Old May 11th, 2009, 05:17 PM   #1
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
DIY: 600 Mile Service
I am attaching as a word doc file the DIY that I wrote for the 600-mile service. It isn't complete right now, as it still needs the pictures added in, but it has been raining here and I haven't had a chance to add them in. I can refer you to the appropriate pages in the service manual if you need to see the pics, and I will edit this post when I get the pictures added in
I would copy the text into the post, but it's long and would get broken up, and right now there are dynamic links contained within the document.
EDIT: Pics now included!
Last futzed with by noche_caliente; May 31st, 2009 at 07:07 PM. Reason: Swappped out file for version with pictures
Old May 11th, 2009, 05:41 PM   #2
NJD022588
NJD022588's Avatar
Motorcycle(s): '09 Ninja 250R
Just kidding! Looks good!
Way better than spending a couple hundred at the dealer
NJD022588 is offline   Reply With Quote
Old May 11th, 2009, 06:02 PM   #3
Lars
Motorcycle(s): 2010 Ducati Hypermotard 796 (red)
Looks great! Thanks!
Lars is offline   Reply With Quote
Old May 11th, 2009, 08:41 PM   #4
py2e
py2e's Avatar
Motorcycle(s): 2009 BLACK Kawasaki Ninja 250R
Just in time for me!!!!!!!
py2e is offline   Reply With Quote
Old May 11th, 2009, 08:47 PM   #5
islanderman7
The Sexy Filipino
islanderman7's Avatar
Motorcycle(s): Ninja 250R 2008 (da black one)
Thanks for this. In for a 7500 mile DIY. jk.
Area P CF Standard,Airbox Removed,K&N R-0990,Factory Pro Jet Kit 3.0, Zero Gravity DB
I'm not riding too fast... I'm flying too low.
islanderman7 is offline   Reply With Quote
Old May 11th, 2009, 09:42 PM   #6
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Nice work Kim - can't wait for the full version with pictures.
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old December 3rd, 2009, 12:05 PM   #7
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Thanks! This is a good guide help to make sure I go over everything.
About to use it right now!
ninja250 is offline   Reply With Quote
Old December 3rd, 2009, 06:29 PM   #8
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Whew now I know why they spend a few hundy at the dealer for the 600 mile service! lol
I still need the huge sockets for the steering bolt, swingarm bolts and axle bolts! My jixxer axle sockets didn't fit. Also need new cotter pins to adjust the wheelbase (chain slack). Will have to look up/find the sizes on those sockets.
Need to get some spiffy extensions and another ratchet to hit both sides of all the engine mount bolts but I got them as best as I could for now. I've had engine mount bolts come lose in an Integra before and know how bad that feels vibration wise.
As always the plastics were a million times harder to get back on than they were to fall right off.
The rear brake pedal pivot bolt is kinda scary on this bike and hard to get to. I'm gonna pull it back out and loctite it. I forgot how crazy working on bikes is.. you get to see how they're barely held together! I guess that's why it's good to give a hefty pre ride check before every trip out. Seems like you can't be thorough enough!
Sorry to bump an old thread
Anything you guys and gals can think of not on that list that is a common area in need of attention?
Old December 3rd, 2009, 07:18 PM   #9
check the shifter lever and the rear brake light switch adjustment... 2 things that need to be carefully watched on this bike.
Old April 22nd, 2011, 09:20 AM   #10
kawac
Kawic
Motorcycle(s): ninja 250 08
Thank you so much KIM this is amazing.
kawac is offline   Reply With Quote
Old July 27th, 2011, 09:34 PM   #11
Merc250r
Motorcycle(s): 2011 Yamaha FZ6R
Amazing
Merc250r is offline   Reply With Quote
Old July 29th, 2011, 12:41 PM   #12
DarkNinja52
DarkNinja52's Avatar
Motorcycle(s): Red 09 Ninja 250r aka Sheila (RIP), Red '10 Ninja 250r aka Sasha (Sold), White '13 Ninja 300 (To be Purchased)
NICE!
