Old July 1st, 2014, 05:05 PM   #1
cuong-nutz
cuong-nutz's Avatar
How to remove the carbs
Remove the side fairings.
Remove seat.
Remove gas tank.
Remove the bracket where the rear of the gas tank bolts too.
Remove the allen bolt on the right side of the gas tank bracket.
Remove the allen bolt on the left side of the lower air box right next to where the airbox drain is.
Remove the a bolt from the coolant reservoir tank and it out of the way to access carbs.
Remove left and right fairing brackets from the frame.
Remove choke and throttle cables.
Loosen all 4 carb boots FROM JUST THE CARB BODIES. (You'll need a long #3 allen wrench and a phillips--Technically JIS screwdriver but a phillips will work if you're careful.)
Slide airbox rearward.
Carefully pull carb out from left side. It's going to be a tight squeeze but it'll come out.
Hope that helps.
HalfFast Racing Team
Old July 1st, 2014, 07:10 PM   #2
Another way to remove the carbs.... Soujyu 2008 - 2012 Ninja 250R Tech Talk 6 August 26th, 2013 12:36 PM
New Video: How to remove the carbs on a pregen n4mwd 1986 - 2007 Ninja 250R Tech Talk 13 August 21st, 2013 08:08 PM
remove and reinstall carbs - stock airbox red 2008 - 2012 Ninja 250R Tech Talk 22 July 16th, 2013 07:09 PM
Easiest way to remove carbs? chadh92 1986 - 2007 Ninja 250R Tech Talk 22 April 9th, 2013 06:59 PM
Howto: Remove carbs in under 10 mins [Video!] TheDuck 2008 - 2012 Ninja 250R Tech Talk 39 January 11th, 2013 10:04 AM
