Go Back   ninjette.org > General > Off-Topic
Old September 9th, 2014, 03:15 PM   #1
3d printing moto parts
https://imgur.com/a/OtNOW
Old September 9th, 2014, 03:29 PM   #2
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Oh now that is cool.
Have you seen this?
http://jalopnik.com/this-3d-printed-...-fo-1632152953
<-- Linky
Old September 9th, 2014, 03:53 PM   #3
M42
Wrench wench
M42's Avatar
Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS
Man, I can't wait till 3D printing becomes commonplace.
M42 is offline   Reply With Quote
Old September 9th, 2014, 04:15 PM   #4
EternalNewb
EternalNewb's Avatar
Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar
^This. Very much this.
EternalNewb is offline   Reply With Quote
Old September 9th, 2014, 06:04 PM   #5
Cool! But plastic key? really?
Old September 9th, 2014, 10:30 PM   #6
iamjacob
iamjacob's Avatar
Motorcycle(s): 2011 250R SE
2 things...
1. When I was younger I remember spare keys that were for emergency use only that were plastic and housed in a credit card sized slip that fit in your wallet. Definitely not for long term use but usable.
2. some VERY expensive 3d printers can print more than just plastic. The one in the photo is probably plastic though.
iamjacob is offline   Reply With Quote
Old September 10th, 2014, 03:02 AM   #7
snot
sammich maker
snot's Avatar
MOTM - Apr '15
How about ...
http://www.businessinsider.com/i-3d-...-great-2013-12
AR lowers
Last futzed with by snot; September 10th, 2014 at 11:47 AM.
Old September 10th, 2014, 10:24 AM   #8
NevadaWolf
NevadaWolf's Avatar
Something went goofy with your link...
<-- Linky
Old September 10th, 2014, 10:35 AM   #9
there are 3 main types, extruders which are typical plastic or food. these are very inexpensive and readily available today.
stereolithograph stenciling -- or SLA --, which projects an image onto a vat of epoxy... the uv light in the projected image cures the different areas of the epoxy. this is much more accurate but messy and more expensive. this is what shapeways prints with typically.
the cool **** is whats called selective laser sintering -- called SLS -- it uses a really strong laser to literally weld tiny bits of metal together, layer after layer. this is what spaceX uses to produce rocket engine parts. you can use powders of titanium, aluminum, magnesium... many options. and because of the way it is made, you can create elaborate "impossible" structures that cannot be created any other way that provide ideal strength to weight in ways that you simply cannot do otherwise. the patents on these machines are just running out this year, so the very first consumer SLS machines are becoming available now (around 3 to 5 grand) but next year a bunch of things expire so expect a small consumer grade SLS machine to be around 1500 by the end of next year.
by the end of next year you should be able to pick up a basic consumer 3d printer for around $200
Old September 10th, 2014, 01:14 PM   #10
SLS is boss! Ever seen that **** in person?!?
I guess I never thought of keeping a plastic key as an absolute last resort. I still would do everything in my power to not need it though. What if it breaks in the lock? Can't use a magnet to get it out
Old September 10th, 2014, 02:36 PM   #11
you could melt it out
Old September 18th, 2014, 07:18 PM   #12
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Or melt it in
Old September 18th, 2014, 11:46 PM   #13
inuendo?
Old September 20th, 2014, 06:57 AM   #14
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
I've 3D printed some parts at work for my builds, but they're only used for mock-ups and to check fits.
Subframe support brace 3D Printed and it fits!
The real parts.
k-os is offline   Reply With Quote
Old September 20th, 2014, 10:19 AM   #15
Rapid prototyping, yo!
Those look good.
Old September 21st, 2014, 06:23 PM   #16
Soujyu
That guy is probably printing his bolt covers with ABS, judging from the tape he uses on his build plate. I would not put ANYTHING 3D printed ANYWHERE near a hot area, like his engine, because it WILL melt.
Old September 21st, 2014, 06:54 PM   #17
You can use tape with PLA. I do. Not necessary, but it works well to release your part.
Old September 23rd, 2014, 06:56 AM   #18
Soujyu
That tape that I'm seeing on those pictures seems to be specific to folks using ABS.
And yes, I definitely use tape when printing with PLA.
Old September 23rd, 2014, 07:31 AM   #19
what tape? kapton tape? blue painter tape?
Old September 23rd, 2014, 04:56 PM   #20
Soujyu
The pictures I see on the imgur links provided look like kapton tape, which is typically used for ABS. The blue painter tape is typically used for PLA.
Which reminds me, I need to get some more blue tape.
Old September 23rd, 2014, 05:19 PM   #21
i'm pretty sure its more like...
kapton tape is used by people who heat their bed above 130C...
and painters tape is used by normal, sensible people, who don't have money burning through their wallet...
Old September 23rd, 2014, 05:27 PM   #22
ally99
Ninja chick
ally99's Avatar
Motorcycle(s): '13 Ninja 300
MOTM - Dec '13, Feb '15
Badass!
Postwhores are COOL! ~Allyson
Old September 23rd, 2014, 06:03 PM   #23
Soujyu
If we have a 3D printer or access to one to make good use of it, we already have money burning through our wallets.
