March 23rd, 2013, 01:12 PM | #1 |
InfoWhore
Join Date: Oct 2012 Motorcycle(s): 2008 Ninja 250 StreetFighter ~~~~ 2005 KTM 450 EXC Posts: 628
Speedometer Thread Size
So i have been looking to buy a analog speedometer and have been doing some research on some of my choices. Anyone know what the speedometer thread size is? So that i can find one that could fit the 250 speedo cable. I am doing this so i can have more space to work with the front fairing cut-down im about to do.
I was thinking about going with this tach once i hear back from one of the members if it worked correctly. Ebay Tach For the speedo i was thinking something like this, once i find the thread size. Ebay speedo Or This Royal Enfield Speedo (without the AMP thing)
Everyone, go buy a dirtbike hurry |
March 26th, 2013, 10:23 PM | #2 |
InfoWhore
@Motofool Need a wise mans help!!
Anyone!? Also if you can at least tell me where i can find the page to find the size! Should be something along the lines of "18mm" or "17mm". HELP
March 27th, 2013, 05:27 AM | #3 | |
March 27th, 2013, 07:19 AM | #4 |
InfoWhore
Love you man!!!
March 27th, 2013, 09:41 AM | #5 |
Just measured the thread for the cable in my 2007:
M10 x 1.0 mm (of pitch)
March 27th, 2013, 12:50 PM | #6 |
InfoWhore
Ok so is that the same for the 08? And that means its a 10mm thread correct?
March 27th, 2013, 01:15 PM | #7 |
The cable-speedmeter part number for the 2007 model is 54001-1123.
The part number for the 2008 is 54001-0014. I would assume that the thread of that end is the same, since diameter of 8 mm would be too small and 12 would be too big. Hopefully someone owning a 2008 will confirm this. Yes, M10 means metric thread of exterior diameter = 10 mm. The distance between two consecutive crests of the thread is 1.0 mm, and that is known as a fine thread for a M10.
March 27th, 2013, 01:52 PM | #8 | |
InfoWhore
And i really appreciate your help, hopefully someone can confirm for the newgen thread size.
March 27th, 2013, 02:22 PM | #9 |
i'll see if i can find my old speedo tonight.
March 27th, 2013, 02:52 PM | #10 |
InfoWhore
Thanks!
March 27th, 2013, 07:14 PM | #11 | |
You are welcome.
March 27th, 2013, 07:53 PM | #12 |
I got 12mmx1.0...
11.76 mm OD and 4.8mm/5 threads is close to 1 mm Eta i have a 2012
March 27th, 2013, 09:05 PM | #13 | |
InfoWhore
I reallyapreciate it guys, thanks! Now time to shop for some similar speedos that are smaller, if all else fails, im going digital
March 31st, 2013, 08:23 PM | #14 |
InfoWhore
Ok so i found this speedo for 62$ shipped and planning to buy this Tach for 23$ shipped. The speedometer has the 12mm thread for the speedo cable that i need and it has the lights i want too. The tach works fine and recomended by another ninja user on this forum.
My only question and my final one() is that if this is a 2:1 ratio, then how willit affect the speed reading compared to the Newgens speedos? Does anyone know the Newgen speedo ratio? is it 23:9 like the pregen? And i did alot of googling and research and all i find out was the the pregens are 23:9 and its calibrated by front tire size which is 16" on the pregen. 17 on the newgen, so im not sure if the ratio is the same on the newgen... caling @Motofool again AND ANYONE ELSE WHO CAN HELP!
April 1st, 2013, 08:28 AM | #15 | |
2240 revs = 1 mph Hence, when the cable spins at 2240 rpm, the speedometer reads 60 mph. The designation 2:1 is mainly for Harleys, which means 2000 rpm = 60 mph http://www.retrocycle.com/catalog_pd...n_2010/682.pdf http://www.mikesxs.net/products-46.html#products
Motofool .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí Last futzed with by Motofool; April 2nd, 2013 at 06:01 AM. |
April 1st, 2013, 10:18 PM | #16 | |
InfoWhore
April 2nd, 2013, 06:03 AM | #17 |
It should be the same for any Japanese bike.
If you input 224 turns and the odometer reads 1/10 mile, then that speedo is good for your Ninja.
April 2nd, 2013, 11:28 PM | #18 |
InfoWhore
So would someting like this work? It has a 2240:60 ratio and a 12mm thread (12mm for Newgen ninjas). This should read the same as my stock cluster correct?
Sorry for so many "confirmation" question posts, i have been scarred by my last speedometer stunt haha.
April 3rd, 2013, 05:50 AM | #19 | |
No need to be sorry.
Not another tire size thread!?!?? really!? | gantt | 2008 - 2012 Ninja 250R Tech Talk | 10 | March 23rd, 2015 08:01 AM |
Rear spool thread size | Robbo81 | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 18th, 2014 01:48 AM |
Coolant drain plug thread size | Kneedragon88 | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 7th, 2014 12:06 PM |
metric thread size question | mikedabike64 | General Motorcycling Discussion | 7 | March 26th, 2014 06:57 PM |
Bike size (shape not cc power thread) | Mowgli | General Motorcycling Discussion | 11 | July 9th, 2012 09:14 PM |
