#1 |
Ranger tom
Join Date: Dec 2017 Motorcycle(s): Ninja Gpx 250 Posts: 6
Bike won't crank - New battery
I just got a ninja 250 that had Ben setting for awhile I got a new battery poot it in the nutrol, oil and the middle tale light come on but when i het the ignishen switch nothing happeneds
#2 |
Hi and welcome Thomas!
Do you have- - FSM - field service manual with electrical wiring diagram? - multimeter? Please review this thread: https://www.ninjette.org/forums/showthread.php?t=307592 |
#3 |
Ranger tom
That was help full I'm about to go over to my papas to work on the bike I'm shore I'll have more questions this is my first bike
#4 | |
Join Date: Apr 2016 Motorcycle(s): 2009 Ninja 250r Posts: 109
This happened to me a while back:
https://www.ninjette.org/forums/showthread.php?t=300192 It ended up being a loose electrical connection (plug) under the gas tank, on the right side of the bike. From @Flying: Quote:
#5 |
Ranger tom
It was the starter solenoid but I found out that the carbarater is mixing my gas in to my oil so I have to Chang the oil be for starting it but I was grad to finally here she make a sound
#6 |
Ranger tom
It's like the coper pen is not going all the way down is what the guy that I bought it from told me was one of the issues
#7 |
Ranger tom
That leank you poor in there is not working
#8 |
Certified looney toon
MOTM Jul '13, Jul '14
![]() Hey Unregistered! The code [you] shows the username currently logged in. ![]() IBA # 56020 AMA # 521481 ![]() Hold yourself to the same rules you expect others to follow. |
#10 |
Hewwo!
#11 |
Ranger tom
Well I have a 1988 gpx ninja 250 so will the wirking be the same as a 2008 ninja 250 shown on the diagram
#12 | |
https://faq.ninja250.org/wiki/Starter_circuit_schematic ![]() 1. Note that there's 4 switches that must be set properly for START button to work. - Ignition-switch = ON sending power out - Engine Start/Stop = ON - Neutral-switch = ON or... - Clutch-switch = IN (squeeze lever) 2. There should be +12v power on red wire going into START button 3. There should be continuity/zero-resistance to chassis-ground on yellow/green wire at starter-relay coil ONLY when ALL these switches and conditions are set properly will START button activate starter-relay which activates starter-solenoid which sends power to starter. |
#13 |
NinjaBraap
Join Date: Dec 2016 Motorcycle(s): 06 Ninja 636, 2016 Yamaha R3 (Street/Track), 2019 Ninja 400 Project Racebike Posts: 175
Fuel mixing into oil huh? Been sitting a while, likely piston rings are, or were seized.
Bike won't crank, lights come one, replaced battery and solenoid starter. | iforgot | 2008 - 2012 Ninja 250R Tech Talk | 4 | November 21st, 2015 12:35 PM |
Starting issues, Ninja 2010 won't crank | BlueDragon | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 12th, 2015 02:49 PM |
Another bike will crank but won't start thread... | remix919 | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 12th, 2014 01:05 PM |
bike won't crank!! | LoneRonin | 2008 - 2012 Ninja 250R Tech Talk | 14 | September 5th, 2011 04:19 PM |
New battery, still won't start | frankfong | 1986 - 2007 Ninja 250R Tech Talk | 9 | January 12th, 2011 10:08 AM |
