Old March 16th, 2009, 11:54 PM   #1
Jiu Jitsu Player
Live 2 Ride Forced 2 Work
Jiu Jitsu Player's Avatar
Motorcycle(s): 2008 RED 250r
Anyone know of a way to clean the materials inside your helmet?
I was wondering if anyone knew if there was a way to remove some of the pads and stuff inside the helmet to wash them some how. Its starting to get alot warmer now and I don't want it to smell bad from sweat, etc.
Jiu Jitsu Player is offline   Reply With Quote
Old March 17th, 2009, 12:05 AM   #2
zartan
zartan's Avatar
Motorcycle(s): 08 250 R
I just bought a can of foam helmet cleaner. you spray it in and it foams up and you wipe it dry. It is safe and not to fragrant. You wipe it out and good to go!
MOTOREX HELMET CARE SPRAY
Description
Cleaning foam and care for helmet shells and inner padding
Cleans, deodorizes and protects
Effectively removes dirt fast
Brightens up colors
Protects the helmet surfaces
Can also be used on removable inner padding
Leaves a pleasant, fresh fragrance
"Don't let adverse facts stand in the way of a good decision" Colin Powell
zartan is offline   Reply With Quote
Old March 17th, 2009, 12:07 AM   #3
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
Depends on the helmet. You should've gotten a few little guides with your helmet that tell how to take out the pads. Some helmets don't have completely removeable pads. Mine only detaches some of the pads. Just depends on your helmet. Check to see if you still have the stuff that came with the helmet. If you do, I bet it's in there somewhere.
Verus Cidere is offline   Reply With Quote
Old March 17th, 2009, 02:01 AM   #4
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
Try look for something that is antiseptic to kill all them nasty germs that touch your head every time you wear a helmet.
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
Old March 17th, 2009, 07:35 AM   #5
TrueFaith
TrueFaith's Avatar
Motorcycle(s): 2011 Honda CBR250R
Or do what us old-timers do and wear a SLIKS helmet liner and wash that instead.
http://www.cyclegadgets.com/slik/
TrueFaith is offline   Reply With Quote
Old March 17th, 2009, 08:01 AM   #6
Broom
Track Junkie
Broom's Avatar
Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike
some helmets have a removable liner, some don't... if it doesn't there is cleaner you can use.
i've used fabreeze on my gear before, but not my helmet. not sure how it'd react to my face, but might be fine. obviously let it dry before wearing.
one thing you can do is always lay out your gear after getting it sweaty so that it can dry quickly. i usually lay everything out and put empty toilet paper rolls in my gloves and turn on a ceiling fan.
Las Escobas -- Track Bikes Save Lives
JonBroom.com
Broom is offline   Reply With Quote
Old March 17th, 2009, 08:15 AM   #7
zartan
zartan's Avatar
Becareful not to use something that will break down the foam and react bad with the hard interior shell.
Old March 17th, 2009, 09:33 PM   #8
Jiu Jitsu Player
Thanks for the tips. I'll definitely check that spray out. Im not too worried about gear, just mainly my helmet.
SAVAGE MODE: [ON] OFF
www.7milesdown.com
Old March 17th, 2009, 11:13 PM   #9
DirtyBoy
DirtyBoy's Avatar
Description
Brightens up colors
I have that product, however I was told by someone at Arai not to use it because it can break down the adhesive they use.
49T sprkt/ EK gold chain/ Galfer pads and SS lines/120 frt 150 rr Pilot Powers/ GSX-R can/Desnorkled/ Raised needles/ Slider spools/ Cowl/ LED rear signals/ Fender eliminator/ Tinted lights / Emu seat
DirtyBoy is offline   Reply With Quote
Old March 17th, 2009, 11:24 PM   #10
zartan
zartan's Avatar
what the heck!! I was told it was safe . Please, can you let me know where you found that out , did you call Arai directly?
I should call the place where I got it and let them know.
Old March 17th, 2009, 11:35 PM   #11
Jiu Jitsu Player
Damn. Ixnay on the spray I guess until someone can confirm....
www.7milesdown.com
Old March 17th, 2009, 11:41 PM   #12
zartan
zartan's Avatar
I just logged on to arai and did a support ticket to ask . will post reply but I believe you dirtyboy. Just want to confirm.
