Old March 28th, 2009, 01:48 PM   #1
ajaygraci
Motorcycle(s): 2009 ninja 250r, black, carbon fiber full exhaust...2000 toyota 4runner
help---installing my flush mount turn signals.
hey they arrived yesterday.. anyone know how to install?? here are some pictures...these have 3 wires coming out, red, black, black with white line...i took some pictures but i dont know how to post??
i just uploaded them on here but nothing happened? says internal server error?
EDIT: ive heard from other members here there is no running light stock?? so i should plus myn into the horn >?? how the heck should i do that ( im clueless on this install...just wrap color to color and then heat shrink it right?)
ajaygraci is offline   Reply With Quote
Old March 28th, 2009, 01:50 PM   #2
ajaygraci
heres some others... gues it worked? didnt show up in my post but after i posted it n looked it was there lol... anyway how should i go about installing these?
Old March 28th, 2009, 03:24 PM   #3
ajaygraci
........bump....
Old March 28th, 2009, 05:27 PM   #4
Sound Wave
Ramen Rider
Sound Wave's Avatar
Motorcycle(s): 08 Honda VFR800A
disclaimer: i am not 100% sure about this. since i have never done it before
the red and black are the ones you need. you could either splice and connect your wires with the oem ones, or you could buy this kawasaki oem adapter for $4.99
http://www.moto911.com/product_info....3fa9386d4c583d
also, you could cut off your turn signal side connector and attach it to your new turn signal.
i don't know what the 3rd wire does, but you said it is the daytime running light? well, if you do attach the 3rd wire into the hot horn wire, then you can use one of these quick splice connectors.
http://www.radioshack.com/product/in...ductId=2998436 they don't require removing the original wire. just tap in somewhere along the length.
i am not sure how much draw those lights have. i wonder if it would cut down the power available to your horn if you did use the running lights? you could also just attach it directly to your battery, huh?
just cover all your work with some electrical tape or something.
i have wired up stuff in my car, but i am new to motorcycling. just trying to throw out some ideas.
Old March 28th, 2009, 07:13 PM   #5
ajaygraci
thanks sound wave, yea i was thinking about cutting the box thing off my stock turn signal wires and sticking the new ones through there so i can unplug easily for fairing removal, thanks for the link.
Old April 1st, 2009, 07:48 AM   #6
Ninja007
忍者
Ninja007's Avatar
Motorcycle(s): None Now - Used to have an '08 Ninja 250R Candy Blue
yes! just like sound wave said. I have flushmounts that have the exact same wiring. had to cut the connector off the stockers and spliced it onto the two wires of the flush mounts. as you know, there is a 3rd wire that you don't need, so I jsut lopped it off. I know you are probably already done with the install, so did it work for you? How does it look? pics please?
Ninja007 is offline   Reply With Quote
Flush Mount Turn Signals Gunner Motorcycle-related 1 May 12th, 2013 08:47 AM
flush-mount turn signals? SafetyPaws 2008 - 2012 Ninja 250R Farkles 18 May 5th, 2012 01:39 PM
Flush mount turn signals jagerbomb00 2008 - 2012 Ninja 250R Farkles 4 May 20th, 2011 08:38 PM
Flush Mount Turn Signals VANtaged 1986 - 2007 Ninja 250R Farkles 7 September 20th, 2010 07:26 AM
flush mount turn signals fiberoptx 1986 - 2007 Ninja 250R Farkles 6 October 17th, 2009 06:45 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Except where otherwise noted, all site contents are © Copyright 2013 ninjette.org, All rights reserved.
