Old June 4th, 2009, 05:45 PM   #1
jdkvice
Shift Problems
2009 250, 3k miles. I sort of noticed from the time I bought the bike until now some shifting issues. I've read about the "false neutral" between 5th and 6th, I dont seem to get that. My problem always lies when I'm at a stop, and downshifting with the clutch in. Many times my shifter just feels like jellow and wont actually "click" down. I have to release the clutch just barely engaging it, pull the clutch back in then it clicks down fine. On rare occassions I have to do the process for every gear, say sitting at the light downshifting from 3rd to 1st. More recently, If I pull the clutch in, click up into neutral, and try to click to first its either jellow, or will engage far enough for the N light to go out, but Im actually in no gear when I try to move. Sometimes it will make it into 1st, but after about 6 feet it slips to neutral. So basically if I click to N, I have to release the clutch, pull it in, then it cleanly goes down to first. The bike is still under warranty, just didn't know if there were some adjustments I should look at myself, possibly something silly. On a side note, I've been doing the oil changes / lubes myself, does that void the warranty?
Thanks,
Justin
jdkvice is offline   Reply With Quote
Old June 4th, 2009, 06:49 PM   #2
c_anglada
c_anglada's Avatar
when down shifting i always engage the clutch and let the bike roll for a bit before i down shift again. try doing that for every gear before you come to a complete stop and that should help. you should be in first gear when stopped
c_anglada is offline   Reply With Quote
Old June 4th, 2009, 06:50 PM   #3
bob706
bob706's Avatar
Are you using synthetic or conventional oil? I found with regular dino juice shifting was sometimes a pain.
Old June 4th, 2009, 07:51 PM   #4
check your clutch cable adjustment.
Old June 4th, 2009, 08:16 PM   #5
jdkvice
Im using conventional oil, and I do try to engine break whenever possible. Every once in awhile your just stuck in a higher gear and must stop.
I will check out the clutch cable in the morning Kim. Although, shouldn't I be able to sit still, click to N, then back to first without releasing the clutch? What would cause it to "miss" first? As I said, if I release the clutch, bring it back in, I can click to first perfectly.
Old June 4th, 2009, 08:28 PM   #6
Motorcycle trannys are a bit different from cars. The bike should be moving when shifting gears. if what you are saying is that you can't shift gears while standing still, try rocking the bike forward or back when you are trying to shift when at a stop. I always try to be in the gear I want to be in when I come to a stop.
also, when is the last time you changed your oil?
Old June 5th, 2009, 04:38 AM   #7
jfauerba
Motorcycle(s): '09 Red Ninja 250r
I use to experience this problem a lot. The key to fix this is to shift all the way down to 1st before you come to a complete stop. You can keep the clutch in the whole time while shift down. Otherwise, once you stop, it will get hung up on some gear while trying to go down to 1st. If you come to a stop and you are not in 1st, when it hangs and will not shift down any more, release the clutch so it just starts to grab, (friction zone / rpms drops slightly / hear the gear engage) and then pull the clutch back in and start the going down the gears again until you are in 1st or it hangs again (repeat process).
jfauerba is offline   Reply With Quote
Old June 5th, 2009, 06:24 AM   #8
jdkvice
Fresh oil, 300 miles. Thanks for the tips / advice guys. I guess I was just at a misunderstanding. I didn't realize on a bike you need to shift like that. My thinking was you could sit and click through all the gears. Ah, clutch cable was good. More engine breaking coming from now on. Thanks.
Justin
Old June 5th, 2009, 06:42 AM   #9
tinng321
tinng321's Avatar
Motorcycle(s): 08 black 250r (sold); '09 black zx6r
I usually have to roll the bike forward a bit to shift into 1st from N.
tinng321 is offline   Reply With Quote
Old June 5th, 2009, 06:44 AM   #10
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
doing your own maintenance won't void warranty. you should keep your receipt for oil and filter (write mileage down on them as well). Sometimes when stopped the teeth of the gears just line up tooth to tooth, when moving they will click in tooth to gap much better.
