Old May 27th, 2010, 07:58 PM   #1
patw
patw's Avatar
Motorcycle(s): 2009 Ninja 250 SE
Tail Light Bulb Change
Oddly enough, I couldn't find a procedure on how to do it after my running light filament burnt out. There's 2 filaments in the bulb (type 1157), found pretty much anywhere (got mine from a 24hr Walmart at 10:30pm).
Process is stupid easy and can be done without tools:
1) Pop passenger seat.
2) Pull up the strange black wire holders (made of some flexible metal). Pull the wires out so they're easy to work with.
3) Disconnect rear light (white connector, not the black one).
4) Twist the white plastic bulb housing sticking out of the back of the tail light unit until the tabs line up, and pull out. It was a bit stiff, so it didn't look like it would twist at first.
5) Remove old bulb, replace with new. Return things to original state.
2013 CRF250L
1985 GL1200 Interstate
patw is offline   Reply With Quote
Old August 13th, 2012, 06:41 PM   #2
Old Lemon
Lays er down
Old Lemon's Avatar
Motorcycle(s): 2008 Lime green Ninja 250R
bump i think this should be in the DIY sticky lol. it helped me
Old Lemon is offline   Reply With Quote
Old August 13th, 2012, 06:51 PM   #3
patw
patw's Avatar
Thanks! Totally forgot I posted this. The new bulb is still going.
2013 CRF250L
tail light/turn signal bulb size ieathonda 1986 - 2007 Ninja 250R Farkles 20 March 27th, 2015 06:48 AM
Tail light? Fuse or bulb? Løckøut 1986 - 2007 Ninja 250R Tech Talk 10 September 30th, 2013 10:17 AM
Tail Light + Brake Light Not Working (Bulb Replaced) JayZE302 2008 - 2012 Ninja 250R Tech Talk 11 August 8th, 2012 05:03 PM
How long does it take to change a light bulb? Den 2008 - 2012 Ninja 250R Tech Talk 12 August 12th, 2011 09:15 PM
Replacement tail light bulb illrational 2008 - 2012 Ninja 250R Tech Talk 3 September 17th, 2010 07:02 AM
