Old November 10th, 2010, 09:03 PM   #1
steadyeddie
steadyeddie's Avatar
Motorcycle(s): 99 ZRX, 2000SVSuperbike, 05 ZZR 250, 09 250R
Ignition delete
Has anyone deleted their igniton switch and used the kill switch instead? Race only so I want to get rid of the keyed switch. Not an electrical guru so I need some guidance.
steadyeddie is offline   Reply With Quote
Old November 11th, 2010, 01:12 AM   #2
jonthechron
Motorcycle(s): magHitVE
Fairly easy, I haven't done it but it's not hard. I'll look at the diagram tomorow and provide you with the howto.
Old November 11th, 2010, 01:05 PM   #3
M
Motorcycle(s): Ninja 250 x2, Ninja 650R
Here's a wiring diagram that'll show you the ignition setup for the 'F' model:
http://faq.ninja250.org/images/0/00/...matic_Rev2.pdf
The '93-07 models have a 100Ω resistor in the ignition that acts as a theft deterrent. You'll have to bypass this resistor:
brown => white
brown => 100 ohm resistor => grey
I do not know if this is the exact same for the 'J' models, though I'm confident that the resistor is still there.
The Rally - Oklahoma
M is offline   Reply With Quote
Old November 11th, 2010, 02:14 PM   #4
I saw someone on here was selling a lock set and gas cap after their race conversion. I'm not sure that they went THAT far though.
Edit:
http://www.ninjette.org/forums/showthread.php?t=59011
Looks like he did because he's supposedly selling the ignition switch and is offering a wiring diagram to use the toggle for ignition.
Old November 11th, 2010, 02:45 PM   #5
demp
I don't know if it's true or not, but I remember hearing advice not to use the killswitch too often - because the switch itself is cheap and ends up staying in the "off" position... something along those lines anyways
Old November 11th, 2010, 07:39 PM   #6
steadyeddie
Been using the kill switch as the only on/off on my race SV for 2 years now and not a single problem. I completely rewired the SV down to 8 wires so it was easy to do. The 250 has to remain ss legal so I can not trash the wire harness. I do not know electronics so hoping someone can provide a detailed schematic.
Thought about a toggle switch to replace the key, but that seems counter-productive: just replacing 1 switch with another.
jonthechron, many thanks in advance for the info.
Old November 12th, 2010, 05:15 AM   #7
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I removed the key and ignition . I was afraid I would loose the Key and I also had to remove the lock from the frame( It got in the way of some wiring).
Now I am rewiring the whole bike. I am going to have a relay to power everything on the bike. The power for the relay will be an on off switch. And the ground for the relay will be through a tethered kill switch . If the switch is pushed or the clip comes out .The power is removed from the relay , That will kill power to the whole bike.
Originally I had two kill switches .One for ignition and one for Nitrous.But now I will combine everything.
Old November 13th, 2010, 09:06 PM   #8
headshrink
headshrink's Avatar
Fantastic, Eric - would love to see more pics.
Old November 27th, 2010, 09:46 PM   #9
steadyeddie
Ignition switch is gone. Wiring was really quite easy. Can be returned to stock if wanted. I'll have to buy a new ignition switch because I didn't know exactly which resister to buy so I took it out of my existing switch, destroying it. Oh well, mission accomplished.
Old November 27th, 2010, 09:51 PM   #10
Nice! Glad it worked out.
Old January 16th, 2011, 05:40 PM   #11
Bueller999
Oldie but a goodie
Bueller999's Avatar
Motorcycle(s): 08 Ninja 650r, 06 SV 650 race, 08 250r race, 03 Buell XB9s, 01 KTM 300 EXC
Does anyone know what the resistor value is or have a wiring diagram for this?
EDIT: Got it taken care of, thanks
Last futzed with by Bueller999; January 17th, 2011 at 02:06 PM.
Bueller999 is offline   Reply With Quote
Old January 17th, 2011, 09:03 AM   #12
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Steady, cool name. Great avatar also. You look like a professional.
Old January 17th, 2011, 07:17 PM   #13
Order
Order's Avatar
Motorcycle(s): 08 Ninja 250R (race), 01 Ninja ZX6R (race), 00 Ninja ZX6R (street), 03 R6 (race)
Someone should do a step-by-steo writeup + photos..
Order is offline   Reply With Quote
Old January 17th, 2011, 07:42 PM   #14
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
Yeah, that be a good idea!
scotty is offline   Reply With Quote
Old January 23rd, 2012, 12:26 PM   #15
Thuevo
Motorcycle(s): None yet
Sorry but.this diagrams is for 2008/2010 model?
i make new bike with ninja 250 engine y and then i connected the gray without the resistor (go and I think I frying the ignition: P
Thuevo is offline   Reply With Quote
Old January 23rd, 2012, 12:37 PM   #16
Thuevo
i make new bike , and then connected the gray to 12v line without the resistor and I think I frying the igniter : P
Old November 7th, 2013, 04:32 PM   #17
blegerton
Motorcycle(s): ninja 250 2008
for the 2008 model, where did you rout the white wire, the white and black wire and the brown. did you just tie the grey and white/black wire together with the resistor? and which if any wires did you locate to the right bar harness?
I am having a hard time with the whole thing, I can rip the motor apart but the wiring is a bitch to get the hang of.
blegerton is offline   Reply With Quote
Area P full race exhaust/jetting/airbox-delete/kleen-air delete.. corksil 2008 - 2012 Ninja 250R Tech Talk 24 January 21st, 2014 07:57 PM
How do I delete a thread and delete profile ojameyo Help 18 July 17th, 2012 10:48 AM
