Old August 11th, 2009, 06:48 PM   #1
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Lightbulb DIY: Relocating the rear turn signals
Copied from the wiki
I found that in using my Cortech sport tailbags, the location of the rear turn signals kept me from mounting them properly. In order to remedy this, I chose to relocate the signals, as I wanted to maintain visibility rather than just removing the signals.
The federal statutes state that the rear signals should be 9" apart at the center of the reflector. Perfect for me, mounting them on either side of the housing for the license plate light set them at exactly 9" apart from one another. My first step was to disassemble the rear of the bike and remove the tail section. This is covered in the DIYs on fender eliminators, so I won't get into that here. I have remarkably decided to keep my fender, and it came in handy for this mod.
After disassembling the fender, I traced the base of the stalk on the side of the license plate light mounting point. I then took a drill to start the hole and used a Dremel to finish cutting them out. Then I popped in the rubber grommet that served as a mounting point.
My last step was to reattach the signals and run the wires through into the tail section. Since there was a hole left where the signals had been, I took the red reflectors and attached them in that spot. We used a random washer we had sitting around to take up the space inside the hole and allow the reflector to be mounted without the bolt falling out of the larger hole.
Here are a couple of shots of the finished product: (thanks Sunny!)
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old August 12th, 2009, 03:40 AM   #2
CRXTrek
FORMER MOTORCYCLE RIDER
CRXTrek's Avatar
+1 Kim
That really makes the stock fender look good.
Kawi should've done it this way.
Old August 15th, 2009, 02:49 PM   #3
noche_caliente
I got some better pics of the tail today... they also show the LED bolts on the plate and the brake-light bar that I added.
Old August 15th, 2009, 04:17 PM   #4
g21-30
g21-30's Avatar
Kim, I like how it looks! Great Job!!
Old August 15th, 2009, 04:20 PM   #5
AnarchoMoltov
AnarchoMoltov's Avatar
Motorcycle(s): 2007 Suzuki GSX-R750
don't you have the integrated turn signal tail light???
AnarchoMoltov is offline   Reply With Quote
Old August 15th, 2009, 04:34 PM   #6
noche_caliente
does it look like I have it? While I organized the group buy, there were enough other folks who wanted one that I let them have it rather than keeping one for myself
Old August 15th, 2009, 05:15 PM   #7
AnarchoMoltov
That sux...But it was nice of u though..
DIY: VEX inspired LED turn signals (Picture intensive!) Kevin2109 2008 - 2012 Ninja 250R Farkles 28 September 24th, 2012 07:08 PM
DIY: Shorten stock turn signals Gorilla25 2008 - 2012 Ninja 250R Farkles 4 November 1st, 2011 02:26 AM
DIY: Installing Mirror-Mounted Turn Signals noche_caliente 2008 - 2012 Ninja 250R Tech Talk 5 June 28th, 2011 01:56 PM
DIY - Relocating the rear brake reservoir VeX 2008 - 2012 Ninja 250R Tech Talk 12 December 3rd, 2008 11:13 PM
Relocating rear directionals Sailariel 2008 - 2012 Ninja 250R Tech Talk 0 October 5th, 2008 06:14 PM
