Old December 7th, 2013, 01:17 PM   #1
notsofast
Motorcycle(s): 2005 Ninja 250
Accessory holes in control lever perch.
On my bike there are holes with threads in the perches of the control levers. I assume they are another one of those things Kawasaki built into the bike for when a newb breaks something.
Does anyone have any idea what the bolt size and pitch are? I unfortunately dont have any extra metric fasteners lying around or Id go figure it out.
I assume they are 10mm but I would rather not make two trips to the shop.
Thanks!
notsofast is offline   Reply With Quote
Old December 7th, 2013, 01:37 PM   #2
they are for mirrors, and they are different sizes on left and right if i remember right. one is a 10mm though. they use the same controls on other bikes, so those holes are for when its on a bike that has handle-bar-mounted-mirrors.
Old December 7th, 2013, 01:37 PM   #3
they also make these nifty little plastic things that you can use to see what size and pitch a hole is. it's like $2
Old December 7th, 2013, 01:41 PM   #4
notsofast
I did not know that, thank you! I will probably go get one today.
Old December 7th, 2013, 02:26 PM   #5
notsofast
edit: found it
Old December 10th, 2013, 05:41 PM   #6
Lychee
sail away
Lychee's Avatar
can also use for GPS , phone, go Pro, gyro cup holder.
Old December 10th, 2013, 06:11 PM   #7
notsofast
Yea, I am using a super tiny mirror at the moment...feels pretty unsafe. I'm probably going to order 07 z1000 mirrors once I confirm they fit these holes. I have a feeling that the 05 ninja 250 and the 07 z1000 use the same control perches.
Old December 11th, 2013, 08:24 AM   #8
Lychee
sail away
Lychee's Avatar
why don't you use the stock mirrors? those are pretty good. Track fairings?
Old December 11th, 2013, 03:20 PM   #9
notsofast
I dont have the stock front end electrics installed, fairing stay was broken from p/o, everything would shake and bounce around on the road.
Old December 12th, 2013, 08:27 AM   #10
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
Very usefule mirror mounts, and they are both standard 10mm, so you can use almost any mirrors ever made, or a GPS or smartphone mount.
Chicagobob is offline   Reply With Quote
Old December 12th, 2013, 01:49 PM   #11
notsofast
Ty amigo, Chicagobob to the rescue!
[RoadRUNNER] - Pot Holes, Sink Holes, and Buckled Roads Ninjette Newsbot Motorcycling News 0 August 26th, 2014 03:01 AM
Is the stock clutch lever compatible with the ex500 clutch perch? M42 1986 - 2007 Ninja 250R Tech Talk 5 August 21st, 2014 08:24 PM
Brake/Clutch lever perch bolts Shaol1n Monk Motorcycle-related 0 January 31st, 2012 03:09 PM
