Go Back   ninjette.org > Marketplace > Motorcycle-related
Old September 4th, 2016, 07:08 PM   #1
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Ohlins gsxr rear shock
Might be selling my bike so i am putting most of the stock stuff back on and selling off the fancy bits.
Lets start at $350 shipped CONUS, + shipping anywhere else.
This works as a GSXR shock conversion but requires a little more modifications than the typical GSXR conversion, not for the faint of heart.
Shock is re sprung, ill get exact details, thinking it's an 8.8kg/mm spring i ended up going with.
Again works just like a typical shock conversion except you need to trim some of the lower bracing of the top shock bracket off See pictures. I think i ended up grinding it out until i had clearance. No guarantees, all i can say is it worked for me and i never had a problem and i have pushed the suspension on the bike about as much as one could. No signs of stress anywhere in that area, the bracket seems pretty beefy.
Everything in the pictures is included, everything you would need to do the conversion.
I ended up drilling the holes out on the shock to 1/2" Some other people have done the same and used the 12mm bolts with little to no problems. I was not comfortable with that so i bored the races out to 1/2" and used all 1/2" hardware. That is all included. Only thing you would have to do is swap the 3 races out with ones i provide, 2 in the linkage and one on the swing arm. Then use the dog bones i provide as well. Since the top shock bushing is drilled out to 1/2" you would either have to drill out the top shock holes on the frame to 1/2" or buy a new 10 or 12mm bushing for the shock to use the OEM 12mm bolt and holes.
This shock is slightly longer than the 250 OEM, not shorter like the OEM GSXR shock. Only longer by a hair at it's shortest length (adjustable) works well with OEM length dog bones. Bones included, holes r drilled out to 1/2"
That should about cover it. Summary, Everything included, you would need to trim shock bracket, drill out shock bracket hole or get different bushing. Everything else is swappable. You could also use the OEM races with 12mm bolts and your stock dog bones with the 12mm holes, you would need to source longer 12mm bolts though.
Note: might not be possible with stock air box
Link to thread
https://www.ninjette.org/forums/showthread.php?t=185283
any questions don't be afraid to ask
Old September 4th, 2016, 07:54 PM   #2
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
your timing couldn't be better...I'm at the limit of what the gsxr shock can do
lemme check the funds, I'm a bit drained since I just did a twin sprints race weekend
I'll also have to see if it works with the stock airbox since I need that
Old September 4th, 2016, 08:38 PM   #3
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
How much room/clearance did you have with the gsxr shock? I just know this one sticks out towards the rear a little bit more, how much?? Not sure, i can line them both up tomorrow and get some pictures for ya as i have an OEM gsxr shock laying around
Old September 4th, 2016, 09:15 PM   #4
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
From the look of the pics on your install thread I can trim the plastic more and it'll fit that way just fine
where would it come into contact with the air box though?
Old September 4th, 2016, 10:00 PM   #5
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
What you gonna do with your parts?
Old September 5th, 2016, 04:57 AM   #6
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
dunno, not sure if it would or not. I never had the air box in when i put the shock in so i can't remember where the airbox starts and stops. Just wanted to throw the thought out there that it might not fit with stock air box as i have no idea so do your homework before you buy
plus that preload adjuster is moveable. I just left it bolted to the shock. you could relocate it onto the frame somewhere back there more accessible and you would not have to trim as much off the back
Old September 7th, 2016, 05:15 AM   #7
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
a shot of the 2 gsxr shocks. The reservoir obviously sticks up a little further than the OEM one,
I can't remember where the air box stops in the back, it's been too long since I looked at a bike with the box in. The remote preload adjuster can be moved so that is not biggie.
On another note, I had a few better pictures but when I was loading them last night my dumb MacBook pro crashed for the 3rd time since we have had it and unfortunately it is now out of warranty.... hate that POS
Old December 20th, 2016, 11:12 AM   #8
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Still have this, bump with a price drop.
$300 shipped CONUS
Old January 13th, 2017, 08:19 AM   #9
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
$270 shipped
Old January 23rd, 2017, 07:57 AM   #10
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
$250 shipped
Old January 24th, 2017, 10:48 AM   #11
eulark
Motorcycle(s): 2003 Blue Ninja 250, 98 ZX6E, 06 ZX636
Wondering if I can make this work on my 636...hmmm....What is the length on this shock? You said longer than OEM right?
eulark is offline   Reply With Quote
Old January 24th, 2017, 11:59 AM   #12
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I am lucky enough to have some info about the shock in my paypal transactions
Here are details of the shock.
Ohlins SU503 Rear Shock Suzuki GSXR 1000 05-06
Old February 12th, 2017, 10:56 PM   #13
Stock gt
Motorcycle(s): 2011 zx10r, 2009 Ninja 250r, CRF 450R
Is this still available?
Stock gt is offline   Reply With Quote
Old February 13th, 2017, 05:31 AM   #14
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
yeah
Old February 28th, 2017, 08:02 PM   #15
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
$200 shipped
Old November 4th, 2017, 06:59 AM   #16
psych0hans
psych0hans's Avatar
I'll take it for 200 shipped.
Old November 14th, 2017, 04:41 PM   #17
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
deal never went through, still available
Old November 24th, 2017, 08:19 AM   #18
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Black Friday special?
Old November 25th, 2017, 08:45 AM   #19
cbreater
cbreater's Avatar
Motorcycle(s): 16' S1000RR, 04' CB919, CRF150/230, 07' 250R
DO IT!
cbreater is offline   Reply With Quote
Old November 25th, 2017, 02:12 PM   #20
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
PM me an offer
Old November 25th, 2017, 05:02 PM   #21
Z1R rider
Z1R rider's Avatar
PM sent
Old November 25th, 2017, 06:15 PM   #22
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
Originally Posted by cbreater View Post
DO IT!
The seller only has ONE, not the 8 that y'all need!
Dave Wolfe is offline   Reply With Quote
Old November 25th, 2017, 07:16 PM   #23
Z1R rider
Z1R rider's Avatar
Old November 30th, 2017, 06:42 PM   #24
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
After 14 months this is SOLD!
Old December 1st, 2017, 07:12 AM   #25
taz
taz's Avatar
MOTM - May '17
Well son of a gun that means i need to do work to my 300.
GSXR rear shock upgrade psych0hans Ninjettes At Speed 18 May 10th, 2024 08:45 PM
Have you tried a GSXR rear shock and an aftermarket offering? ninja2007 Ninjettes At Speed 49 February 5th, 2015 05:45 AM
New Ohlins rear shock available mania 2013 - 2017 Ninja 300 Tech Talk 12 March 14th, 2014 07:54 PM
Feeler GB ohlins rear shock for Ninja 250 krunkfoo Motorcycle-related 8 June 4th, 2012 01:13 PM
2005 GSXR 1000 rear shock jasle Motorcycle-related 0 February 19th, 2012 02:25 PM
