Old April 4th, 2009, 03:51 PM   #1
Rynownd
Rynownd's Avatar
LED Signals and Fender Chop
So, I bit the bullet and took a Dremel to my fender. Before doing this I purchased some LED strips from http://www.radiantz.com/. I can't link directly to the product I purchased, but I can tell you they're called 'Flexible LED Array.' You can choose the size in multiples of 5 LEDs; I decided on 25. The whole assembly with the 'D' Tube and end caps is about 4 inches long. They come with adhesive backing, so you just peel and stick.
I wanted them to go on the plastic to the right and left of the seat, so I had to drill a tiny hole in the the fender to run the wires. I also had to use silicone in the end caps to seal the water out. I put some around the hole where the wires run as well. I forgot I was going to need some resistors to get them to blink, so right now they just come on and stay on... resistors should be in on Monday.
All in all it wasn't a bad project, but due to crap weather and a lack of tools, the whole thing took about a week. But, yesterday one of the grad students in my office let me barrow his Dremel so I could chop that fender. By going nice and slow with the cutting wheel, wire brush attachment, and sander, it came out quite clean IMO. Used a SS L-bracket to mount my LP to the under side of my taillight... no LP light yet.
Anyway, the whole point of all this is the pictures, so here they are!
1
2
3
4
5
6
8
9
10
11
13
14
15
16
17
18
19
20
Ok, so I posted way too many pictures. Oh well! Tell me what you guys think!
PS Proton flushmounts are on their way; I'll post another 100 pictures when I get those on.
http://www.southparkstudios.com/clips/224099
Last futzed with by Rynownd; April 5th, 2009 at 05:28 PM.
Rynownd is offline   Reply With Quote
Old April 4th, 2009, 04:02 PM   #2
CRXTrek
FORMER MOTORCYCLE RIDER
CRXTrek's Avatar
I've been waiting for someone to post up the Protons installed on a 250
Old April 4th, 2009, 04:05 PM   #3
Rynownd
Rynownd's Avatar
Not sure when they'll be here... definitely this week sometime. If the weather doesn't suck, which it will, I'll have them installed and get some pictures next weekend.
Old April 4th, 2009, 04:18 PM   #4
Nemy
Nemy's Avatar
Motorcycle(s): 2009 SE Ninja 250R
clean! Good job/choice with those leds, 25 is nice and bright
Nemy is offline   Reply With Quote
Old April 4th, 2009, 04:23 PM   #5
Shift250R
Shift250R's Avatar
Motorcycle(s): 08 Ninja 250R
Nice. That looks real clean and barely noticable until they light up. good job.
Shift250R is offline   Reply With Quote
Old April 4th, 2009, 04:41 PM   #6
Rynownd
Rynownd's Avatar
Thanks for the compliments guys!
I'm gonna put her to bed and go get drunk with my friends haha
Old April 4th, 2009, 04:45 PM   #7
randomwalk101
self wrencher
randomwalk101's Avatar
Great job!!! Very clean fender job. I like the signal a lot too
Old April 6th, 2009, 10:03 AM   #8
SpyderGirl
3 for street, 2 for dirt
SpyderGirl's Avatar
Motorcycle(s): 2008 Can Am Spyder PE #1344 / 2009 Kawi KLX140L Monster Energy / 2009 Kawi Ninja 250R (RIP 8.23.09)
That looks great. Good work!
Feel free to look me up on facebook.
SpyderGirl is offline   Reply With Quote
Old April 6th, 2009, 12:05 PM   #9
djindia23
Ride or Die Ninja
Motorcycle(s): Blue Ninja 250R (the fastest color)
ryno.... that is sick... i think im gonna look into those LEDs now... they look really nice good job!!!
djindia23 is offline   Reply With Quote
Old April 7th, 2009, 04:29 PM   #10
Rynownd
Rynownd's Avatar
The lights are officially 'blinkers' just needed some more resistance. I used the following product to get them blinkin':
http://cgi.ebay.com/ebaymotors/ws/eB...m=250400195010
Protons still aren't in, but New Enough says they're shipped. Can't wait...
Old April 7th, 2009, 07:11 PM   #11
LeftoveRRice
Motorcycle(s): 250r 09
Do you know how many ohms are on that resistor?
LeftoveRRice is offline   Reply With Quote
Old April 7th, 2009, 07:16 PM   #12
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
Wow, those LED strips do a bloody good job. Great cut mate.
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
Old April 7th, 2009, 09:29 PM   #13
Rynownd
Rynownd's Avatar
I don't know how many ohms the part I bought is. However, when I was testing a few things, I left one of the stock lights installed and wired some resistors I had laying around into the other LED signal. First thing I learned: Resistors don't work in series for this application. Second thing I learned: a 15 ohm resistor (wired in parallel) will get those lights blinking. I tried 1 ohm, 5 ohm, and 15 ohm.
15 ohms wired in parallel works.
I didn't just wire up the resistors I had because they were literally burning up as I tested them. The ones I was using were some lightweight junkers I had from class. This application requires something more robust. Also, the part I purchased off ebay came with some in-line splice connectors as well as a protective cover and mounting bracket for the resistors.
Old April 7th, 2009, 09:33 PM   #14
Rynownd
Rynownd's Avatar
Thanks again for the compliments!
Old December 26th, 2009, 08:44 AM   #15
blackRod
blackRod's Avatar
Motorcycle(s): Honda DIO2 trike; 2010 Ninja 250R
Hi! Is that a 150/60/17 on the rear?
TIA
Regards
blackRod is offline   Reply With Quote
Old December 26th, 2009, 08:48 AM   #16
mike_sema
mike_sema's Avatar
Motorcycle(s): ninja 250r
looks nice and clean
08 250R: sportisi VR full exhaust, Dynojet, custom seat, kleen air rmvd, rim tape, grips, fender chop,zg db windscreen,k&n air filter,15t front sprocket,sportisi-usa clipons,solo seat cowl
mike_sema is offline   Reply With Quote
Old December 26th, 2009, 08:52 AM   #17
Snake
Snake's Avatar
Nice clean look. I like the led turn signals.
Rear Fender Chop and Moved Turn Signals Today Renner 1986 - 2007 Ninja 250R Farkles 28 April 15th, 2012 07:20 PM
Rear Fender Chop and Moved Turn Signals Today Renner 2008 - 2012 Ninja 250R Farkles 1 April 8th, 2012 05:52 PM
$15 ZX-6R LED Flush mounts/integrated tail mod/mini-mirrors & fender chop =) speedgsx98 1986 - 2007 Ninja 250R Farkles 9 March 27th, 2011 10:19 PM
FS: Fender Eliminator 250r 2008+ w/ LED signals & LED plate light CUT 35$ shipped jonthechron Motorcycle-related 9 November 5th, 2010 07:43 AM
