Old July 27th, 2014, 02:43 PM   #1
amad1972
Motorcycle(s): 2006 Honda ST1300, 2001 Ninja 250
Valve adjustment, carb clean, carb sync?
Hi everyone,
I just bought a 2001 Ninja 250 yesterday. I have had a couple of them before, but haven't done much work on the other ones. This one has just under 16,000 miles on it and I have no idea about the past maintenance. I changed the oil today and adjusted the clutch cable. The bike starts and runs really well. When it is warm and idling, it will sometimes increase to about 1,500 rpm and then settle back down to about 1,000 rpm. When riding it hard, it seems to want to bog a little starting at about 8,000 rpm, but it continues to climb...just not as quickly. Would you think these symptoms would be because of a needed valve adjustment, carb cleaning, carb balance, or all three. I am fairly capable of doing all of these on my own.
Thanks
amad1972 is offline   Reply With Quote
Old July 29th, 2014, 08:08 PM   #2
amad1972
I adjusted the valves this evening. 3 of the 4 intake valves were significantly too tight and 3 of the 4 exhaust valves were significantly too tight. I adjusted them all back to spec. I haven't had a chance to start it yet, because I am waiting on a couple of spark plugs to come in tomorrow at the parts store and am then going to balance the carbs before putting everything back on. Adjusting the valves wasn't too bad. Definitely easier than doing it on a Suzuki Boulevard M50 I used to have.
Old July 29th, 2014, 09:42 PM   #3
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Good job! pictures of your bike?
Be careful. Remember you are
invisible
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped menikmati Motorcycle-related 4 April 8th, 2020 12:39 AM
Valve adjust and carb sync... jgcable 1986 - 2007 Ninja 250R Tech Talk 20 July 14th, 2014 09:20 PM
carb sync WELLS 1986 - 2007 Ninja 250R Tech Talk 4 September 19th, 2013 08:30 PM
Engine noise and delayed throttle response after valve adjustment and carb clean gdvd 2008 - 2012 Ninja 250R Tech Talk 27 January 6th, 2013 04:54 PM
Help please - carb sync? nixthewiz 2008 - 2012 Ninja 250R Tech Talk 4 September 7th, 2011 06:37 PM
