Old June 12th, 2017, 10:00 AM   #1
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
Z250 to 300cc Bore up
Havent started a thread in what seems like eons, ha ha...
Been so busy with work, family (we have a son whos almost 3, and another one due in Jan 1 2018!)
I sold my red Ninja 2009 back in 2013~ and then bought the Z250 in 2014.
Due to local regulations, bikes that are over 250cc are hit with an additional 70% taxes. So here yamaha, kawasaki, etc are all boring down their 300~320cc bikes to fit into the 250cc bracket.
About a month ago i finally finished upgrading the Z250 to a Z300.
Thats the day we started to taking the bike apart for the bore up kit~
About 3~4 weeks later i was doing my 2nd hard break in session.
did an oil change 50~ km after bore up, and then drove another 200~250 km before replacing oil, oil filter, clutch plates, and clutch springs.
The added torque caused the clutch to slip, and that wasnt feeling too good, ha ha...
Before the bore up i already had the full exhaust system, porting, power commander, and tuning done. But i was never quite satisfied, since i knew there was more to be had!
Even with the slipping clutch, the bike was a blast to ride. I did 200km trip in about 3 hours going across and around the island a little.
Just ordered a Ninja 300 Throttle body in the states, which a friend will bring back to Bali in Sept. So thats something interesting to look forward to. atm i still have the stock 28mm bore throttle body that comes with the 250cc version. while the 300cc bikes in the states have a 32mm bore.
Thats about all i can report on my bike
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer
Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield
Last futzed with by wayanlam; June 18th, 2017 at 08:15 AM.
wayanlam is offline   Reply With Quote
Old June 12th, 2017, 12:19 PM   #2
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
Oh that's cool. I think we only have the Z125 in the US. Congrats on the upcoming addition to your family.
Old June 12th, 2017, 04:27 PM   #3
Very nice!
Old June 14th, 2017, 02:17 PM   #4
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Did you simply use a OEM Ninja 300 cylinder bank and pistons to complete the job?
Old June 14th, 2017, 03:24 PM   #5
Zaph42
Zaph42's Avatar
If I had to guess, the compression was upped a bit. That's a nice power curve, a little more than what a stock 300 can get without engine work.
Old June 14th, 2017, 05:26 PM   #6
wayanlam
wayanlam's Avatar
no, we went up with a larger bore, while the oem 300cc actually has a different crank shaft and piston rod if im not mistaken, allowing for a longer stroke.
OEM 250cc: Bore/stroke: 62 mm X 41,2 mm
OEM 300cc: Bore/stroke: 62 mm × 49 mm
OEM 250cc cilinder stacked under the bore up kit
and some die by side comparisons:
if you put this bad boy into a oem 300cc bike, you would end up with like 356cc~
a friend actually told me to try source an oem 300 crank and piston rods if i wanted to go up even more, but i think ill leave it at 300, ha ha...
i haven't even put in the bigger throttle body yet, which should help in the top revs where the engine needs that extra little bit to breathe.
Old June 14th, 2017, 07:53 PM   #7
Wow, that's some really thin cylinders!!! About 3,5 to 4,0mm?
Old June 18th, 2017, 08:16 AM   #8
wayanlam
wayanlam's Avatar
Originally Posted by JacRyann View Post
thanks!
i didnt realise i had to only pate the video code, and not the rest, he he
Old June 19th, 2017, 06:22 AM   #9
sharky nrk
sharky nrk's Avatar
Ahh yes that is correct, the OEM 300 is through stroke not bore. What brand kit did you use? I assume its something common over there that we don't have in the states?
Old June 19th, 2017, 06:32 AM   #10
wayanlam
wayanlam's Avatar
The cylinder block is an OEM kawasaki block, bored out to the limit, and then a sleeve inserted and honed to fit a (i think OEM from some bike...) cylinder that is that correct size.
Im not sure of the Cylinder that was used because the company i bought the kit from CNC'd the info off, to keep that as propriety knowledge i guess.
i paid like $400~500 for that kit, plus labor to install, ported the intake and exhaust again, had it ported already on the stock cilinder, but it needed to go even bigger to allow for a good flow for the larger displacement. And then the whole process to tune the bike on the Dyno~
Old June 19th, 2017, 08:19 AM   #11
bruce71198
bruce71198's Avatar
67mm or 68mm?
Old June 19th, 2017, 09:44 AM   #12
wayanlam
wayanlam's Avatar
Originally Posted by bruce71198 View Post
67mm or 68mm?
Using a 67mm cilinder/bore
Old June 19th, 2017, 12:31 PM   #13
In U.S. you can do that easily too. Sleeves are commodity items used all the time in engine-building. You can get them from LA Sleeves or Darton or any number of suppliers in a variety of sizes. Machine-shops can also mill out block and install them easily as well. The difficult part is finding the proper pistons for the desired compression-ratio.
Wayan, do you know what the compression-ratio is after upgrade?
Have you done a compression-test?
Do you have photos of pistons?
Thanks.
Old June 19th, 2017, 04:25 PM   #14
wayanlam
wayanlam's Avatar
Thanks.
The CR is 12.8, up from the stock 11.3 my mechanic did a displacement measurement to check that.
I neglected to take a picture of the piston cause the brand/SN was removed, and it basically looked the same as most 4 port cilinder piston, lol
Old June 19th, 2017, 06:17 PM   #15
bruce71198
bruce71198's Avatar
Thanks.
Buy a used ZZR600 cylinder block off ebay, press the sleeves out and, with a little machining, you can press them in place of your current 250 sleeves. This will allow you to bore up to 68mm.
Old June 19th, 2017, 06:24 PM   #16
bruce71198
bruce71198's Avatar
actually you'd end up with 346cc. You would need 1mm more of bore (68mm) to get 356cc
Old June 19th, 2017, 06:31 PM   #17
Egads that's a lot of work for some sleeves when you can get them for $20/ea! I prefer flanged tops for strength and rigidity. Also helps sealing to have them shaved not flush, but 0.002" or so above deck.
http://www.jegs.com/i/Melling/689/CSL722/10002/-1
For boosted applications, I'd go for chromoly with a wider top-flange. Best if flanges butt up against each other and at corners for support.
Last futzed with by DannoXYZ; June 19th, 2017 at 08:05 PM.
Old June 19th, 2017, 06:44 PM   #18
bruce71198
bruce71198's Avatar
Egads that's a lot of work for some sleeves when you can get them for $20/ea! I prefer flanged tops for stretch and rigidity. Also helps sealing to have them shaved to be 0.002" or so above deck.
Actually its no more work than installing the sleeves you mentioned. And the ZZR blocks can be had for $50 used. This nets you 4 sleeves. Not to mention the 1.5mm of solid wall thickness it leaves with 68mm bore sounds like a win win to me.
300cc Supersport Class being added to World Superbike tgold Ninjettes At Speed 34 December 13th, 2017 12:06 PM
[cyclenews.com] - Issue 39: First Ride 2016 Suzuki RM-Z250, Big-Bore Naked Bike Compa Ninjette Newsbot Motorcycling News 0 September 29th, 2015 10:40 AM
[visordown.com] - BMWs 300cc single is imminent Ninjette Newsbot Motorcycling News 0 May 6th, 2015 05:20 AM
What petrol for Ninja 300cc SE new mataleo 2013 - 2017 Ninja 300 Tech Talk 21 January 20th, 2014 09:10 PM
My new Ninja 300cc SE mataleo Pictures 21 January 11th, 2014 09:41 PM