SO should i attempt this.. or pay $200 for the stealership to do it??
I looked over it and it seems like its a tad bit out of my mechanical skill level...
DarkNinja52 is offline   Reply With Quote
Old July 29th, 2011, 05:26 PM   #13
noche_caliente
AJ- I'm a girl, and this is my first bike... I had no problem doing it and writing the DIY... ymmv...
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old July 29th, 2011, 05:33 PM   #14
Snake
Snake's Avatar
aj, it is realy very easy and after you are done you will have the satisfaction of knowing exactly what oil and filter was put in and that everything was tightened to spec. With the steelership you never realy know. The first time may take you a while but after that your confidence will grow and the next time it will be quicker and easier.
Old July 30th, 2011, 11:47 AM   #15
DarkNinja52
Would it be absurd for me to say I think i'm going to have the dealer do everything, then I'll check over their work on my own using the DIY?
The bike has been sitting around for a while without use before I bought it and my only concern is that they'll catch something that I wouldn't have noticed, either as part of the 600 mile service, or something that I never wouldve even noticed unless i was more experienced.
I really rather not give the stealership my money, but I didn't buy the bike new off the lot, it sat in someones garage for a while before I got it.
You think they would let me watch them work on it? or is that a big no no?
Old July 30th, 2011, 01:18 PM   #16
Snake
Snake's Avatar
It is perfectly acceptable to let the dealership the servicing for you. This DIY just gives you the option to do it yourself. Since the bike has been sitting for a while letting the dealership do the service will let you start with a clean slate and possibly do some of your own maintenance in the future. Watching the dealership will not be an option due to their insurance liability.
Old July 31st, 2011, 06:17 PM   #17
DarkNinja52
Thanks Snake!
Old September 4th, 2011, 05:46 PM   #18
C L
Motorcycle(s): 2014 300
What does "free play" mean in relation to the inspections? such as
• Check the throttle grip free play.
C L is offline   Reply With Quote
Old September 4th, 2011, 05:55 PM   #19
Cuongism
Cuongism's Avatar
Throttle grip free play is how much the throttle grip can turn before it engages the cable. You should be able to turn your grip 2-3mm back and forth before it engages. If it's more than 3 mm and you need to know how to adjust it, let me know
Old September 4th, 2011, 06:12 PM   #20
C L
Ah how obvious.. lol
coming up on 600 miles here and I'm just reading through the .doc and making sure I know everything
Another question, does it void my warranty if I do it myself?
Old September 4th, 2011, 08:24 PM   #21
No. But keep receipts of any supplies you buy for it, and keep a notepad of the services themselves to show that there is some documentation for it being done.
Old September 6th, 2011, 11:41 AM   #22
GreenNinja
GreenNinja's Avatar
Name: I'm a ninja!
Motorcycle(s): 2009 Ninja 250
You DIY writers are awesome!!!
GreenNinja is offline   Reply With Quote
Old September 6th, 2011, 04:19 PM   #23
noche_caliente
Old October 8th, 2011, 02:24 PM   #24
Cwat6363
Motorcycle(s): 2009 Kawasaki Ninja 250J (Black)
is this link still working? everytime i click on it it asks me to log in again, and tells me im not able to view this page.
Cwat6363 is offline   Reply With Quote
Old October 8th, 2011, 03:28 PM   #25
Seems to be working fine. Log out of the site. Close your browser. Come back to the site, log in, and see if you still get an error.
600 mile service akcalhoun 2008 - 2012 Ninja 250R Tech Talk 8 July 14th, 2012 07:48 PM
600 mile service? beqwarrior 2008 - 2012 Ninja 250R Tech Talk 10 November 4th, 2011 07:10 AM
Is the 600 mile service necessary? Lil_Green_Demon 2008 - 2012 Ninja 250R Tech Talk 41 August 28th, 2011 10:49 AM
600 mile service. tinng321 2008 - 2012 Ninja 250R Tech Talk 7 June 8th, 2009 03:23 PM
600 mile service next week. py2e General Motorcycling Discussion 8 April 28th, 2009 09:36 PM