Old March 18th, 2009, 12:28 AM   #13
Sound Wave
Ramen Rider
Sound Wave's Avatar
my helmet has padding that completely removes.... still, i do have something like that too. i have a couple, so like you said, i just throw that in the wash. easier that way... plus it helps reduce "helmet hair"
click here
Old March 18th, 2009, 11:29 PM   #14
DirtyBoy
DirtyBoy's Avatar
Yes, I called Arai directly.
Old March 20th, 2009, 08:07 PM   #15
zartan
zartan's Avatar
confirming Dirtyboys post
Talked to a tech also. He said ok to take helmet into the shower. I Live in WASHINGTON. NOTHING DRYS HERE. I told him... we live in a wetland pond in this state. He said that people over use the chemicals. Did not say it was necessarally horrible for the helmet but did not elaborate.
But would only suggest the following.
Directly from Arai:
Thank you for your request about recommended helmet cleaning procedures.
For the inside, please remove the cheekpads and headliner (where applicable). Remove cheekpad covers and wash individual items by hand in the sink using a small amount of mild shampoo or Woolite. No dish soap or any other product with aggressive grease dissolving agents. The shell of the helmet can be cleaned in the shower with a small amount of shampoo and lots of water. If a large enough sink is available, the helmet can also be cleaned in this manner. Remember, lots of water and a the smallest amount of shampoo necessary to clean the material inside the helmet. When clean, shake the helmet to help expell water caught in the air channels, and rest the helmet upside down to air dry for a day or two. Under no circumstances use a hair dryer or any other heat source to dry the inside as this may have a negative effect on the EPS liner. It may also be necessary to make some provision to keep your canine friends away while it dries- we’ve had a customer or two whose dog has mistaken a helmet for a chew toy…
For the outside, more of the same- water. Use a clean, soft towel and water to clean the outside of the helmet as well. Warm water will help remove bug debris, and if necessary a warm towel may be put over the shield to clean it easier. Under no circumstances use glass cleaner on the shield (or any other part of the helmet, for that matter). This is the most significant cause of chemical embrittlement that leads to side pod failure and shield deterioration. The other mistake we often see is too much of a cleaner or polish. It too much polish is left to soak on the helmet, it can creep under the adhesive that holds the vents in place, and cause them eventually to become loose or even fall off. If one wants to use an exterior polish, we recommend spraying just a whiff of it onto a cloth, and then applying it to the helmet. The less, generally, the better.
Once clean, use a dab of the silicone provided with the helmet to keep the eyeport gasket soft, and you should be good to go. Please consult your owner’s manual for more information. If you have any additional questions about cleaning or maintenance, please let us know, and we’ll be happy to point you in the right direction.
Best regards,
Rob Lefever
Arai Technical Services
Old March 20th, 2009, 08:20 PM   #16
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
thats some good info zartan, thank you very much
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old March 28th, 2009, 05:56 PM   #17
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
arai just got major bonus points with that reply as well!
Old March 28th, 2009, 08:14 PM   #18
00v_Lucky
00v_Lucky's Avatar
Motorcycle(s): '09 Candy Thunder Blue Ninja 250R
thx zartan for that post, no more windex for me! :/
00v_Lucky is offline   Reply With Quote
Keeping your helmet clean Roranninn Motorcycle Gear 7 April 10th, 2015 08:13 PM
What's Inside the Helmet? Motofool Motorcycle Gear 11 December 7th, 2014 10:53 AM
[motorcyclistonline] - How To Clean Your Helmet | MC GARAGE Ninjette Newsbot Motorcycling News 0 December 1st, 2014 09:51 PM
[motorcyclistonline] - What's Inside the Helmet? | MC GARAGE Ninjette Newsbot Motorcycling News 0 November 30th, 2014 10:21 PM
A Bee INSIDE The Helmet Jiggles General Motorcycling Discussion 56 August 20th, 2012 03:26 PM
