Old June 4th, 2010, 11:58 PM   #1
Kitdog
Kitdog's Avatar
Motorcycle(s): 2009 Ninja 250r, 1996 Yahmaha YZ 125... Both in Blue the coolest color
DIY Painted wind screen
Well my friend who WORKED at the tint shop does no more, (owners daughter dumped him so he fired) so I decided after much thought that I would just paint my wind screen. I never look through is i don't tuck that low and if I try I'm hitting my helmet on the tank. I also don't like the looks of a double bubble, (just a personal preference) So here is a DIY on painting your wind screen.
First look at kkim's DIY on replacing the windscreen http://www.ninjette.org/forums/showthread.php?t=13507
Then these are the things you will need, along with a razor blade and scissors, some blue masking tape, some paper, and this part is key the KRYLON FUSION for plastic. I got mine at Wal-mart. and got the Gloss black.
Then begin to mask off your wind screen. the Side that is inside the curve will be the painted so be careful to mask well the other side to protect from over spray.
after masking the front of the wind screen.
To mask the "bead across the top of the wind screen I affixed 50% of the masking tape to the out side then Rolled it over to the back (to be painted) side
I then took my NEW (has to be SHARP) razor blade and cut away the masking where the bead ends on the back side and pealed the masking tape away.
After I took the masking tape again and placed it round the edge of the wind screen (the edge like you were trying to look at how thick it is) and affixed it even with the back (going to be painted side) and the rolled the excess over to the front. also notice how I went over the mounting bracket to make your tape cover these bits simply cut the tape like this... just fold over to the front side.
Just slice the tape onto little fingers and over lap them as you fold.
Once you have the sides well masked, simply take some news paper and mask off the remaining front side. this is the view looking threw the to painted side at the final masking job.
Then paint the unmasked side, shake the can WELL (yes untill your arm hurts about 3 min). Next repress all your masking, (just to be safe). Begin to paint with short strokes holding the can about 8-10 inches from the screen,perpendicular to it, laying down a thin, even layer of paint, building it up until you can no longer see through the screen, allow to dry, about 30-45 min and then apply a 2nd coat with the same method.
Then allow the screen to dry fully over 10-12 hours, I left mine over night.
Remove the masking and behold your lovely new black wind screen.
I have to say the Krylon is AMAZING, the results are almost glass like and supper smooth.
File Type: pdf DIY Painted wind screen - ninjette.org.pdf (4.17 MB, 31 views)
"Well you know, for me, the action IS the juice"
Kitdog is offline   Reply With Quote
Old June 5th, 2010, 12:33 AM   #2
Chubbs032
Motorcycle(s): 250r
Did the same with mine 2 weeks ago, used high-temp black engine/caliper paint. Came out nice.
Nice write-up
Chubbs032 is offline   Reply With Quote
Old June 5th, 2010, 10:15 AM   #3
Linked to our DIY Sticky.
Old June 7th, 2010, 07:49 AM   #4
BlueThunder18
BlueThunder18's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2006 Suzuki Boulevard C50T
Nice job. Mine came like this from the previous owner so saved me from doing it. When I first saw it had been painted, I thought not being able to see through would bother me, but haven't noticed it when riding.
BlueThunder18 is offline   Reply With Quote
Old June 7th, 2010, 08:04 AM   #5
tjkamper
tjkamper's Avatar
Looking good.
Old June 15th, 2010, 08:22 AM   #6
WOWNinja
oh yes it is!
Motorcycle(s): 2010 Ninja 250R SE - SOLD 2004 CBR600RR Candy Blue (sportech wind Screen / OEM Sliders)
did this last night and surely it makes a +1 difference...
WOWNinja is offline   Reply With Quote
Old June 15th, 2010, 06:31 PM   #7
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
Nice DIY, inexpensive,simple and looks the way it should
Old June 15th, 2010, 07:28 PM   #8
Snake
Snake's Avatar
Great job, Looks very good.
It's amazing the high quality of paints now available in rattle cans.
Old June 15th, 2010, 08:14 PM   #9
Kitdog
Kitdog's Avatar
Masking is an art to me... I build 1/48 scale model airplanes and when I go to air brush a plane and have to mask a windshield that is no bigger than my fingers made this really really easy.
Old June 16th, 2010, 11:04 AM   #10
Guinss
Guinss's Avatar
Motorcycle(s): 2008 250R (Black)
Inspired by this, i painted my windscreen today. Looks great. Thanks for the DIY, Kit.
One thing i liked alot with this, is that you don't have to have any skills in painting. I got a load of dust in the paint, and was worried of the result. But when i got it mounted on the bike again, it's just not visible at all because it gets all dark under the windscreen, so you don't see a thing. You will need a flashlight to see it.
That masking-job you did there is impressive. I'm sure you would have started crying if you saw pictures of my masking. You have done this before, i could tell.
