Old July 12th, 2013, 08:21 PM   #1
beninja
beninja's Avatar
Post Underneath the Block Off Plate?
I recently purchased a block off plate and was wondering if the two holes under it leads directly into the engine.
If so, when installing the new plate would it possible to use some short of engine treatment (seafoam, B-12, etc.) and pour it directly into the engine?
I also cleaned out some junk under the gasket plate ensuring a seal for under the block off plate.
beninja is offline   Reply With Quote
Old July 12th, 2013, 09:02 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Leads strait to your cams if I recall, I'd say don't use sea foam there because you'll directly thin the oil in the cam area by a lot and that would be bad.
Old July 12th, 2013, 09:34 PM   #3
keeblerkhan
Motorcycle(s): 250J
+1 Your camshafts float on journal bearings and it probably wouldn't be best to thin the oil in this area...or anywhere for that matter with an additive.
I think there is a widespread misunderstanding of what seafoam and similar products are, do, and how to use them. They are not a cure-all that you just use everywhere. If you change your filter and oil regularly you should NEVER have to add an oil treatment. Every now and then it won't hurt to put a little seafoam in the fuel tank to run through the carb, but even this isn't at all necessary or useful if the motorcycle is used frequently. Today's oils and fuels are really very good (at least what we have here in the states) and they keep things pretty clean inside the engine and fuel system.
keeblerkhan is offline   Reply With Quote
Old July 12th, 2013, 10:04 PM   #4
beninja
beninja's Avatar
Thanks guys, I was just wondering since I will have the plate off. I'll just install the new plate after I clean up the area under it.
Old July 13th, 2013, 11:00 AM   #5
Runeknight95
Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only
This doesn't sound correct.
In all my other model bikes the block off plates go directly to the exhaust, the smog plates are there to pump fresh air into the exhaust to meet EPA standards.
Unless you're referring to another type of block of plate?
Runeknight95 is offline   Reply With Quote
Old July 13th, 2013, 11:26 AM   #6
beninja
beninja's Avatar
http://www.ninjette.org/forums/showthread.php?t=97700
It leads to the top of the engine.
Old July 13th, 2013, 01:11 PM   #7
Runeknight95
Originally Posted by beninja View Post
Roger that!
Install Block Off Plate On The 300 cbzdel 2013 - 2017 Ninja 300 General Discussion 28 January 16th, 2013 12:48 PM
DIY - Emission block off plate MikeBudd 2008 - 2012 Ninja 250R Tech Talk 29 September 6th, 2012 11:47 AM
Smog Block Off Plate - $10 !!! road_warrior64 2008 - 2012 Ninja 250R Tech Talk 5 May 4th, 2012 10:05 AM
Kawasaki 08 09 10 Ninja 250 250R Emission Block Off Plate onepeon 2008 - 2012 Ninja 250R Tech Talk 86 January 14th, 2012 07:19 PM
