August 8th, 2009, 02:44 PM | #1 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
DIY - GPS Tether
After modifying Headshrink's Erector-RAM GPS mounting solution for my Garmin Street Pilot C508, I decided there was too much of a possibility of the GPS vibrating off the Arkon mini-ball stem (See first picture below). So, I decided to come up with a "tether" and hoped someone else had already found a solution. Yesterday, I did a search via Google and found these instructions:
http://www.gadgetjq.com/gps_tether.htm This afternoon, I went to Lowes and bought the following items: 1 Easy Release Key Ring @ $2 2 Feet of 1/16" Stainless Steel Cable @ $.50 I then stopped at Advance Auto and purchased: 1 Package of 10 Interior Connectors Double-Crimp (Dorman #84170) - $6. Since I already had a package of JB Weld on hand, I didn't spend money for it. The current mount: In the next picture, the white arrows show the insulation removed from the double-crimp connector (top) and an unmodified crimp connector (bottom). The yellow arrows show the crimp connectors installed on the Arkon mini-ball/RAM ball mount via the 1/16" cable (blue arrow). On the opposite end of the cable is the easy release key ring. The following picture shows the JB Weld (yellow arrow - still drying) with one of the crimp connectors embedded in the JB Weld and cable (blue arrow) running to another crimp connector with just a cable loop. The other end of the easy release key ring will be connected to the loop (whte arrow). Prior to sanding the mounting spot on the GPS, I had to peel off the Garmin Serial # label. I stuck it on the top rear of the GPS. Since the GPS came with a protective pouch, this adhesion spot allows for the cable/ring to fit within the pouch when removed from the bike. Last futzed with by g21-30; August 9th, 2009 at 03:49 PM. |
August 10th, 2009, 08:18 AM | #2 |
Join Date: Nov 2008 Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold) Posts: A lot.
Great idea. I was thinking about doing something like this during my ride this weekend, haven't had the chance to look into it yet. Thanks again Sam.
DIY: Adding GPS and Heated Gear / Battery Tender cable | Alex | 2013 - 2017 Ninja 300 Tech Talk | 23 | April 12th, 2013 05:50 AM |
What did you name your GPS? | Skippii | General Motorcycling Discussion | 6 | September 25th, 2011 01:07 PM |
DIY GPS mount installed | chitor | 2008 - 2012 Ninja 250R Farkles | 19 | July 7th, 2011 07:51 PM |
GPS + Ipod audio solution DIY | Scott1620 | 2008 - 2012 Ninja 250R Farkles | 11 | May 29th, 2011 05:20 PM |
Gps | jump | 2008 - 2012 Ninja 250R Farkles | 4 | July 27th, 2009 03:58 PM |
