Old December 21st, 2013, 06:32 PM   #1
rasta
Your face
rasta's Avatar
F*cking frustrating
I'm in the middle of mounting my tires and I can't get them completely mounted. I can get 75% on just fine, but the last part is being a stubborn little bitch. Any tips for finishing up?
Old December 21st, 2013, 06:35 PM   #2
it is a problem on the opposite side. you must squeeze the lips to the inside of the wheel, away from the outside where they try to bead up. they need to be centered in the middle to be able to get the last edge on the rim. remember lots of windex. once the last edge is on you can let them out from the center and let them bead up
Old December 21st, 2013, 06:36 PM   #3
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Make sure you're keeping the bead on the opposite side pressed all the way down into the center of the rim.
Lube.
edit: Alex.s beat me to it.
Be patient.
BTW I picked up a very cool tool at the motorcycle show....
http://www.beadbuster.com
Old December 21st, 2013, 06:36 PM   #4
bruce71198
bruce71198's Avatar
If your working at home without good equipment my suggestion is pleanty of lube. Liquid dish soap is my go to in a pinch. Lots of it.
Old December 21st, 2013, 06:37 PM   #5
Whatever you do, don't put too much force and dent the soft edges that seal against the wheel.
The opposite side of the circle should always be completely in the central-deeper part of the section of the wheel.
This is the best helper that $10 can buy:
Old December 21st, 2013, 06:38 PM   #6
bruce71198
bruce71198's Avatar
You guys are quick
Old December 21st, 2013, 06:39 PM   #7
adouglas
adouglas's Avatar
Consistent, too!
Old December 21st, 2013, 06:42 PM   #8
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
:whatalldemsaid:
An I use dish soap
Old December 21st, 2013, 06:43 PM   #9
dish soap leaves a sticky residue. alcohol based windex evaporates cleanly
Old December 21st, 2013, 06:46 PM   #10
JohnnyBravo
The residue washes off, and cleans the rim... I may have to try this window washing solution
Old December 21st, 2013, 06:47 PM   #11
how do you wash off the inside of the rim after the wheel is on
Old December 21st, 2013, 06:53 PM   #12
rasta
Your face
rasta's Avatar
Wow, you guys are quick, you're girlfriends and wives must be proud
Seriously though...thanks I appreciate it. I'll go try this right meow. I'm either going to be relieved or my tire/wheel might fight itself thrown out a window
Old December 21st, 2013, 07:04 PM   #13
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
You could always have brought it over to RojoRacing's shop to have them mounted
Old December 21st, 2013, 07:05 PM   #14
old3
The advice above is the answer. The tire bead only fits over the rim when both of the other beads are in the drop center as much as possible.
Another method is the zip ty or strap method. You use 5-6 of them to pinch the beads together. A bit of lube and it just about falls on the wheel. A new idea I just heard today was to use electrical tape to do this. The guy said he uses about 3/4 of a $1 roll of cheap tape.
You cut away the ties or tape after. Really easy if you don't have a machine. Tubed or tubeless.
old3 is offline   Reply With Quote
Old December 21st, 2013, 07:39 PM   #15
rasta
Your face
rasta's Avatar
God dammit, I still couldn't get it
Plus..how the **** am I supposed to get a rim guard up there
Old December 21st, 2013, 07:43 PM   #16
old3
Opposite where you are levering, the tire bead is seated on the wheel, not in the drop center. If it is hard to lever it on, you are doing it wrong. It is all about the bead on both sides, not huge effort. It should just about slide into place.
Old December 21st, 2013, 07:44 PM   #17
old3
How are you holding the wheel? If you are fighting it, get a 5g pail and set it on that at least.
Old December 21st, 2013, 08:09 PM   #18
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
If you would just quit taking all those road trips all over the world and tend to your tires!!! JK
If I understand your problem its getting the tire bead up and over the wheel rim. How I do it is to use some pieces of junk plastic ( from a cut up oil bottle ) as my rim protectors. I insert them where I plan to pry and so that I can gradually get the tire mounted. The plastic strips are easy to remove an place where you need them. Use some lube as suggested above. You are almost there , you are just stuck at the point where you have to stretch the tire the most to get it on. If you need a hand, let me know and I'll be happy to help you get 'er done.
235 MPG Hypermotorcycling to a better tomorrow
greenaero is offline   Reply With Quote
Old December 21st, 2013, 08:14 PM   #19
JohnnyBravo
Ya wait till its off again... Not like anyone can see the goo on the inside
Old December 21st, 2013, 08:48 PM   #20
rasta
Your face
rasta's Avatar
Turns out I put them on backwards in the first place like a chode, so I have to dismount them again. Now that's being a bitch. So that's all for today, I think a couple hours of failure is enough for one day. Time to drink some smoke some, then back on the horse tomorrow.
Great learning experience I guess
EDIT: So I refused to end the day with the dismount stumping me, so I gave one more try. Got it dismounted, and tried to mount it again, but hit the same wall.
Old December 21st, 2013, 08:56 PM   #21
old3
Try the tape trick. You will be amazed.
Old December 21st, 2013, 08:59 PM   #22
old3
http://www.youtube.com/watch?v=S6WPzRRJLpA
And he is doing it the hard way fighting the wheel on the ground!
Old December 21st, 2013, 09:29 PM   #23
God dammit, I still couldn't get it..........