Now, granted I use my 3D printer for costuming and not for motorcycle parts, so printing with PLA is more than enough for my needs.
Old September 23rd, 2014, 11:17 PM   #24
i spent under 300 for my printer so...
Old September 23rd, 2014, 11:41 PM   #25
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
The machine shop at the community college I went to has a 3d printer and anyone is open to use it. My physics project group had some project components 3d printed for free. I've also heard of open workshops that have 3d printers available among their many tools and machines; all you need is to pay the membership for use of the workshop. 3d printers are becoming a lot more accessible.
My Ninja 300
Old October 1st, 2014, 12:58 PM   #26
Soujyu
I ended up getting my own 3D printer after breaking printers in various community workshops.
Personally, considering most of my prints take about 10-20 hours of printing, and I can't really hog a community printer for that long.
Old October 1st, 2014, 05:08 PM   #27
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Which one did you get? I just picked up the XYZ da vinci 1.0 Seems like a nice printer for the $$$ so far.
Old October 2nd, 2014, 01:38 PM   #28
i'd love to hear what you think of it
Old October 2nd, 2014, 03:38 PM   #29
ninjamunky85
Que Buenos Son!!!
MOTM - Nov '14
Well I've only had it for a day, but so far I really like it. For the price I think it's probably the best way to get into 3D printing at home. The finish quality of the parts isn't perfect but I didn't expect it to be at this price. The parts are quite strong though and the build time seems to be rather short. BTW I bought mine on-line from MicroCenter then picked it up at my local store.
Pros:
Initial quality and finish of the unit looks good. It come packed securely and all moving parts are taped up, some with supports.
Set up is easy. I had my unit printing a demo part in <15 minutes from un-boxing.
It looks cool. I especially like the clear enclosure and bright LED light for the work area.
Parts print relatively quickly and are surprisingly strong (even at 5% density).
Build area of 7.8 in cubed. Bigger than other printer in the price range.
Heated glass bed makes the parts easy to remove once cooled, and the glass bed doesn't have to be replaced like the plastic beds (which is just stupid).
It comes with 300ft of filament. That's not a lot I guess, but it actually lasts longer than you might think. The spool has a chip in it that tracks the amount used. This lets you know how much plastic is left, and the printer won't start a project if there isn't enough plastic left.
It makes noises that sound like a futuristic printer mixed with an old school arcade game.
Cons:
Parts definitely don't come out smooth especially at lower quality/shorter build time selections.
It's kinda noisy, I guess
Reliability may be an issue. Only comes with a 30 day warranty
The filament cartridge has a computer chip on it that track the plastic used from that spool. This is their way of forcing you to but spools from XYZ that are more expensive. (there seem to be several work arounds to solve this issue)
This isn't the first time I've used a 3D printer also, as I've had access to the one at school for a few projects. Compared to the one at school it seems to be just about as good for a lot less $$$. The one at school is a few years old though and I think might have a few more features.
Old October 3rd, 2014, 06:43 PM   #30
damn DRM
Old October 15th, 2014, 05:31 AM   #31
Soujyu
I've got a Makerbot Replicator 2.
It works really well for what I do with it, and I can take apart the extruder if it clogs.
Old October 15th, 2014, 05:48 AM   #32
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
@alex.s I ended up getting a Prusa i3. I've pretty much had constant problems with it.
Old October 15th, 2014, 07:01 AM   #33
you should know better by now than to listen to me
Old October 15th, 2014, 07:25 AM   #34
DCMoney
DCMoney's Avatar
I printed prototypes for my captive spacers before machining them.
Also a few other things I use to help me such as a fork height tool.
Printed a 38mm ring at 12mm thick, place it on the fork tube above triple, make everything flush and boom height of fork set in seconds...
Yeah nothing special but when your rebuilding 4 sets of 250 forks that extra minute setting the height on each fork adds up. Also have 11mm 10mm and 13mm rings for testing other fork heights.
MCRA.com
Old November 6th, 2014, 01:10 PM   #35
Old November 6th, 2014, 03:47 PM   #36
NevadaWolf
NevadaWolf's Avatar
Now that's an interesting idea.
<-- Linky
Old November 7th, 2014, 02:38 PM   #37
TnNinjaGirl
Ms. Personality
@alex.s Got the Prusa figured out. She's printing some pretty nice stuff now.
Printing parts for a Kossel as we speak.
Old November 7th, 2014, 03:02 PM   #38
deltas are much better anyway
Old November 12th, 2014, 07:49 AM   #39
TnNinjaGirl
Ms. Personality
They're bigger and I hear bigger is better
Shapeways 3d printing eddiekay General Motorcycling Discussion 8 July 17th, 2014 08:33 PM
[motorcycle.com] - MV Agusta To Manufacture Racing Parts With Help From Yakhnich Moto Ninjette Newsbot Motorcycling News 0 March 19th, 2014 01:52 AM
3D printing Joshorilla Off-Topic 176 February 27th, 2014 02:22 PM
Parts for the 250/300 from Xlite Moto DaBlue1 General Motorcycling Discussion 3 April 23rd, 2013 10:55 AM
Help! Where to find moto parts and services?? cool_hand_luke_12 General Motorcycling Discussion 2 July 11th, 2011 09:17 PM
