Old February 23rd, 2014, 07:17 AM   #1
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
no spark ???
I have a good one going on. I put the new motor in and have no spark. I can't wait to find the answer. But in the mean time its ....let's learn all about the ignition time.
First off the whole writing system is not stock.. no kickstand switch or starter cut out. I also have a BRT ignition. But I swapped in an 88-94 cdi and still have no spark.
Tried different coils.
I have power on the red wire to both coils.
If I connect a lead to the coil and tap ground the coils spark.
I checked the pickup. 114 ohm. And cranking it has 3to6 volts ac fluctuations while cranking.
I checked grounds on black yellow wires. And .made sure the pick up is not shorted to ground.
I checked voltage to the ICU and have lights on the ICU.
I also made sure the battery is fully charged and holds 12 v while cranking.
The bike ran before I pulled the other engine out. I really don't want to pull the motor and swap the other one out.
Any ideas?
Worlds fastest 250 ninja
Old February 23rd, 2014, 09:10 AM   #2
Racer x
Racer x's Avatar
I tried swapping over a stator and pick up from another engine. Nope.
Now I have a 1988 250 Ninja. Going to test it and compare. I am baffled at this point. One thing I noticed. I have 12 volts at the battery while cranking but only 10.7 at the coils. Both ignition modules do the same thing.
Old February 23rd, 2014, 10:27 AM   #3
Racer x
Racer x's Avatar
OK I found that the green black wire on an 88-94 ignition module is grounded. On the 08 its hot or at least the gray wire is hot. Once I grounded the Green black lead I had spark with the 88-94 module. I guess my BRT RTis is bad.
Anyone know of an adjustable ignition module??
Old February 23rd, 2014, 06:18 PM   #4
cuong-nutz
cuong-nutz's Avatar
have you messed with Jetting Pro any?
Cheetah-Power is another indonesian option as well.
HalfFast Racing Team
Old February 25th, 2014, 09:08 PM   #5
mgentz
Board Member
JettingPro or BRT-is are the only ones I know
spark plugs jcsalazar 2008 - 2012 Ninja 250R Tech Talk 11 May 17th, 2015 08:44 AM
Removing spark spark plugs? tsdexter 2008 - 2012 Ninja 250R Tech Talk 3 June 26th, 2013 03:48 PM
Why no spark? Flying Pig 2008 - 2012 Ninja 250R Tech Talk 12 January 30th, 2012 01:13 AM
95 with no spark... maynard 1986 - 2007 Ninja 250R Tech Talk 1 January 3rd, 2011 01:55 PM
Spark plugs Betlog 2008 - 2012 Ninja 250R Tech Talk 2 March 1st, 2010 10:59 PM