The opposite edge is far from the center in those pictures; it cannot jump over that way.
It wouldn't stretch, there is a ring of steel inside.
http://faq.ninja250.org/wiki/Tire_Mo...Hints_%26_Tips
http://faq.ninja250.org/wiki/Mountin...tires_yourself
Use a couple of 2x4 to protect that brake disc from inappropriate loads as you fight the beast.
Old December 21st, 2013, 09:59 PM   #24
rasta
Your face
rasta's Avatar
Thanks Moto, didn't realize there was much more to do before I can even mount the tire
Old December 21st, 2013, 10:02 PM   #25
You are welcome, Wes
Please, check my previous post for a schematic that I added.
Avoid the valve for the area where the edge of the tire needs to seat deep in the groove.
Hope you will get it right tomorrow when fresh.
Old December 21st, 2013, 11:31 PM   #26
rasta
Your face
rasta's Avatar
I've noticed in a lot of videos/DIY I've looked at, people aren't really taking note of where they mount the tire. They're making sure that the tire is facing the right direction, but nobody is putting the lightest part of the tire at the heaviest part of the wheel. Is that something I don't really need to worry about?
Old December 21st, 2013, 11:44 PM   #27
I'm all for saving money when it also saves me time. But if you're anywhere near road rider, it takes 20 minutes to have them mount and balance both of those tires perfectly, at $20/pop.
Old December 22nd, 2013, 12:07 AM   #28
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
+1 on Road Rider. What was a few hours of struggle for me took those fancy machines almost no time at all. If you ride there though, you will have to remove the wheels yourself in the parking lot as they are not insured to work on bikes. They'll provide stands and tools.
Old December 22nd, 2013, 12:21 AM   #29
rasta
Your face
rasta's Avatar
Road Rider is 45ish mins from me, that's not too bad. I'm gona try the zip tie thing tomorrow and hopefully it works out as well it looks like it should. If not, I'd consider giving RR a try. Are they able to do it right when I'm there? Or would I have to make two separate trips...
Old December 22nd, 2013, 12:51 AM   #30
tfkrocks
tfkrocks's Avatar
They'll do it right then and there. You can even watch to see how easy it is with those fancy machines and then wish you had fancy machines too.
Old December 22nd, 2013, 03:41 AM   #31
KawiKid860
KawiKid860's Avatar
I know the frustration, had the same exact issue when mounting the only tire I've ever done. I ended up either scratching the rim too much or slightly tearing the tire because it doesn't hold greater than 32 psi anymore either lol...
Say where do you guys get those rim protector things? I made my own and well obviously they didn't work too well :P
Old December 22nd, 2013, 06:55 AM   #32
adouglas
adouglas's Avatar
Are you fighting your tire irons?
Take a look at what this guy is doing with the strings attached to his rim protectors when he mounts the tire... skip forward to 5:15
Old December 22nd, 2013, 07:32 AM   #33
Yes, I noticed that your wheel had weights before having the tire on.
You don't have to do it, but you may end up adding more weight than needed for balance, which translates into a little more rotational inertia for accelerating, braking and flicking the bike.
I enjoy doing these things, so I balance the naked wheel first and internally mark the heavier spot, which will never change for future replacements.
Then, I use that reference to place the dot on the side of the tire.
The rim protectors can be any sturdy deformable sheet; I cut mine from milk or juice jugs.
If you don't have plenty of lubricant, patience and inclination to do it without damaging the sealing edge of the tire ......... or your fingers, taking it to some professional shop is a great idea.
Old December 22nd, 2013, 05:37 PM   #34
rasta
Your face
rasta's Avatar
I should have started with the zip tie trick....took me 10 mins to do
Old December 22nd, 2013, 05:58 PM   #35
JohnnyBravo
Comgrats
Old December 22nd, 2013, 06:34 PM   #36
greenaero
greenaero's Avatar
Great!!!
Old December 22nd, 2013, 07:32 PM   #37
adouglas
adouglas's Avatar
Did the zip ties scratch your rim at all?
Old December 22nd, 2013, 10:18 PM   #38
rasta
Your face
rasta's Avatar
Ummm I didn't think of that. I didn't notice anything too bad other than scratches that were already there. I'll have to take a closer look
Old December 23rd, 2013, 12:42 AM   #39
i just squeeze the tire with my hands instead of zipties. but maybe i have abnormally strong hands. it must be the excessive masturbation.
Old December 23rd, 2013, 12:57 AM   #40
rasta
Your face
rasta's Avatar
Yeah, I tried squeezing with my hands, but I couldn't squeeze it hard enough. Oh well, I guess I can start masturbating more if it'll help me change tires and all
[motogp.com] - Crutchlow: “It is frustrating not to be on the front row" Ninjette Newsbot Motorcycling News 0 April 11th, 2015 05:30 PM
Misplacing/losing stuff, frustrating subxero Off-Topic 25 December 2nd, 2014 08:48 AM
Somebody loosened all the f*cking fairing bolts on my 250 Lil_Green_Demon General Motorcycling Discussion 45 December 6th, 2011 06:55 AM
Frustrating searching for a used bike OddlyOrdinary General Motorcycling Discussion 27 October 3rd, 2011 03:09 PM
After a long frustrating day.... DarkNinja52 General Motorcycling Discussion 15 October 9th, 2009 09:00 PM
