Old March 31st, 2024, 02:51 PM   #1
unionjack
Motorcycle(s): ninja ex250f
Unhappy no spark
following previous posts ive read about putting a resistor in the gray wire for an aftermarket ignition which this bike had previous to buying it the bike would have a rough time starting but would start and i recently cleaned out the carbs but suddenly there is absolutely no spark from either plug or the coils themselves, i started with checking the battery and voltage is fine, all of the lights come on and engine cranks/tries to start it literally just will not give any spark and im confused as to why the only left over connections are these two that im not entirely sure as to where they go, any tips on where to go from here to diagnose this issue?
unionjack is offline   Reply With Quote
Old March 31st, 2024, 02:52 PM   #2
unionjack
Thumbs down no spark
following previous posts ive read about putting a resistor in the gray wire for an aftermarket ignition which this bike had previous to buying it the bike would have a rough time starting but would start and i recently cleaned out the carbs but suddenly there is absolutely no spark from either plug or the coils themselves, i started with checking the battery and voltage is fine, all of the lights come on and engine cranks/tries to start it literally just will not give any spark, any tips on where to go from here to diagnose this issue?
Old April 1st, 2024, 01:18 PM   #3
All I can suggest is to go by the wiring diagram and check to see that you have the correct voltages at the ignition unit, the pickup coil's resistance is 100 to 150 ohms, that all the safety switches are connected and working as they should, etc. Any of the safety switches could be causing no-spark if a wire came loose, for example.
Page 212 shows ignition wiring.
Old April 2nd, 2024, 05:25 PM   #4
unionjack
thank you i will take a look at these first
Old April 5th, 2024, 12:48 PM   #5
unionjack
update it was the pulsar coil
Old April 5th, 2024, 01:51 PM   #6
Bad coil, or wrong gap?
09 with no spark Tsmith9233 2008 - 2012 Ninja 250R Tech Talk 2 July 3rd, 2020 09:24 AM
No spark Oldskool 1986 - 2007 Ninja 250R Tech Talk 0 May 7th, 2019 12:19 PM
no spark ??? Racer x 2008 - 2012 Ninja 250R Tech Talk 4 February 25th, 2014 09:08 PM
Removing spark spark plugs? tsdexter 2008 - 2012 Ninja 250R Tech Talk 3 June 26th, 2013 03:48 PM
Why no spark? Flying Pig 2008 - 2012 Ninja 250R Tech Talk 12 January 30th, 2012 01:13 AM