Guinss is offline   Reply With Quote
Old June 16th, 2010, 01:42 PM   #11
Kitdog
Kitdog's Avatar
This is what I'm used to masking. It's a 1/48 scale B-17g...yes that's my finger next to it for scale, the windows on this took me about a day to mask all 7 of them.
Old August 29th, 2010, 02:12 AM   #12
leedajdmba
Motorcycle(s): 2008 Triumph Daytona 675 SE
Thanks for the Post, Just did Mine Today
leedajdmba is offline   Reply With Quote
Old September 10th, 2010, 04:42 PM   #13
kn250
Motorcycle(s): 2009 kawasaki ninja 250r
Thumbs up looks good
it's looks great thanks for the info. i going to do that to mine too i have a red 250r it's 09.
kn250 is offline   Reply With Quote
Old June 11th, 2011, 02:02 AM   #14
maxwellca21
maxwellca21's Avatar
Motorcycle(s): 09 ninja 250
tag
ride it like you stole it!
maxwellca21 is offline   Reply With Quote
Old June 11th, 2011, 09:06 AM   #15
DBentley415
DBentley415's Avatar
When removing the windscreen has anyone had troubles attaching it again? I recently took the screws out of my bike all over and painted the heads black so there is less silver on my bike. When I went back to screw in the two bottom screws for the windscreen they wouldn't thread back in and then one of them just pushed all the way in without threading at all. After looking at it closer and checking out what was wrong I noticed that the part with the threads is attached with rubber and I had pushed too hard on that and it broke off. I still have the piece that broke off, but it's almost impossible to reach under there and thread it onto the screw so i've just left those two screws out. I just don't understand why anyone would think it was a good idea to attach that stuff with some flimsy rubber. If anyone doesn't understand what i'm talking about, I can post some pics of the piece that broke off.
*In paradise there ain't no clocks...*
DBentley415 is offline   Reply With Quote
Old June 11th, 2011, 10:05 AM   #16
Cazper
ninjaholic
Cazper's Avatar
What you are referring to are called "wellnuts". Unfortunately they are very brittle and weak rubber and have a tendancy of deteriorating and falling apart. There are many places you can buy replacements for... you can do a simple search on here for "wellnuts" and come up with more information.
Nice DIY btw
09' SE Ninja 250R
$2,547.83
Old June 11th, 2011, 10:49 AM   #17
DBentley415
thanks so much! I will definitely look into that. I'm glad someone understood what i'm referring to.
Old June 11th, 2011, 10:04 PM   #18
southernmostninja
Motorcycle(s): ninja 250 pearl white 2011
i had considered doing this but i find myself looking through the clear glass when i crouch down when im riding hard. do you guys get that low when you ride?
southernmostninja is offline   Reply With Quote
Old June 12th, 2011, 03:07 PM   #19
wtfh4xx
Opinionated individual :)
wtfh4xx's Avatar
Motorcycle(s): 2010 Ninjette Special Edition (red/black)
anyone have tips on REMOVING paint from windscreens?
Previous owner did ****** job on the screen and I want to repaint.
Not sure if paint stripper would damage the plastic.
Yoshi slip on, shimmed 2 washers, zip tie throttle mod, pre-load #2, snorkel delete
2010 SE 250R!
Miles in the saddle: 1000
wtfh4xx is offline   Reply With Quote
Old June 12th, 2011, 05:19 PM   #20
ladyninja08
ladyninja08's Avatar
Motorcycle(s): 2011 black ninja 250r
Anyone who is interested in seeing 2011 black bike with DIY painted windscrren check out my pics in my albums section Sorry but I cant figure out how to post pics Let me know what you think!!
ladyninja08 is offline   Reply With Quote
Old June 12th, 2011, 05:58 PM   #21
wtfh4xx
wtfh4xx's Avatar
Host to somewhere like photobucket or imageshack (reduce to 600x600 before you do or itll take forever), and then use the little link button.
2010 SE 250R!
Old June 15th, 2011, 02:05 PM   #22
Chefdota
Motorcycle(s): 250r
im thinking of doing this cus there is alot of black bikes doing might as well to
KRYLON FUSION gloss black is the best?
Chefdota is offline   Reply With Quote
Old June 15th, 2011, 02:09 PM   #23
ladyninja08
Yes Krylon Fusion Gloss Black works best
Old June 15th, 2011, 02:16 PM   #24
Old June 21st, 2011, 01:34 PM   #25
Luiz Gaia
Luiz Gaia's Avatar
Motorcycle(s): Ninja 250R
Thats my Red.
