#1 |
Join Date: Jul 2013 Motorcycle(s): 2009 Ninja 250 Posts: 55
Are the demon eyes/angel eyes the only HID headlight housings made for the 2008-2012 Ninja? I'm looking for a direct replacement as I don't want to modify my current housing and I'm not that mechanical. They are $400
![]() http://eshop.ktautopart.com/kawasaki...2008-2012.html ![]() ![]() Last futzed with by passive101; July 23rd, 2013 at 10:20 PM. |
#2 |
#3 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
doing it yourself will be cheaper.....
or you can pay for a premade one for big $$$ custom lights like this are always expensive. |
#4 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
Why spend 400 bucks on that? Buy some good tires and a brt tis instead
#5 |
Bass Master General
Dual High Beams and Dual Low Beams
Won't blinding the oncoming traffics 300% brighter than stock holagen headlight No need to modify stock headlight, directly fit. Good to know it won't blinding the oncoming traffics and it's brighter than holagen, directly fit too! |
#6 |
I am running a regular H7 bulb as my high beam. My low beam is 190% brighter then stock as I'm running an H7/H9 hybrid with no problems with the stock wiring and full length life from the bulb with 700 more lumens
![]() So far this is actually holding me over and it was a huge improvement with the exact same beam pattern as H7's. I'm not good with doing it yourself things and 400 is just to much for me right now. My next bike will be easier to put them in so I'm not worried. If I have extra money in the future, I'd consider this though. |
#7 |
Join Date: Jan 2012 Motorcycle(s): 2008 (Black) Kawasaki Ninja 250R Posts: 151
#8 | |
#9 |
that is a kit... not sure how much easier I can make it.
you are just reusing the oem housing. |
#10 | |
Join Date: May 2013 Motorcycle(s): Kawasaki Ninja 250R Posts: 51
Looks like he's outta luck, you get what you pay for and if you want it all together you have to fork over the $400. |
#11 |
I don't want to have to do all this and risk screwing something up. http://www.kawiforums.com/ninja-250r...inja-250r.html
#12 | |
Join Date: Aug 2010 Motorcycle(s): 2010 250R SE Posts: 262
The only problem I've found with the bkmoto kit is the wiring harness is bit shorter than what I expected. Either I splice the projector control end or the battery terminal leads to make it longer. I'm still debating due to mounting space on which end but I was leaning towards the battery end. Hopefully, I'll have it in this weekend and have pics. |
#13 | |
Join Date: Sep 2011 Motorcycle(s): Ninja 250r se 2011 Posts: 5
#14 | |
Join Date: Jun 2013 Motorcycle(s): 2013 Ninja 300 Posts: 470
ATGATT Fresh meat on the street |
#15 |
On the 300 only one light is on for low beams and then both for high beams. So with these aftermarket kits both lights are lit up for low and high beam. These lights make a HUGE difference at night. With the stock headlights I struggled to see at night.
#16 |
If someone would figure out how to put a set of FXR projectors in these headlights, I'd be impressed. BKmoto ones are too gaudy (angel/demon eyes) for my taste.
#17 |
if they don't autolevel then you will still blind people when turning with bixenons. doing it yourself is not hard. and costs about 10x less
#19 |
Join Date: Apr 2012 Motorcycle(s): 2012 250R CLG Posts: 23
#20 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
I tried to contact the maker on eBay who has the drop-in ready kit ($400) but he won't get back to me.
Maybe someone else can and try a group buy Its not like he's moving tons of inventory. I didn't see any sell in the past 6 months according to his profile
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
#21 |
Join Date: Jul 2012 Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :( Posts: 270
Don't buy KTautopart. Had them on my r6. Demon eyes burnt out and the plastic lens popped off in the housing. pita and not worth it. bkmoto is said to be the best of the lot.
#22 |
BTW anyone with a 300 wanting projectors the new 636 headlight assembly is the exact same dimensions but projectors. Literally plug and play.
#23 |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
#24 |
[url]http://www. kawasakininja 300 .com/forum/12-ninja-300-appearance-modifications/20713-headlight-swap.html Last futzed with by Xtina; October 2nd, 2013 at 06:21 PM. |
#25 | |
#26 |
www. kawasaki ninja 300 .com Take out the spaces and then add the other stuff on. That's one of Alex's goofy auto sensor things.
#27 |
Nooblet
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R FI Posts: A lot.
MOTM - Oct '13
@gibtzumich318: that looks so awesome! I'd love my ninjette to have those eyes. Shame the kit is so wonky to fit. If I was paying that much I'd want something as close to plug and play as possible.
Just finished my HID retrofit today | CThunder-blue | 2008 - 2012 Ninja 250R Farkles | 147 | May 29th, 2018 05:32 PM |
Anybody try this halo angel demon eyes assembly? | Han Solo 1 | 2008 - 2012 Ninja 250R Farkles | 2 | May 25th, 2014 10:34 AM |
HID Projector retrofit completed(Pics) | ForceofWill | 2008 - 2012 Ninja 250R Farkles | 13 | August 6th, 2012 11:58 AM |
HID PnP Kit With Angel Eyes | wayanlam | 2008 - 2012 Ninja 250R Farkles | 23 | July 23rd, 2011 11:32 PM |
