Old February 11th, 2013, 12:10 AM   #1
skilletmo
InfoWhore
skilletmo's Avatar
Motorcycle(s): 2008 Ninja 250 StreetFighter ~~~~ 2005 KTM 450 EXC
Speedometer not working...
Ok so my speedometer (mph) is not working but my tack and fuel are. I was riding back to my house one day when i noticed my tach and speedometer were not working so i stopped by a gas station and checked the gauge wire. I then noticed a metal wire wrapped around my speed sensor thing and rim. I was shocked and removed it immediately. I turned it on and vualla, my tach started working. I started to move and i noticed the speed still doesn't work. I checked if they were tightly screwed and they were, so i decided to go home and work on it tomorrow since its dark and im tired as f*ck.
Anyone know what is going on before i inspect it tomorrow? I know its a common problem but i would like to make it more clear for myself on what i should be trying to do or find.
I posted how the wire looks below, if it matters. Also the tach wires are exposed because i made it into a streetfighter. Just fyi's
Everyone, go buy a dirtbike hurry
skilletmo is offline   Reply With Quote
Old February 11th, 2013, 12:44 AM   #2
The original mechanism is a mechanical cable. IIRC, it's a sleeved stranded metal cable like the clutch and throttle cables. One end has a beveled pin that fits into the gear on your front wheel and the other end has bigger end that fits into the back of your gauges. It's very hard to get it to thread correctly with the gauges when screwing it on unless you hcae all the fairings and such off the bike, but you did say that it's a street fighter.
Anyway, I know you were working on installing an aftermarket gauge with a magnetic speed pick up instead of the mechanical way the stock gauges do it. Did you simply leave it disconnected since then? Did one end or the other twist off, allowing it to slide out of the sleeve? It should not be cable to slide out of the sleeve, IIRC.
Old February 11th, 2013, 12:48 AM   #3
rawbert625
rawbert625's Avatar
Motorcycle(s): the cool ones
Are you using the stock dash or an aftermarket one?
rawbert625 is offline   Reply With Quote
Old February 11th, 2013, 01:09 AM   #4
As I recall, he returned it for a refund.
Old February 11th, 2013, 07:32 AM   #5
/moved to new-gen tech
Old February 11th, 2013, 07:48 AM   #6
Clearly it's telling you that it wants to become a track bike.
Old February 11th, 2013, 10:14 AM   #7
skilletmo
InfoWhore
skilletmo's Avatar
So that pin at the ends of the cable is what i have to check? What do i do, just make sure its all the way in? (thats what she said)
I put everything back together after i was done with the other gauge and its been working since this metal cable thing hooking on my front wheel incident last night.
Last futzed with by skilletmo; February 11th, 2013 at 12:28 PM.
Old February 11th, 2013, 10:16 AM   #8
skilletmo
InfoWhore
skilletmo's Avatar
Funny story, I returned it since the tach wasnt working, he never received it after a month. So he just gave me my money back. 2 weeks ago it came back, box was all messed up and it said return on it because they didnt find the address. I must have written it wrong or something. Anyways its here now sitting and i might one day give it to a pro with gauges and electronics who can make it work or something. So i got my money back and the gauge.
Old February 11th, 2013, 10:19 AM   #9
skilletmo
InfoWhore
skilletmo's Avatar
My exact plans when i decide to buy a 600 or 1000. I am never selling this full system exhaust (got for free) little track monster.
Old February 11th, 2013, 03:21 PM   #10
skilletmo
InfoWhore
skilletmo's Avatar
So.... Ya lol
The metal wire cut the bottom of the metal cord in the rubber.... Found out when i unscrewed the bottom end of the cable were the wheel is.
Old February 11th, 2013, 03:35 PM   #11
Is that the cable in the picture of the first post?
Old February 11th, 2013, 03:51 PM   #12
skilletmo
InfoWhore
skilletmo's Avatar
The metal wire that was stuck to my rim from god knows what and how, probably just caught on there while riding, cut the metal cable in the rubber tube which is the "speedometer cable". The picture of the metal wire in the first post is what cut the speedometer cable in my last post. Hope that clarifies it.
Now i have to wait like 5 days for a new one... Unless someone sells that cable in Dallas lol
Just a quick question, if anyone knows, the speedometer cables are all the same for 08-12 right?
Edit: the third picture on the right is the same cable as the other 2 next to it, but just without the rubber, i removed the rubber to show yall.
Old February 11th, 2013, 03:56 PM   #13
You were very lucky because that vagabond wire could have caused a lot of damage to your leg or chain or more.
I am not sure, but I would say that it is the same cable for all models.
You could verify the part number in Ronayers website.
Old February 11th, 2013, 04:25 PM   #14
skilletmo
InfoWhore
skilletmo's Avatar
Ya never thought of it that way, and ya i will look. Thanks for the help!
Old February 11th, 2013, 05:09 PM   #15
rawbert625
rawbert625's Avatar
Nice man, totally lucked out!
what kind of gauges did you get?
Old February 11th, 2013, 07:55 PM   #16
How much was the replacement?
Old February 11th, 2013, 11:12 PM   #17
skilletmo
InfoWhore
skilletmo's Avatar
No replacement. I received the 93$ i paid for it because i showed proof of tracking number and a paper showing it was shipped. I dont have new gauges yet, ive been using the same old one. I painted some of it so it blends in like in the picture. Im planning to buy a Trail Tech Vapor or something at the 100$ range in summer when i have the 100$ to spare.
Old February 16th, 2013, 09:49 PM   #18
If you're still looking for a speedometer cable, @slolee is selling one for $5:
http://www.ninjette.org/forums/showthread.php?t=124177
Old February 17th, 2013, 01:47 AM   #19
skilletmo
InfoWhore
skilletmo's Avatar
I got one for 15$ shipped thanks! I am definitely interested in some other things of his so thanks for the thread find too!
Aftermarket Speedometer aspenratt07 2008 - 2012 Ninja 250R Tech Talk 2 February 25th, 2014 06:05 AM
Need help with speedometer.. Rheno911 2008 - 2012 Ninja 250R Tech Talk 7 August 31st, 2013 08:19 PM
Speedometer calibration eljay 2008 - 2012 Ninja 250R Tech Talk 27 September 6th, 2012 08:56 PM
Inaccurate Speedometer gilmorec61 2008 - 2012 Ninja 250R Tech Talk 3 January 29th, 2012 08:38 PM
Speedometer Problems Cedilla 2008 - 2012 Ninja 250R Tech Talk 3 July 24th, 2009 04:35 PM