Old June 5th, 2009, 08:54 AM   #11
tlhamon
tlhamon's Avatar
Motorcycle(s): None Yet
I experienced the same thing after a long ride. Felt like there was a spring pushing back up from 1st gear. Tried a few things to get it to engage. Like slipping the clutch in 2nd. Not sure if it's just a matter of not meshing or the plates spinning to fast. Like was said, a wet clutch is a different animal than a dry clutch on a car, so the oil may be the culprit. Also, that first gear has got to be giagantic since it is almost useless. I remember having a similar issue with an old tractor that was geared about the same (1 mph in 1st gear was maxing it out).
It's not worth doing if you aren't completely stressed out about it.
tlhamon is offline   Reply With Quote
Old June 6th, 2009, 05:28 AM   #12
ScorpionNinja
ScorpionNinja's Avatar
Hi!
Yea sometimes this kinda thing happens to me and Ninja Nate (yes my bike has a name now!)
From what i can tell, downshifting on a motorcycle, your Supposed to be moving as you downshift, pulling in clutch,etc!
My Dad had a 72 or 73 Honda 350, and told me he had the Gears do this sort of thing on him too!
I notice it mostly if your in NEED of a SUDDEN STOP! ie: the Car in front of you, just Jams on the brakes too a Full stop (im 4 secs behind but still) and you dont have time really too downshift Gear by Gear... just Pull Clutch in, use Front/Rear brakes evenly... and Stop.... then your Stuck in a Matrix zone, and cant get her into 1st or any gear!
Yes it seems too work for me best... if i were too walk the bike foward or back (while clutch pulled IN fully) and step down, untill back in 1st.
Old June 6th, 2009, 10:27 AM   #13
Dave,
Have you taken the MSF course?
Old June 6th, 2009, 11:05 AM   #14
CANTFUNCTION
CANTFUNCTION's Avatar
Motorcycle(s): 09 ninja 250(red)
What is the matrix zone?
CANTFUNCTION is offline   Reply With Quote
Old September 11th, 2009, 05:57 AM   #15
Jerry
Jerry's Avatar
Motorcycle(s): 2007 EX250
Most bikes I've had are hard to shift while still.
Usually, just a little clutch friction between shifts will help get you from gear to gear.
You don't have to move the bike, just touch the friction zone.
Jerry is offline   Reply With Quote
Old September 11th, 2009, 02:30 PM   #16
killerkay3
killerkay3's Avatar
Motorcycle(s): 2009 Yamaha R6 / 2008 Green Ninja 250 (Sold)
yea, like if your in 6th gear and come to a complete stop and try to shift down, it doesnt quite work unless your moving a bit
killerkay3 is offline   Reply With Quote
Old September 11th, 2009, 03:10 PM   #17
HKr1
IC2(SW)
HKr1's Avatar
Thats a bad spot to be in......
http://www.gadgetjq.com/transmission.htm
Old September 11th, 2009, 07:37 PM   #18
killerkay3
killerkay3's Avatar
yep happened to me once when i first started riding
Old September 12th, 2009, 04:20 AM   #19
mxnello
Motorcycle(s): 2009 Ninja 250R 'Blue'
Shifting woes
Synthetic oil helps a ton, but as I have said before the 250R gearbox is not the smoothest. Which is fine as long as it wears well, no woes!
mxnello is offline   Reply With Quote
WTB: New gen shift linkage + shift knuckle + Woodcraft rear sets 675Raisinator Items Wanted 1 July 30th, 2012 05:59 PM
Can't shift up Moto126 2008 - 2012 Ninja 250R Tech Talk 10 November 16th, 2011 11:43 PM
Problems...maybe ya'll can help bobguy 2008 - 2012 Ninja 250R Tech Talk 34 October 3rd, 2011 02:37 PM
when to shift kn250 2008 - 2012 Ninja 250R Tech Talk 5 September 19th, 2010 09:27 AM
