Old July 15th, 2014, 07:01 AM   #1
DCMoney
DCMoney's Avatar
Cheap eBay 415 Chain
I purchased a 415 kit from Aftermarketcycles last month and decided to also buy a cheap eBay 415 chain to test and see how long it will last, carrying the DID chain that came with the kit with me.
This is the chain I'm taking about. http://www.ebay.com/itm/415H-MOPED-C...2dcd49&vxp=mtr
Installed for 2 days of track days in June with 2 races. Then also this past Saturday plus a race, finally Sundays first afternoon session the chain broke.
Had roughly 375 miles on the chain. Not buying another, sticking with DID for now.
MCRA.com
Old July 15th, 2014, 07:22 AM   #2
soonerbillz
Motorcycle(s): 2003 Ex250
After much discussion my choice was a DID 520...
I have heard and seen of too many chain failures in the 428-415 camps...
I need all the help I can get in keeping my large mass moving... Besides..
I really want to hear from those using the 428-415 set ups.. do you really notice an appreciable increase in performance with them?
soonerbillz is offline   Reply With Quote
Old July 15th, 2014, 07:34 AM   #3
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
If I ever decided to race, i have a better chance of winning the lottery, i would look into a 415 chain. does it offer that much weight reduction?
TEAM ALFALFA
www.apexassassins.com
Old July 15th, 2014, 07:37 AM   #4
rc racer
rc racer's Avatar
Motorcycle(s): 2015 R3, 1969 CB160, 2002 TTR125, 2007 KX250F
I have been running a 415 Tsubaki HD chain for 2 race days and 3 track days at this point. I chose the Tsubaki since it is supposedly stronger than the DID equivalent but weighs a little more and does not look as good since its black instead of gold.
So far I have no issues to report and have not even needed to adjust it yet. Still have the 1.5" of slack that I originally started with. But I keep a keen eye on it and keep it clean and well lubed. Also have a spare with me at all times.
I did not notice a huge difference with it since I was already using a non 0-ring 520 chain when I first set the bike up for track duty. Even the heavy 520 chain spun really free since it was a non-oring so I think that is where most of the improvement it. That and theoretically since it moves with your swing arm the suspension should work better as well. Its probably one of those things that are more noticeable if you go back to a heavy o-ring chain after running the light set-up for a while.
I am no lightweight either. Without gear I tip the scales at 245 lbs. so the chain definitely gets a workout.
rc racer is offline   Reply With Quote
Old July 15th, 2014, 07:38 AM   #5
DCMoney
DCMoney's Avatar
If your racing on the cheap stick with 520 non-oring and get a rear aluminum sprocket, think I paid $30 for mine and the weight savings was noticeable between the OEM and the AL one.
With the guys I'm racing against I need every single weight savings, I can get. I don't think any of the other guys running 415 chains have had the chain fail when using the DID.
I ran the cheap chain to evaluate it to see if it was a viable option against the $80 DID chain. Which its not.
MCRA.com
Old July 15th, 2014, 07:48 AM   #6
soonerbillz
Yepper.. thanks for the points !
I am running the DID o ring and a steel 45 tooth with the stock 14 up front... I'm not worried about speed at this point as I have skills learning as my goals right now.. When I get more comfortable with the bike and confident with my tracks skills I move toward more refinement of the bike for performance.. that's why didn't go crazy on the motor build.
The chain/sprocket set I bought was a sale thing, got it cheap and figured it was good enough to get on the track with for now...
Did buy another 15 front and a alloy 44 for the rear... think I should have went with a 46 instead...
Old July 15th, 2014, 07:49 AM   #7
DCMoney
DCMoney's Avatar
Thanks for the info, will have to find one of the Tsubaki chains and give it a try!
MCRA.com
Old July 15th, 2014, 09:12 AM   #8
rc racer
rc racer's Avatar
I got my first one as a 415 set with sprockets from www.speedmotoco.com
They conveniently provide a long enough section of Tsubaki chain with 2 master links to make it work on the ninja 250. I don't think the chain is listed on their website that way but a quick email or phone call and they'll line you up.
