Old June 14th, 2010, 02:46 PM   #1
00v_Lucky
00v_Lucky's Avatar
Motorcycle(s): '09 Candy Thunder Blue Ninja 250R
Exclamation !HELP! Adjusting Valves issues
I started to begin adjusting valves (checking valve lash) yesterday. As I was removing the 8 cam journal bolts (8mm) I stripped one
*it's not terribly stripped but the socket just spirals off as I begin to turn. Any ideas how I can get it out?
Anyone with a book know torqued these bolts are supposed to be? How bout the valve cover grommet bolts as well (for when I put everything back together). Thanks in advance!
00v_Lucky is offline   Reply With Quote
Old June 14th, 2010, 02:56 PM   #2
HKr1
IC2(SW)
HKr1's Avatar
You used a 6 point socket & it stripped?
Old June 14th, 2010, 03:00 PM   #3
00v_Lucky
00v_Lucky's Avatar
I think my problem was that I used an extension going over the frame (wasn't as careful as I should have been I guess). big lesson learned. I hate how this stupid little bolt has made my valve adjusting come to a complete halt.
anyways, Thank you for the numbers!
Old June 14th, 2010, 03:03 PM   #4
HKr1
IC2(SW)
HKr1's Avatar
Maybe salvage it, clean it up with a file or something. Use it on an outside cap?
Or did you not get it loose?
Old June 14th, 2010, 03:06 PM   #5
00v_Lucky
00v_Lucky's Avatar
from my friends 500 book, the actual name for it is the "camshaft bearing cap bolt" however, which one of those names is the same one as this "camshaft bearing cap bolt" ?
edit: and yes, I was not able to get it loose at all sadly.
Old June 14th, 2010, 03:14 PM   #6
tjkamper
tjkamper's Avatar
Use Vicegrips to take it out. Clamp them down hard on the bold. If you need more torque to turn the bolt, put a pipe on the end of the vicegrips.
Old June 14th, 2010, 03:28 PM   #7
00v_Lucky
00v_Lucky's Avatar
I've been trying with the Vicegrip since this bolt cannot be salvaged anymore, the problem is that this bolt was much softer than I had expected.
Old June 14th, 2010, 04:01 PM   #8
Momaru
Momaru's Avatar
Might take a gander @ Craftsman's Bolt-out sockets. Link is for a 10pc set but I know they sell 'em individually too. Not cheap, but...
Proud member of the Blue Army
Old June 14th, 2010, 04:07 PM   #9
HKr1
IC2(SW)
HKr1's Avatar
second pic, camshaft cap bolt.
Crap, noticed that in your first post now. If it's all F'd up from vice grips. I would probably grind the top off, get the cap off/cam out. Then use the vice grips/pliers on the stud.
Old June 14th, 2010, 04:39 PM   #10
00v_Lucky
00v_Lucky's Avatar
I luckily got it out by hammering down a nut driver onto the cap and used an air gun with 120 psi. phew.
now all i need to do is buy a new bolt. thanks for all of your guys' help once again.
DIY - Adjusting Valves on '08+ 250r (WITH Pictures) VeX 2008 - 2012 Ninja 250R Tech Talk 93 August 21st, 2017 01:34 PM
issue adjusting the valves extremez31 1986 - 2007 Ninja 250R Tech Talk 5 June 16th, 2014 10:16 AM
Adjusting Choke astricklin 2008 - 2012 Ninja 250R Tech Talk 4 April 5th, 2013 06:06 PM
Adjusting my mirror RaZeDaHeLL General Motorcycling Discussion 6 January 22nd, 2012 02:34 PM
Help with adjusting the values Ingersoll 2008 - 2012 Ninja 250R Tech Talk 2 January 14th, 2010 08:08 AM
