Old March 7th, 2009, 07:51 PM   #1
Karma250R
Motorcycle(s): Ninja 250R, K7 GSXR 600, 2 Honda Ruckus'
Read my plugs
What do you guys think is she running lean?
Karma250R is offline   Reply With Quote
Old March 7th, 2009, 07:57 PM   #2
Sloppy2nds
just a n00b
Sloppy2nds's Avatar
Motorcycle(s): '06 R6/'08 250R
when did you pull it off the bike or how did you ride it before you pulled it off?
Sloppy2nds is offline   Reply With Quote
Old March 7th, 2009, 08:43 PM   #3
Karma250R
Just a normal ride. pulled them out last night when I got home from work
Old March 7th, 2009, 09:12 PM   #4
is it possible to get a shot of the ceramic around the center electrode area?
what are you testing for? main jet?
Old March 8th, 2009, 12:27 AM   #5
Karma250R
I barely ride the 250R but I have been riding it alot recently. And I have never jetted the bike yet. I have had this Dyno Jet kit for a long time. After riding it more frequently the bike does not run really well from 1-6ishk rpm. Then it comes alive. I need to install this kit ASAP. After do some reading I suspect the bike needs to be richend up a little down low. She may be lean, with the Area-P and snorkel removed. I may just try the washer trick. Or just use the needles from the dyno jet kit.
Old March 8th, 2009, 01:49 AM   #6
either will help. if you use washers, I'd recommend 3.
Old March 8th, 2009, 08:42 AM   #7
g21-30
g21-30's Avatar
You have the Stage 2 2193 kit? Put the needles with the clip in slot #3, 2 washers and a clip on top of those (see attachment). Adjust the idle mixture screws (remove the caps to get to the screws) 2 1/2-3 turns out and I bet your problem is solved!
As kkim stated, we need a picture of the ceramic insulator, viewed from the end of the plug.
More general info:
http://www.strappe.com/plugs.html
Old March 8th, 2009, 02:44 PM   #8
ajaygraci
Motorcycle(s): 2009 ninja 250r, black, carbon fiber full exhaust...2000 toyota 4runner
if you put a full exhaust on do you have to re-jett it? if you want your bike to run good i mean and not break down... i just installed a fulkl system but have no clue about jetting it or anything... can i just take it to a shop or something and theyll do it or do i need a kit n easy enough to do myself?
ajaygraci is offline   Reply With Quote
Old March 8th, 2009, 06:30 PM   #9
islanderman7
The Sexy Filipino
islanderman7's Avatar
Motorcycle(s): Ninja 250R 2008 (da black one)
This is a pretty good link that gives an idea how to read plugs. Lots of Pics of Plugs
Yes you need to re-jet. Read the Sticky DIY threads in the Tech Talk area.
Area P CF Standard,Airbox Removed,K&N R-0990,Factory Pro Jet Kit 3.0, Zero Gravity DB
I'm not riding too fast... I'm flying too low.
islanderman7 is offline   Reply With Quote
Old March 9th, 2009, 03:18 AM   #10
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
how's the bike running since installing the pipe? are you sputtering/stuttering/missing etc along the powerband anywhere? more often than not, exhaust makers will suggest rejetting somewhere in the installation instructions. there are some threads on the forum that details both jet kits and mixture needle shims. check it out and see if these options are in your 'wrenching range'. CAN you do it yourself? if not, i'd pay for a shop to do it. let us know what you're gonna do k?
aloha
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old March 9th, 2009, 06:21 PM   #11
Karma250R
I think im gonna try and just install these needles first and see what I get with that. I have the DynoJet stage 2 kit 2193.001
So g21-30 you recomend putting the clip on slot #3?
Old March 9th, 2009, 06:23 PM   #12
If that's where the instructions recommend, I would start there.
Old March 9th, 2009, 06:47 PM   #13
HKr1
IC2(SW)
HKr1's Avatar
Old March 9th, 2009, 09:46 PM   #14
Karma250R
Just seeing if any one has tried just using the aftermarket needles with no jet changes. And what results they got, before I do it. I was thinking maybe trying to duplicate the affect of "raising the needles" w/ washers, but using aftermarket needles w/ there different tapper. I will let you guys know what happens.
Old March 9th, 2009, 11:54 PM   #15
I've seen it done before. It worked well.
Old March 10th, 2009, 03:34 AM   #16
g21-30
g21-30's Avatar
Yes and since the kit includes 2 extra circlips, I put one on top of the two washers. When I tried to install the needles with just the washers, one washer fell off. Of course, I could have used vaseline/grease, etc. I just figured the extra circlip would fix it for good.
You Read My Mind csmith12 Forum Information 2 September 4th, 2014 06:01 PM
Please read this psych0hans Riding Skills 20 April 25th, 2014 11:42 AM
Please read. Sorry blink General Motorcycling Discussion 28 June 8th, 2011 05:32 PM
My plugs headshrink 2008 - 2012 Ninja 250R Tech Talk 1 March 24th, 2010 02:07 AM
You should read this.... Apex General Motorcycling Discussion 7 June 23rd, 2009 10:01 AM
