Old January 6th, 2013, 12:13 PM   #1
bandit_fosky
Motorcycle(s): ninja 250 r
power commander?
what does a what does a power commander do?
bandit_fosky is offline   Reply With Quote
Old January 6th, 2013, 12:16 PM   #2
Joshorilla
Bass Master General
Joshorilla's Avatar
It commands power.
Old January 6th, 2013, 12:17 PM   #3
bandit_fosky
Originally Posted by joshorilla View Post
it commands the power.
power!!!!!
Old January 6th, 2013, 12:19 PM   #4
allanoue
allanoue's Avatar
MOTM - Sep '14
Let me Google that for you
Old January 6th, 2013, 12:29 PM   #5
Joshorilla
Bass Master General
Joshorilla's Avatar
It replaces your ECU for the sake of adjusting the fuel to air ratio curve across the power band to allow the optimum mix for best performance.
It does this by being uploaded with a "map" which can be a stock fuel to air ratio curve or a custom one created by putting your bike on a dyno to determine a custom ratio based on your specific bike for best performance.
So, in a nut shell, it tells your fuel injector system to deliver more fuel, as typically your bike will run a little lean and will only get leaner "meaning it'll need more fuel for tye best mix ratio" with the more performance parts you add, like exhausts and air filters and snorkel.
Leo Vince also make an ECU for the Ninja 250 that does the same thing.
Old January 6th, 2013, 01:34 PM   #6
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Interesting. Got a link? Can't find it.
Old January 6th, 2013, 01:37 PM   #7
Joshorilla
Bass Master General
Joshorilla's Avatar
http://www.leovince.com/en/catalog-k...008_2009/12087
It's for the Leo Vince exhaust, but since all performance exhausts do the same thing "better flow" and it's reprogramable I believe it will do the same as a the powercommander.
Old January 6th, 2013, 03:14 PM   #8
akima
Nooblet
akima's Avatar
MOTM - Oct '13
It could actually just be an OEM powercommander wrapped into some leovince branded plastic!
Old January 6th, 2013, 03:21 PM   #9
Joshorilla
Bass Master General
Joshorilla's Avatar
Could well be, what makes you say that?
I know dynojet are doing hardware for some american companies, but I didn't know LeoVince was one.
Old January 7th, 2013, 11:17 AM   #10
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Just a thought.
Old January 7th, 2013, 11:19 AM   #11
Joshorilla
Bass Master General
Joshorilla's Avatar
Just a thought.
Looks like you could be right, I did some research and it looks like it is.
Old January 7th, 2013, 12:00 PM   #12
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Cool! I thought to myself what I would do if I ran LeoVince and needed an ECU to go with my performance components... develop one from scratch (long development time, high risk, expensive) or look for an existing system (low risk, cheap in the short term, practically no development time).
Old January 8th, 2013, 10:59 AM   #13
akima
Nooblet
akima's Avatar
MOTM - Oct '13
@bandit_fosky: just incase you don't know: only the fuel injected ninjettes can make use of the powercommander. The ninja 250 (2012 and earlier) found in the states isn't fuel injected and thus has no ECU, so a powercommander is useless.
Old January 16th, 2013, 01:55 PM   #14
bruce71198
bruce71198's Avatar
You can get a different CDI box that will alter the ignition advance curve. I think there are some programable ones on the market. If you had a dyno available you could probably make use of an adjustable CDI unit.
Old January 16th, 2013, 02:05 PM   #15
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
All exhausts are not created equal
AFM #676
Supersports are for n00bs
Power commander 5 joecool 2013 - 2017 Ninja 300 Tech Talk 27 October 17th, 2014 05:03 AM
Dynojet Power commander 5 FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 3 September 23rd, 2012 03:23 PM
Power Commander for FI version? raybolic 2008 - 2012 Ninja 250R Tech Talk 3 February 26th, 2012 06:34 AM
DIY Power Commander Install Sonofswin 2008 - 2012 Ninja 250R Tech Talk 3 December 13th, 2011 11:04 AM
Power Commander for new bike? dive1tom General Motorcycling Discussion 5 December 8th, 2009 08:53 PM
