Old March 30th, 2010, 01:59 PM   #1
bikeguy57
Motorcycle(s): 1974 CB360 2008 Black 250 Ninja
"Play" in master cylinder
Any ideas on how to overcome the "slop" or play in the master cylinder. I have braided brake lines and have properly bled the system. I would even consider Pazzo levers to improve the feel, or a reasonably priced aftermarket master cylinder. Thanks.
bikeguy57 is offline   Reply With Quote
Old March 30th, 2010, 02:10 PM   #2
g21-30
g21-30's Avatar
How far does the lever move when brakes are engaged?
Old March 30th, 2010, 02:14 PM   #3
bikeguy57
about 1/3 of the travel?
Old March 30th, 2010, 02:22 PM   #4
does it travel 1/3 of the way before the brakes start to engage or travel 1/3 of the way from initial brake grab to brakes full on.
Old March 30th, 2010, 02:33 PM   #5
bikeguy57
Full on. They really work ok, but the lever almost touches my hand on a hard stop. I'd rather have them engage sooner.
Old March 30th, 2010, 02:36 PM   #6
bikeguy57
Actually, it's 1/3 to the beginning of brake engagement.
Old March 30th, 2010, 02:47 PM   #7
If you can pull the lever all the way to the bar, something is likely up with the bleeding job somewhere. I'd try it again, and repeat until you can't bring the lever all the way to the bar without a vise grip.
Old March 30th, 2010, 02:54 PM   #8
I agree... either you need to bleed the lines again or something may be wrong with your master cylinder.
Have you tried back flushing the line to get any air out?
how was the front brake before the braided lines were installed?
Old March 30th, 2010, 03:02 PM   #9
bikeguy57
It's the same amount of play as before the installation of the lines. I'm confident it's not a bleeding issue. As I said, they work fine. I'll just deal with it, or find a good deal on a radial master cylinder.
Old March 30th, 2010, 03:09 PM   #10
g21-30
g21-30's Avatar
Prior to replacing my MC with one from a ZX-10R, I installed Galfer SS lines and used the OEM MC. The only time the lever came close to the clipon was before bleeding. I'm curious on how you bled the lines. Don't get me wrong, I'm NOT questioning whether you did it correctly or not...just how?
Old March 30th, 2010, 03:15 PM   #11
And I'm saying what you are experiencing is not what the majority of owners have at their front brake lever. I still say it's a bleeding issue or a bum MC.
Did you purchase the bike new? If used, could the previous owner have futzed with the brakes and let air into the system?
Old March 30th, 2010, 03:18 PM   #12
bikeguy57
The lever doesn't come close to the bar. It comes close to my hand under hard braking. I bled it with a vacuum pump and by pressure both before and after riding it.
Old March 30th, 2010, 09:03 PM   #13
kevlar250
kevlar250's Avatar
Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1
You need to bleed the banjo bolts, a tiny air bubble can sit in there and will not come out. Get some help and have them squeeze the lever while you loosen the banjo bolt slightly, hold a rag under to catch fluid, and tighten before the lever bottoms out. You should do both upper & lower. Hopefully you're not using DOT 5 fluid, that will make them spongy.
kevlar250 is offline   Reply With Quote
Old March 31st, 2010, 09:36 AM   #14
bikeguy57
Thanks, I'll give that a try.
[superbikeplanet.com] - "Violent Braking Sections" Should Play To Aprilia WSBK Streng Ninjette Newsbot Motorcycling News 0 June 4th, 2014 08:10 AM
"all work and no play makes jack a dull boy" subxero Riding Skills 24 January 18th, 2013 10:26 AM
