Old August 10th, 2009, 07:28 PM   #1
Snake
Snake's Avatar
DIY - ZG Double Bubble Windscreen Installation
Tools:
1 #2 phillips screwdriver
1 long flat scredriver
super glue
1. Remove 6 phillips head screws located on the front of the windscreen. Caution: As soon as each screw is loose make sure to pull the screw foward at the same time that you are unscrewing them. This is so the plastic nuts do not fall back behind the gauge cluster. If this happens you will have to fish them out.
2. While holding the plastic nuts in place with a long flat scredriver place one drop of superglue between the outside edge of the plastic nut and the inside of the fairing. Let dry for at least 5 minutes before installing the windscreen. This is to keep the plastic nuts in place otherwise they will fall out of the holes while trying to tighten them.
3. Place ZG Double Bubble Windscreen in place and loosely start all 6 screws. After all 6 screws are loosely in place start to tighten them snugly but not overly tight from the bottom center working your way outward and alternating from left to right.
Thats all there is to it. The hardest part is keeping the plastic nuts from falling out. Now for some before and after pics.
Front before and after:
From behind before and after:
Size difference between the two windscreens. The ZG Double Bubble is aproxamately 1.5 inches taller.
Last futzed with by Snake; August 10th, 2009 at 09:48 PM.
Old August 11th, 2009, 06:02 AM   #2
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Nice job Snake! Want to go add it to the wiki where we have the install for the new gens?
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old August 11th, 2009, 07:17 AM   #3
Grn99Kawi
Grn99Kawi's Avatar
Motorcycle(s): 2000 Honda CBR600F4 (sold) 1999 Ninja 250 (sold)
'm really happy with mine too.. one thing that I have been going back and forth on.. would the DB look better if we were to put a new "Ninja" script on it just like OEM? Same size and place?
2000 Honda CBR600F4 Silver and Red
1999 Kawi Racing Green Ninja 250 sold
Grn99Kawi is offline   Reply With Quote
Old August 11th, 2009, 08:05 AM   #4
addy126
Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt
Looks much better than stock screen, great job Rick
addy126 is offline   Reply With Quote
Old August 11th, 2009, 08:21 AM   #5
addy126
Adam... I took the liberty to touch up the pic comparison of Ricks with a similar font style "Ninja" on the DB screen. You can better see whether you like the looks of it or not. My opinion..... looks pretty o.k. if you do go ahead and do it
Old August 11th, 2009, 10:55 AM   #6
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
I seriously need to get new fairings so I can get one of these and not worry that it'll fall off!
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old August 11th, 2009, 01:38 PM   #7
Snake
Snake's Avatar
I agree it does look better with the Ninja emblem on the new screen.
Thanks addy126.
Old August 11th, 2009, 01:41 PM   #8
Snake
Snake's Avatar
Yes I would like to add it to the wiki. How do you do that?
Old August 11th, 2009, 04:47 PM   #9
noche_caliente
Rick - Alex gives pointers on how to do it here: http://www.ninjette.org/forums/showt...highlight=wiki
Old August 12th, 2009, 04:28 PM   #10
ASecretNinja
ATGATT Squid Killer
ASecretNinja's Avatar
Motorcycle(s): '06 CBR600
I disagree with whoever agreed that the emblem looks better. I like it without any stickers.
ASecretNinja is offline   Reply With Quote
DIY: Puig Double Bubble noche_caliente 2008 - 2012 Ninja 250R Farkles 26 March 29th, 2014 05:05 PM
WTB: Double Bubble Windscreen Slono Items Wanted 1 March 24th, 2012 08:26 PM
DIY: Zero Gravity Double Bubble kkim 2008 - 2012 Ninja 250R Farkles 122 August 5th, 2011 02:26 PM
Double bubble windscreen? modrummer 1986 - 2007 Ninja 250R Tech Talk 9 May 18th, 2011 12:45 PM
ZG double bubble windscreen Ninja Nut Items Wanted 0 February 26th, 2010 08:52 PM
