Old April 6th, 2024, 02:01 PM   #1
unionjack
Motorcycle(s): ninja ex250f
vaccuum petcock now is gravity powered
it appears the petcock on this bike no longer works through vacuum but just pours out regardless, is there going to be any serious adverse effects of running a basically just normal gravity fed one on this bike or is it worth the rebuild?
unionjack is offline   Reply With Quote
Old April 6th, 2024, 02:13 PM   #2
The problem happens if one of the carbs develops a leaking float valve. Then the engine's crankcase can fill up with gasoline, causing you lots of grief. It could even pour gasoline onto your garage floor. I wouldn't risk running it with an always-on petcock.
Old April 6th, 2024, 03:01 PM   #3
unionjack
honestly thats a really good point i think ill order a rebuild kit for it thanks
Petcock off = good idle, petcock on = no idle? | Could use some help notrocketscience 1986 - 2007 Ninja 250R Tech Talk 9 August 17th, 2022 04:33 PM
Zero Gravity Windscreens DaBlue1 2013 - 2017 Ninja 300 Farkles 10 September 13th, 2013 08:59 AM
Vacuum nipple came off petcock - fix or replace petcock? fierostetz 1986 - 2007 Ninja 250R Tech Talk 3 November 24th, 2012 11:03 AM
Gravity Falls? Byakkotai Off-Topic 11 October 24th, 2012 06:15 PM
Had my first fight with gravity :( Sk8dude !%@*#$%!)@#&!%@ I crashed! 37 August 25th, 2010 08:26 AM
