 12th, 2012, 05:46 PM   #22
Swynefloo
damn, the valves was the thing I was trying to avoid doing T.T I don't trust myself with that kind of job, and don't have the money to have someone else do it for me. Rejetting it sounds like the right course of action at the moment, but what stage do I get?
Old September 12th, 2012, 05:54 PM   #23
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Check out the jetting data base in the DIY directory and choose a setup that is close to yours
AFM #676
Old September 12th, 2012, 05:56 PM   #24
Swynefloo
Oh thank you, didn't know you had one ^^
Old September 12th, 2012, 05:56 PM   #25
Jiggles
Jiggles's Avatar
MOTM - Apr '13
http://www.ninjette.org/forums/showthread.php?t=5586
AFM #676
Old September 12th, 2012, 06:29 PM   #26
Swynefloo
what would cause the valves to be maladjusted? The bike only has 7k miles on it (I did say it sat for a long time)
Old September 12th, 2012, 06:32 PM   #27
Jiggles
Jiggles's Avatar
MOTM - Apr '13
a pregen needs a valve adjust at 600 miles and 6000 miles. Standard procedure
AFM #676
Old September 12th, 2012, 06:44 PM   #28
Swynefloo
Well damn, that's a tall order, what do I do if I screw up? I probably won't have money for a mechanic or other to clean up for me, sigh
Old September 12th, 2012, 06:48 PM   #29
lgk
just take your time and do it indoors.
follow all the steps and you'll be ok.
Old September 12th, 2012, 06:50 PM   #30
Swynefloo
Well thanks for believing in me
Does the valve adjustment have anything to do with the problem I'm having? Or do I just need to do it anyway because it needs to be done?
Old September 12th, 2012, 07:07 PM   #31
lgk
if the previous owner did not do it, then you definitely need to.
when the clearances are too tight, the top end will burn up.
Old September 12th, 2012, 07:18 PM   #32
Swynefloo
What does that mean exactly?
Old September 13th, 2012, 10:13 AM   #33
http://faq.ninja250.org/wiki/Why_do_...be_adjusted%3F
Jet the bike. Check/adjust your valves (not that hard, just time consuming). Sync carbs. Check tuning again.
Old September 13th, 2012, 10:26 AM   #34
lgk
without proper clearances, the head and valves are damaged in several different ways.
-additional friction between cams and buckets
-valves dont have a good seat and over heat.
-cams seize due to lack of lubrication
-valve seals are damaged due to lateral tresses.
-etc.
these problems can cause a lot of other running issues.
Old September 13th, 2012, 01:30 PM   #35
It also starts up and runs smoother in the mid/low range with properly adjusted valves. It's worth it to learn how to do the maintenance yourself.
Old September 13th, 2012, 01:59 PM   #36
lgk
if your broke its well worth it DIY.
use the saved money to go on some extra rides
Old September 13th, 2012, 06:22 PM   #37
Swynefloo
Thanks for the help everybody, guess I'll have to get prepared to adjust the valves. Got some reading ahead of me.
Old September 13th, 2012, 10:27 PM   #38
dirty nasty
I don't think your valves are out of whack at 7k miles. I've just turned over 8k and my bike is still running fine. Gonna check all that **** out over the winter.
Also if you're still considering this trade I'd like to add that my airbox is easy! I cut the battery box off, so getting the carbs off is as simple as removing the battery, 2 bolts, pulling the tray and peeling the airbox off from the carbs. Do you have the full Muzzy system with the header?
Old September 13th, 2012, 10:30 PM   #39
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Have to agree with buttcheese on this one, its literally impossible for 2 different bikes to have different valve clearances.
AFM #676
Old September 15th, 2012, 11:53 PM   #40
Lychee
sail away
Lychee's Avatar
why is countersteer explained so poorly? jschorr Riding Skills 114 July 3rd, 2015 10:58 AM
[kropotkin thinks...] - 2015 MotoGP Sepang 1 Test Gallery - Poorly Framed And Out Of Ninjette Newsbot Motorcycling News 0 February 3rd, 2015 11:21 PM
Engine running poorly + tach not working Ausoi 2008 - 2012 Ninja 250R Tech Talk 13 March 9th, 2013 12:09 AM
Please Help - Bike not running well CampinCracker 1986 - 2007 Ninja 250R Tech Talk 14 November 15th, 2011 12:51 PM
[hell for leather] - Dainese Tattoo suit: good idea, poorly executed Ninjette Newsbot Motorcycling News 0 November 10th, 2008 08:49 PM
