Old March 31st, 2009, 11:41 PM   #1
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
Fairing repair and special paint stuffs...
Hey guys...
I've got a couple of questions. My fairings came damaged and I've done a little to help them along in that respect (bottomed her out trying to get her into the back of the truck to take her to the shop when my clutch cable broke and bad choices/inexperience with a tube of loctite my dad thought was glue and I didn't know to say NO! ). I was thinking for a while that I would just replace the fairings (which is insanely expensive, as you all probably know). A friend of mine suggested I repair them with fiberglass. Anybody have experience with this? I need to know what to do and how to do it correctly so my bike doesn't end up coming out looking like some sort of hunchback of notre-dam 250!
Also, I plan to repaint those spots I'm repairing, and do several touch-ups on other areas of the fairings that are scratched. I allready bought the upper paint layer (CP blue is fricken' EXPENSIVE! $90 a quart!!! Really have no idea why I spent that much, but I like my stuff lookin' real purty! ), but was wondering if anybody had specifics on what kind of primer I should get. I figure it should be some sort of light blue or something, but I have no idea where to look for the exact type to get.
Another question is to those of you that have experience painting bikes. I plan on getting Fury airbrushed after the touch-ups and then re-clearing the entire bike. Are there certain types of paint I should avoid? I don't want another solvent-problem like I had with the loctite. Is regular automotive paint ok? The paint I got for it from my local paint shop is automotive paint and I told him I needed it to be ok on plastic to keep it from melting, but I'm not completely sure his english was good enough to understand me! Any/all help is greatly appreciated.
P.S. Alex, I wasn't sure whether to put this in a tech talk or farkles section, as it could apply to both styles of bike. Move it wherever!
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old April 1st, 2009, 01:47 AM   #2
Syphen
Some weird Canuck!
Syphen's Avatar
Motorcycle(s): '92 CBR250RR "Babyblade", 2008 Ninja 250R, 2001 CBR600F4i
Yikes! Body work is something that can take a lot of experience. Plastic work takes even more then metal. Are your fairings cracked or just scuffed up?
Lets say that they are cracked (you mentioned damaged), you can get a good quality adhesive called 'plastic weld'. You can then fill the crack with this glue, use it to re-enforce the back of the damage spot if needed. You can also V-out the cracks and pull the bits really tight together to make sure they are seating good. Once this is all done and dry you sand the area, tape off/mask off the good stuff, prime, paint and clear coat. I recommend finding someone who has done it before. I would only ever attempt repairs on something MYSELF if the entire peice was being repainted. To just do a touchup and blend in requires considerable talent. If there is a pearl in the paint it can add to difficulties.
Sorry if my post seems a little convoluted.
I still like CBR's more Just kidding.
Syphen is offline   Reply With Quote
Old April 1st, 2009, 03:21 PM   #3
Verus Cidere
No worries!
The big problem is that the area we messed up with the loctite is around the windscreen (my dad thought it would hold those bolts in, so we tried it and it melted the fairings. An example of the lack of experience you were talking about! ). There are actually a couple of places where there's no fairing any more at all. More specifically, the top left bolt and the corner of the fairing it attaches to literally broke off. The bottomed out section is mostly cracks, but there's a chip missing from that too. I do have someone who's worked with fiberglass before, but again, I need a little more info to be sure we do this right. Hope that helps!
Edit -- Anybody think I should take it to a professional body shop for this? Or would buying new fairings be cheaper?
Old April 1st, 2009, 03:48 PM   #4
Syphen
Some weird Canuck!
Syphen's Avatar
It sounds like you have quite a bit of damage and from the sounds of it you might want to consider buying new body work. Can you post some pics of it?
Old April 1st, 2009, 05:16 PM   #5
sometimesido
sometimesido's Avatar
Motorcycle(s): 2006 250R
wtf....I did NOT know those front upper's are so damn expensive.
Piece of plastic...
Yea, post up some pics.
my flickr™
sometimesido is offline   Reply With Quote
Old April 1st, 2009, 07:09 PM   #6
P1NDLESK1N
P1NDLESK1N's Avatar
Motorcycle(s): 2015 Ninja 300 (Sold), 2016 Z1000
Originally Posted by sometimesido View Post
wtf....I did NOT know those front upper's are so damn expensive...
Yeah these front uppers are prone to be damaged at some point in the bikes life. It's real hard to find even used ones cheap.
P1NDLESK1N is offline   Reply With Quote
Old April 1st, 2009, 07:24 PM   #7
sometimesido
While Michael takes his sweet time posting pics...
If I ever have to replace mine, I might even try to fabricate a mount to put 08+ body work.
my flickr™
Old April 1st, 2009, 09:42 PM   #8
Verus Cidere
Hehehe.... Don't expect pics overly quickly guys. I don't have a camera. I'll try to bum my Aunt's tomorrow though so I can get pics of the places I'm needing to play with.
Old April 1st, 2009, 09:44 PM   #9
you don't have a cell phone w/ a camera?
Old April 1st, 2009, 09:54 PM   #10
Verus Cidere
I'm a wierd teenager. I don't have a cell phone. Period. My family is feeling the economic crappyness right now, and I'm actually the only one that ever has any extra money, so if I want a cell phone, I have to pay for it myself. As of right now, I don't think I'd use it enough for it to be worth it, but times like this are starting to prove me wrong.
Old April 1st, 2009, 10:37 PM   #11
props to you.
i thought every teenager was born with a cell phone attached to their ear. it's refreshing to find one that doesn't.
Old April 1st, 2009, 10:42 PM   #12
Verus Cidere
Hehehehe.... I know how that goes. It's kinda funny when I show up to things and people say to turn off cell phones, I don't and they look at me like I'm defying them. I tell them I don't have one and they look at me like I'm insane or something! But then again....maybe I am?
