Old July 29th, 2013, 03:52 PM   #1
Løckøut
Løckøut's Avatar
Motorcycle(s): 2007 Ninja 250r
Removing front wheel.
I got a flat front tire on Saturday, and I'm planning on taking the whole front wheel off and taking it to House of Kawasaki tomorrow evening for repair. I haven't really eyeballed it yet, but how do I take the front wheel off the proper way?
Løckøut is offline   Reply With Quote
Old July 29th, 2013, 03:56 PM   #2
Lychee
sail away
Lychee's Avatar
you need a method of supporting the front with the wheel off the ground. A common method is either using a front fork stand or front triple tree stand.
Old July 29th, 2013, 04:04 PM   #3
n4mwd
n4mwd's Avatar
Supporting it in a stable way is a real pain. Its not very pretty, but I use a step ladder with a strap around the handle bars. To get it up in the first place, I jack it up with a floor jack. The jack point is the oil filter cover with a small piece of 2x4 as a cushion so I don't damage the engine or pipes.
Just make sure you loosen the axle nut before you jack it up. You don't have to remove the brakes, but it would make it a little easier.
One important thing is the spedometer pickup. It has to go in just right or it wont let the wheel spin and can be damaged. Study it carefully before reassembly.
My Ninja Blog
Old July 29th, 2013, 04:16 PM   #4
put it on your rear stand, then put it up on a triple stand.
alternatively stick two jack stands under the forks and put some bricks under the engine. don't tip it over.
another alternative (i've used in emergency tire situations) is to put the bike on a curb and let the wheel hang off over the edge of the large curb. put a brick down so you can support the bike by the engine instead of the headers.
Old July 29th, 2013, 04:57 PM   #5
http://faq.ninja250.org/wiki/What_ca...on_the_road%3F
http://faq.ninja250.org/wiki/Support..._the_Front_End
http://faq.ninja250.org/wiki/Greasin...wheel_bearings
http://faq.ninja250.org/wiki/Reinsta...he_front_wheel
http://faq.ninja250.org/wiki/Tire_Mo...Hints_%26_Tips
Old July 29th, 2013, 06:38 PM   #6
7oxSin
MSF Coach!
7oxSin's Avatar
Motorcycle(s): 2003 ninja 250
@Motofool no need for me to post, yoda's got it covered.
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th
Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35
7oxSin is offline   Reply With Quote
Old July 30th, 2013, 06:21 PM   #7
Løckøut
Løckøut's Avatar
Thanks everyone. I have the tire of and marked with sharpie where the speedo should be; soaped the tire down and found a teenie tiny pinner of a hole. I'll have her plugged and running by tomorrow evening
Old July 30th, 2013, 07:13 PM   #8
For a little hole, an internal patch is a much better option and a more permanent repair.
Balance that wheel after the repair !!!
Old July 30th, 2013, 08:05 PM   #9
n4mwd
n4mwd's Avatar
A plug is more for emergency roadside repairs. The weight of the plug can throw off the balance.
Patches are a little harder to install, but you have a better seal. Just be careful not to warp the brake rotor getting the tire off. When done, rebalance so save the little weights.
My Ninja Blog
Fix for front wheel squeak noise/Front wheel removal cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 13 April 23rd, 2014 12:25 PM
250 ninja front wheel and 300 ninja front wheel JasonG134 2013 - 2017 Ninja 300 Tech Talk 2 March 30th, 2014 09:12 PM
Removing the front fender Old Lemon 2008 - 2012 Ninja 250R Tech Talk 5 December 8th, 2012 08:06 PM
Need help removing front cowl bracket kashun84 2008 - 2012 Ninja 250R Tech Talk 5 March 29th, 2011 12:20 PM
Removing Rear Wheel? minuslars 1986 - 2007 Ninja 250R Tech Talk 6 September 1st, 2009 03:23 AM