The 415 chain normally only comes in 120 link lengths
Old July 15th, 2014, 01:59 PM   #9
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
I'd rather not have my chain snap and destroy my engine or my leg. Don't cheap out on chains.
Xtina is offline   Reply With Quote
Old July 15th, 2014, 09:32 PM   #10
Knolly
Motorcycle(s): Daytona 675
Found a photo of you:
More seriously, I had never even heard about the Tsubaki chain, thanks for the info! My chain is about at the end of its life so I'm thinking I'll upgrade to a 415 setup while I'm replacing it.
Knolly is offline   Reply With Quote
Old July 16th, 2014, 05:36 AM   #11
bruce71198
bruce71198's Avatar
I run the 415 kit from Speedmotoco or After Market Cycles, I don't remember what one, any how I was curious to see how long the chain would last so I ran it till it broke, three race seasons is what I got out of a good chain. For maintenance I would take the chain off, clean it and store it in a gallon anti freeze jug half full of oil when I wasn't using it. A lot of oil would fling off the chain, kind of messy but not enough to make it dangerous.
Old July 16th, 2014, 10:55 AM   #12
DCMoney
DCMoney's Avatar
Good info, thanks!
MCRA.com
Old July 16th, 2014, 11:30 AM   #13
salcuta88
salcuta88's Avatar
Motorcycle(s): 2011 Ninja 250R (Sold), 2015 Rocky Mountain Soul (Runs on fat)
Why would you put a bycicle chain on a motorcycle? It clearly shows a bycicle with a small engine on it.
salcuta88 is offline   Reply With Quote
Old July 31st, 2014, 10:26 AM   #14
skeelo221
Motorcycle(s): Ninja 250R (race), Aprilia Tuono 1000R, CRF250X, DR650
I'm running the same from speedmotoco. Great service from that shop.
I don't like the Tsubaki master link, though. The end plate does not simply insert over the pins, you have the press the end plate on. Not a big deal except for when you go to remove the master link I needed to press the pins out (which makes it a pain).
skeelo221 is offline   Reply With Quote
Old August 1st, 2014, 05:25 AM   #15
green_bread
green_bread's Avatar
Motorcycle(s): Ninja 250R & CBR250R
Because 520 chains are overkill for a 250 and the weight savings is pretty substantial when talking about rotating mass. When racing, you go for every bit of weight savings you can.
green_bread is offline   Reply With Quote
Old August 1st, 2014, 05:58 AM   #16
red26
Motorcycle(s): Ninja 250R, GSXR600 K4, KX250F,NSR150SP, Yamaha TZM150
And to think the 600 & 1000cc also use 520 chain despite their power and weight
red26 is offline   Reply With Quote
Old August 1st, 2014, 10:34 AM   #17
salcuta88
salcuta88's Avatar
Well, it broke!
Old August 4th, 2014, 01:57 PM   #18
green_bread
Well, it broke!
Because it was a cheap chain. A good quality/well maintained 415 chain should hold up to anything these little bikes can throw at them.
Old August 5th, 2014, 12:00 PM   #19
fred smoot
fred smoot's Avatar
Motorcycle(s): 1996 Ducati 900SS/SP 45k miles
chain life . . . .
usually, you get what you pay for!
'09 Ninja 250R track only SOLD
"If everything seems under control, you're not going fast enough." -Mario Andretti
fred smoot is offline   Reply With Quote
415 chain conversion kit aschika1 2008 - 2012 Ninja 250R Tech Talk 57 June 2nd, 2014 10:24 AM
possible chain for 415 conversion people subxero 2008 - 2012 Ninja 250R Tech Talk 8 March 13th, 2014 06:36 AM
Is 415 Chain Setup Better? krolinked 2008 - 2012 Ninja 250R Tech Talk 1 July 19th, 2012 05:40 PM
415 chain conversion question 675Raisinator Ninjettes At Speed 45 April 17th, 2012 12:40 PM
415 GP chain conversion tim61 2008 - 2012 Ninja 250R Tech Talk 13 September 6th, 2011 01:19 PM
