Old August 10th, 2016, 03:37 AM   #1
Lap202
The Mechanical Noob
Aftermarket speedometer that works with cluster (2008)
So I bought and have been disappointed by a used speedometer that's 7 mph slow and has got stuck a couple times. There are too many miles on the ones online and I feel like unless I get something new, I'll be disappointed. Has anyone found a speedometer that wit minor modding would fit into the stock cluster (like how it looks)
Lap202 is offline   Reply With Quote
Old August 10th, 2016, 05:08 AM   #2
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
How much money do you want to spend? Koso RX-2N is awesome for our bikes because they make a plug and play kit, we're really lucky in that regard. If you get it directly from Koso, they will set the mileage for you.
Here's mine.
Old August 10th, 2016, 10:46 AM   #3
Lap202
The Mechanical Noob
How's it fit in the dash, any adjustments needed or does it slide right in.
Old August 10th, 2016, 11:53 AM   #4
ForceofWill
That mounting plate is made for the 250 by Koso, it literally bolts right in.
Old August 10th, 2016, 01:49 PM   #5
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Plus buying the plug n play kit along with the mounting plate ensures a simple swap to the upgraded gauge. Really easy install.
<-- Linky
Odometer works, speedometer stuck at 0 moonwalker 2008 - 2012 Ninja 250R Tech Talk 20 May 15th, 2016 07:13 PM
07 Ninja Speedometer Cluster ninjarider707 1986 - 2007 Ninja 250R Farkles 2 April 28th, 2015 03:19 PM
EX 250 Ninja gauges speedometer cluster james250ninja 1986 - 2007 Ninja 250R Tech Talk 3 October 16th, 2013 01:56 PM
2008+ speedometer gauge cluster $120 Bueller999 Motorcycle-related 2 July 1st, 2011 12:13 PM