Old April 4th, 2009, 03:31 PM   #13
Verus Cidere
Ok guys. I hijacked a freinds camera for the weekend and I've got pics of the damage. The worst one is around a bolt in the windscreen. Lemme know if you think it's saveable!
This is a different bolt on the other side of the windscreen.
This is the damage to the side of the fairing. The area on the first one has been fixed as best as can be expected by superglue.
These are pictures of the damage to the bottom fairing.
This is the bolt while it's still connected.
This is the bolt when taken off.
This is what it looks like when the bolt is missing.
This is on the right side of the front fender fairing/forks.
Old April 4th, 2009, 04:39 PM   #14
Nemy
Nemy's Avatar
Motorcycle(s): 2009 SE Ninja 250R
Well generally I think anything is fixable. But something of this magnitude is going to take a LONG time! So you'll have to weigh that in when you factor in the fact that the bike will be out of commission for that period.
I didn't notice any gaps/holes, so if it's just cracks you can plastic weld them or bond them to make sure they don't spread any further, but I wouldn't recommend superglue. I don't think they're rated for high speed/vibrations/exposure to env. elements and it won't give you a good finish that you can sand and prime later on.
What I used on my fairing was Plastex (www.plastex.ca). It's retardedly strong, smells like cr@p , easy to sand, and it comes with a flexible mould that you can use to rebuild those broken tabs/bolt mounts. Once that's done, you'll have to sand it flush working your way through the grits, prime, sand again, paint, wet sand, clear coat, wet sand again, then finally polish like you've never polished before. That's as much as I know as well lol because I'm still workin on mine... The windshield, though, I haven't seen done before. I guess you could still patch and paint it over....
Good luck if you do decide to take it on, it is fun and quite the challenge
Nemy is offline   Reply With Quote
Old April 4th, 2009, 04:56 PM   #15
sometimesido
That looks fixable with plastic welding.
my flickr™
Old April 6th, 2009, 10:08 AM   #16
zeroth
weekend rider
zeroth's Avatar
Motorcycle(s): '05 Ninja 250
Tim are you going to put together a DIY on your plastex repair? It seems like an interesting product ... especially the mold. If it's easy to work with, I might pick some up for an upper fairing crack I inherited. It's at the upper right corner just aft of the windscreen, and I'd need to support it somehow. If I could use the mold to space the fairing properly and then pour Plastex onto it...
zeroth is offline   Reply With Quote
Old April 6th, 2009, 11:54 AM   #17
Nemy
Nemy's Avatar
Well I'm working on a smaller section right now that is already primed and covered up. I do have a camera at my disposal now, though, so I might be able to do a DIY for the next part I wanna do. But at the rate I'm going it might not be done for awhile
Anyways, the mould is great! It'll mould to anything you want, then peel right off when the plastex sets. Just watch out about drips etc., cause they don't come off easily
Old April 7th, 2009, 07:23 AM   #18
zeroth
weekend rider
zeroth's Avatar
Cool thanks for the tip. It will probably be awhile (weeks, if not months) before I get around to it, so I'll await your DIY eagerly.
Old April 16th, 2009, 11:41 PM   #19
Verus Cidere
Any word on the base coat for CP blue? I found some possible fairing replacements that are on the cheaper side, but they're white and I already have the replacement paint for the blue (gotta keep my bike the fastest color! ) I need the base coat and the primer for it, then I'll buy the fairings and have them painted, then airbrushed finally. I just don't wanna pay over $100 for the colorrite stuff. Anybody know codes or anything for the primer/base?
Edit -- I just thought of this... Would it be kinda cool to do a little front-to-back two tone with the perfect CP blue and a CP blue without the base? I'd still have the airbrushing over it, so that'd hide the unprofessionality of it all a bit. Thoughts?
Old April 17th, 2009, 08:53 AM   #20
Nemy
Nemy's Avatar
Here's your base and paint for CP blue. Good luck with the project. Mine's gone on 2 months now trying to get it perfect... but im also a slacker
http://www.colorrite.com/matrix-colo...TOKEN=38101733
Old April 17th, 2009, 10:26 PM   #21
Verus Cidere
Ok, so the base coat is listed as #1345 on colorrite. A quart of base coat is $200 though! I got a color match for cp blue from a paint store here that was only (haha ONLY ) $90 a quart. Do I still need the base? If so, is the 1345 a color code for it or just the part number from color rite? I don't want to pay $200 a quart!
Old April 18th, 2009, 12:12 AM   #22
Nemy
Nemy's Avatar
i don't know how much a quart is and way too tired to look it up but I would think you only need a couple of spray bomb's worth - I would say about 1 per fairing and you have 3, from what I can tell, that need to be repaired. So maybe a 1/2 pint or pint?! Dunno how much that equates to either
The 1345 should simply be colorrite's code but they make strictly OEM paint matches. So if you had your paint matched somewhere else you might have to check with them to see whether a base is even required... but you might also want to do a spray test anyways to ensure it is the exact same color code
Ninja 300 Special Edition - Only a paint job? Christofini 2013 - 2017 Ninja 300 General Discussion 7 July 31st, 2013 07:07 AM
paint and fairing repair qs crazymadbastard 1986 - 2007 Ninja 250R Tech Talk 2 May 29th, 2013 09:42 AM
[visordown.com] - Suzuki special edition paint schemes Ninjette Newsbot Motorcycling News 0 March 8th, 2013 04:10 PM
Touch up paint repair help cuong-nutz General Motorcycling Discussion 4 May 16th, 2012 10:29 PM
[sportrider - latest stories] - Yamaha unveils special one-off paint scheme for Ben S Ninjette Newsbot Motorcycling News 0 November 4th, 2009 11:10 AM