Luiz Gaia is offline   Reply With Quote
Old July 28th, 2011, 01:40 PM   #26
the big mike
the big mike's Avatar
Motorcycle(s): 2008 Ninja 250r, Fazer8
this thread needs a green bike!! I'll do this when I find some free time
the big mike is offline   Reply With Quote
Old July 28th, 2011, 08:11 PM   #27
solo440
solo440's Avatar
Motorcycle(s): 2009 Ninja 250R SE
The screen is not 100% black and the bike is not 100% green, but hopefully this can tie you over until you do yours.
2009 250R SE, ProGrip CF Tank Pad, DIY Smoke Windscreen
solo440 is offline   Reply With Quote
Old July 30th, 2011, 01:25 PM   #28
the big mike
I would like to see this from different angels, rider position etc.
thanks
I can not be a true player by playing around.
Old July 30th, 2011, 02:06 PM   #29
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
----> My Youtube! <----
Old July 30th, 2011, 02:19 PM   #30
the big mike
wow, fast post, nice of you thanks!!
I was wondering, doesn't it bother you that it's so dark under your screen whilst riding?
And if I don't like the result, how can I undo it?
edit: 101st post
Old July 30th, 2011, 02:33 PM   #31
Kevin2109
KThanksBye
Kevin2109's Avatar
edit: 101st post
The ONLY time I ever notice it is if I try to get in a full tuck doing 100+ other then that I never even notice it. The only other thing is the GoPro, I cant suction cup it to the tank and have it record through the screen, but there are so many other positions for the camera that it really is a big issue
Old July 31st, 2011, 01:01 PM   #32
the big mike
painted it this evening. I'll post some pics when I put it back on tomorow.
Thanks for the quick response kevin
here you go:
Last futzed with by the big mike; August 2nd, 2011 at 02:13 PM.
Old August 8th, 2011, 10:46 PM   #33
SweetB
Motorcycle(s): 2009 Blue Ninja 250, 2009 White Vespa S 150
Just did this mid last night and the results are amazing! I initially grabbed the wrong paint ay Lowe's; got a can of Valspar and while it's great stuff for interior walls, it was horrible on plastic. The Nylon Fusion worked perfectly and my bike looks so hott!
SweetB is offline   Reply With Quote
Old November 29th, 2011, 01:28 PM   #34
saxnbass
saxnbass's Avatar
Motorcycle(s): 2009 CBR600rr
I know I'm bumping an old thread, but I figured it better than starting a new one.
Has anybody done this using something other than the gloss black? Flat/Matte black perhaps? Or a colour other than black (red, green, blue, etc. to match the bike?)
And the unanswered question from above, can you undo it if you do a bad job?
saxnbass is offline   Reply With Quote
Old November 30th, 2011, 08:59 AM   #35
GateKeeper
GateKeeper's Avatar
Motorcycle(s): 250 Ninja - Soon
use what ever color you want, as long as it's safe for plastic...
your spraying the inside of the wind screen, you really can't screw it up, unless you spray too close and create runs or something silly like that, and or you don't mask off what you don't want painted.
Can you undo ? you could, you have to strip off the paint, but in doing so, you will probably mess up the wind screen, by either scratching it, or melting it if using some sort of paint stripper.....
Typically once you do this, you really don't want to undo it.......probably cheaper to buy a new one
GateKeeper is offline   Reply With Quote
Old August 8th, 2012, 11:52 AM   #36
ryan.chin
Motorcycle(s): 2007 R6
Going to do mine today.
ryan.chin is offline   Reply With Quote
Old October 12th, 2012, 04:14 PM   #37
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Just saw this trick on a YouTube vid. LOVE the look, I am so doing this one!
Thanks for the DIY and brilliant masking job. Guessing modeling pays off in unexpected ways.
<-- Linky
Old October 19th, 2012, 08:30 PM   #38
Dazo
Motorcycle(s): 09 Ninja 250
Thanks for the DIY, it was very simple and makes the windscreen look a lot nicer.
Dazo is offline   Reply With Quote
Old April 5th, 2013, 02:35 PM   #39
ArcAngel
Motorcycle(s): Kawasaki Ninja 250R 2012
Do you recommend sanding the windscreen before painting?
ArcAngel is offline   Reply With Quote
Old April 5th, 2013, 03:05 PM   #40
saxnbass
saxnbass's Avatar
No, do not sand. Use Krylon Fusion spray paint and it'll turn out great. The only thing you'll want to do for prep is mask the outside and clean the inside.
My Mods | My Bike's Ninjette Thread
2009 Stock Wind Screen Mjj Free stuff! 5 December 23rd, 2013 01:08 PM
Rear Hugger and Wind Screen akima General Motorcycling Discussion 17 June 24th, 2012 08:08 AM
Wind screen bolts? play2pwn 2008 - 2012 Ninja 250R Farkles 4 May 20th, 2011 12:40 PM
Home made wind screen Mr Quality 1986 - 2007 Ninja 250R Farkles 5 November 9th, 2009 09:47 AM
