Old November 1st, 2012, 08:00 PM   #1
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
Fairing Alignment
I did the first oil change on my 300 tonight and discovered, like others, the oil filter was installed by King Kong. I had to take off the bottom right fairing to get at the filter with pliers. When I reinstalled it, it isn't aligned at the front anymore. I've tried taking it off and reinstalling it, but it's still gapped a bit. Any ideas? It wasn't that way when it came off.
geeker is offline   Reply With Quote
Old November 2nd, 2012, 05:20 AM   #2
Peanut_EOD
Peanut_EOD's Avatar
Motorcycle(s): Green 2013 ZX-6R
Make sure all of the tabs on the two bottom halves are lined up correctly and loosen all of the screws on the right side. Push up on the lower piece as you tighten the screws starting with the front then work back.
http://www.simplysurrealphotography....es/peanut2.png
Peanut_EOD is offline   Reply With Quote
Old November 2nd, 2012, 06:40 AM   #3
geeker
geeker's Avatar
Tried that already. Just removed it again and tried to tighten from the front. The gap is still there.
Old November 2nd, 2012, 08:26 AM   #4
Peanut_EOD
Peanut_EOD's Avatar
Ride it to Colorado and I'll take a look at it for you.
Old November 2nd, 2012, 11:52 AM   #5
kMvNeverLandMan
Motorcycle(s): 2013 Ninja 300
There is another location on the bottom going towards the back wheel that has to align as well. Make sure both locations line up and you should be able to put them back together without there being a gap.
kMvNeverLandMan is offline   Reply With Quote
Old November 2nd, 2012, 05:06 PM   #6
geeker
geeker's Avatar
It's on the bucket list.
I tried again this morning. Everything seems to be aligned and in place. Maybe I need to take all the fairings off and start from scratch?
Old November 7th, 2012, 03:39 PM   #7
My lowers on the J-bike didn't align and stayed that way for months until I popped out the three plastic rivets and held them in place while setting the rivets. Popping one at a time did nothing. It looks like this gap is between the lower and mid fairings but perhaps you could try something similar?
Old November 19th, 2012, 02:05 PM   #8
geeker
geeker's Avatar
I just took a look at two new 300s on the showroom floor and they both have the same gap on the bottom fairing. I still haven't had a chance to remove all the fairings and try again.
Alignment off? APEmike 2013 - 2017 Ninja 300 Tech Talk 1 October 14th, 2014 07:32 PM
Fairing alignment issue - HELP PLEASE (video) Komm_Klink 2008 - 2012 Ninja 250R Tech Talk 5 May 15th, 2014 10:31 AM
Fairing,Headlight,Gauge Cluster alignment lotusseven 1986 - 2007 Ninja 250R Tech Talk 1 November 27th, 2010 10:50 PM
Headlight alignment kobachi 2008 - 2012 Ninja 250R Tech Talk 2 July 29th, 2010 11:19 AM
Need help with front fairing / headlight bracket alignment. abyssdncr 1986 - 2007 Ninja 250R Tech Talk 5 May 24th, 2010 03:47 PM
