Old March 30th, 2010, 04:37 PM   #1
Chubbs032
Motorcycle(s): 250r
Bike has no throttle and dies?
So I have a 2008 250r with 600 miles. It's been shimmed 2 washers, desnorkled, kleen air mod, and a full PLFMG exhaust. The past 4 rides, I've been riding in 3rd gear going 30-40mph and suddenly I will lose all throttle response and the idles will drop and the bike dies causing me to pull off to the side of the road if I can make it. I'll turn it off give it 1-2mins and restart it up and it will work okay or do it again after I get going. I open the gas cap to see if there is any air/fuel problems, but there's no suction noise.
1. For CA emission gas tanks, there are 3 holes on the left side of the tank. I removed the emission evaporator box and plugged the red and blue hole with rubber vacuum caps. The only tube that remains is the run-off that goes to the ground? Is that okay?
2. From reading, I'm thinking my carbs may be getting flooded with two washers, so I might just do 1 washer on each side?
3. The bike only has 600 miles, so it has a lot of dead time, I'm not sure with the previous owner, but it has sat for 2 - 3 weeks without riding. I've used seafoam 1oz/per gallon a tank ago. You think this is just a clogged up carb?
Otherwise the bike runs very well and strong, just these random stalls with no throttle control at all. It can happen after a 20-30min ride or last night it happened after 5mins.
Chubbs032 is offline   Reply With Quote
Old March 30th, 2010, 07:59 PM   #2
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Chris did you do the mods or were the done when you got the bike?
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old March 30th, 2010, 08:07 PM   #3
http://www.kawiforums.com/ninja-250r...s-08-250r.html
start w/ post #26
Old March 30th, 2010, 11:57 PM   #4
Chubbs032
Motorcycle(s): 250r
Thanks kkim, so my options are add a fuel filter to the blue vent hose or do the gas cap mod/buy 49-state cap? Do I have to do both or can I do one or the other?
Also any part number on which fuel-filter, it'll make my trip a lot easier?
Thanks.
Also look like there is a air filter attached after the fuel filter, I'm not sure where to pick those up?
Old March 31st, 2010, 12:46 AM   #5
Chris,
PM VEX and ask him your questions. I don't have a Ca bike and know nothing firsthand of what it takes to get things right when removing the canister.
Engine Issues: Bike Dies when given throttle? Largo 5.0 2008 - 2012 Ninja 250R Tech Talk 19 August 4th, 2021 05:12 AM
6000 RPM Idle Dies with Throttle garman 1986 - 2007 Ninja 250R Tech Talk 3 August 9th, 2014 01:29 PM
bike dies when giving it throttle RED_09 2008 - 2012 Ninja 250R Tech Talk 8 December 16th, 2012 04:51 PM
Throttle problem? Bike bogs and dies MikeBudd 2008 - 2012 Ninja 250R Tech Talk 12 September 8th, 2011 09:02 PM
Engine Dies w/ throttle + shimming needles kevlarorc 2008 - 2012 Ninja 250R Tech Talk 19 October 20th, 2010 08:19 PM
