Go Back   ninjette.org > 2018+ Ninja 400 > 2018+ Ninja 400 Tech Talk
Old September 13th, 2020, 04:50 PM   #1
Azn400
Motorcycle(s): 2019 ninja 400 ABS
Smoking O2 sensor
So white smoke comes out of O2 sensor after 2 minutes of idling. Bike is 2019 and has about 760 miles. What could be the issue here, team ninjette?
File Type: jpg FBD29AF6-28DC-4C3E-AE77-B98D20D75204.jpg (65.0 KB, 14 views)
Azn400 is offline   Reply With Quote
Old September 13th, 2020, 06:54 PM   #2
Hi Duc & welcome to Ninjette!
White smoke is usually coolant. Typically from cracked head or blown headgasket.
Does it come out of body of O2-sensor? Or the threads? Or out end where wires are? Any white smoke out tailpipe?
Does white smoke come out anywhere after bike’s fully warmed up (about 10-15 min)?
Last futzed with by DannoXYZ; September 13th, 2020 at 10:24 PM.
Old September 13th, 2020, 07:49 PM   #3
Azn400
Hello,
The smoke comes out where the crush washer meets the header. So I think it’s the thread. It will come out normally 1-2 minutes after starting up. The washer looks a little rusted.
I’ll check the tail pipe tomorrow.
Old September 18th, 2020, 07:47 AM   #4
@Azn400
Any more news on this smoking?
Forgot to mention to check if O2-sensor is fully tightened. Might want to remove, replace crush-washer and re-install.
Old September 18th, 2020, 12:44 PM   #5
Azn400
No white smokes from tail pipe. It could be sitting for a while and burned off the old gas. After refueling with no-ethanol gas, it runs fine. I still smell some smoke but not like before. You might be right about replacing the crush-washer. Thank you.
Old September 18th, 2020, 03:08 PM   #6
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
I don't see any traces of coolant from above in your pic, but check out Cylinder coolant seal issues to make sure you don't have a leak there.
Smoking is bad for you :) Ninjinsky Off-Topic 5 February 17th, 2016 04:26 PM
Koso Oil Temp Sensor Adapter & Water Temp Sensor Adapter StaylorT 2008 - 2012 Ninja 250R Tech Talk 10 January 24th, 2014 12:38 AM
quitting smoking Bunker Off-Topic 7 September 20th, 2011 07:54 PM
Smoking pipe eddiekay General Motorcycling Discussion 12 November 22nd, 2010 04:55 PM
Smoking hell! jonthechron 2008 - 2012 Ninja 250R Tech Talk 17 March 19th, 2010 03:46 PM
