December 16th, 2010, 09:28 AM | #1 |
Ninja Dog
Join Date: Dec 2010 Motorcycle(s): 2011 Kawasaki Ninja ZX-14 Posts: 186
Tuning carbs for altitude
This winter and/or spring I would like to ensure that my Ninja is tuned properly for the altitude that I live at. I have been searching online for any manuals or tech specs regarding tuning our carbs for altitude, but I cannot find anything. Any thoughts to help a newbie out?
I live at approximately 4400-4500 ft above sea level. Any help would be greatly appreciated! |
December 17th, 2010, 08:47 AM | #2 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
any mods to the intake/exhaust?
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
December 17th, 2010, 09:15 AM | #3 |
Ninja Dog
No mods right now.
I do plan on K&N air filter, Yoshi Full Exhaust, and Stage 2 Jet Kit, but that's not gonna happen anytime soon. It does appear that my Ninjette is running rich. I checked the oil fill and it smells like there may be fuel in the oil. I plan on checking my plugs too to see if it confirms that the engine is running rich as well.
ALL YOUR NINJA ARE BELONG TO US! |
December 17th, 2010, 10:57 AM | #4 |
MOTM - Oct '15
Yup, I was gonna say, that you'd maybe want to go to 96 main jet's, raise the needls 1-2 shims, and go to 2-turns out on the air/fuel mixture screw (if the plugs been drilled out). But that's about all you'd need to do... You could try 94 main jets, but that might be a touch too lean.....
I'm at 5,000 feet, and these aren't just my numbers. They have been verified by most 250 racers here...
December 17th, 2010, 11:23 AM | #5 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
Definitely. Stock jets or 96s. You could put one or two shims on the needles and see what happens. About two turns on the idle mixture screws. That is a good baseline. Then play with it from there.
If you do the K&N then you are looking at having to go a lot richer all the way around. you'll probably be fine with the stock pilot jets even with all those mods at that altitude. My current setup with the 40s pilot jets is great at 2000 feet, but when I ride to utah, It is too rich and bogs down and almost dies in stop and go traffic.
Addicted to anything that has an engine and rolls. |
December 17th, 2010, 12:20 PM | #6 |
MOTM - Oct '15
My stock idle jets were 98's, not sure why that is, but keep an eye on that Psycho...
If you want to get really anal and crazy accurate, you can get yourself a set of jet drills, aka, jewelry drills - 81-60 guage kits are cheap. 2 drill sizes usually equal 1 jump in jet sizes, so you can tune very accurately for this. Unfortunately (and this is why i want FI so bad), you can tune a carbed bike very accurately for one day, but it will be off again the next... I find having 2 sets of jets - summer and winter is a good way to go. Our fall and spring isn't long enough, nor consistent enough to warrant 4 sets of jets.... For the winter, you can usually jump up one size in jets, all around. Your needle and air/fuel mixture setting might vary a little, but probably not by much. Keep in mind, I'm saying this assuming this is for general commuting/street riding where you're not really going to notice a massive difference if the jets are off just a bit.. On the track, you might.... On the other hand, the ninjette engine is a very docile power plant, especially in stock trim, which makes it more difficult to notice small effective changes....
December 17th, 2010, 12:36 PM | #7 |
Ninja Dog
Thanks for the suggestions spooph and tjkamper
Since this is my first carbed vehicle that I will be tuning, I have another question. Is adding shims to the needles going to make the AFR leaner or richer? Does turning out the needle increase airflow or fuel flow to the carb?
ALL YOUR NINJA ARE BELONG TO US! Last futzed with by PsychoNinja; December 17th, 2010 at 12:36 PM. Reason: can't spell |
December 17th, 2010, 12:41 PM | #8 |
what is your end goal... to meet emissions standards for your location or performance?
December 17th, 2010, 12:51 PM | #9 |
Ninja Dog
Mostly to optimize performance and efficiency for where I live.
December 17th, 2010, 12:55 PM | #10 |
Then I would recommend you make your intake and exhaust upgrades, buy a jet kit and start tuning.
December 17th, 2010, 01:32 PM | #11 |
Raising the needles leans the lower-end and midrange mixture. I think they are making the asdumption that while a leaner main jet might be necessary for the top end, the midrange might be too lean without shimming.
Posted via Mobile Device |
December 17th, 2010, 01:34 PM | #12 |
corrected that for ya.
December 17th, 2010, 05:24 PM | #13 |
Gah i was thinking about that a little bit ago--"wait did I said it leans the mixture?" Was too busy to check. Heh thanks for that correction :P . Youd think with carb tuning so fresh on my mind Id get the little things right lol.
December 17th, 2010, 05:50 PM | #14 |
From the Factory the Mains are 98s and the Pilot (slow jets) Jets are 38s.
December 17th, 2010, 05:58 PM | #15 |
Moroccan Gold Imports
Join Date: Sep 2010 Motorcycle(s): '03 ZX9R, '03 ZX7R & wife's '09 250R Posts: 136
Hmmm I also live near this elevation, and just ordered the parts to do all of this work over the holidays on my wife's '09. I live just shy of 4000 feet, so I will let you know how it works out for us (full exhaust, K&N pod, FP jet kit).
December 17th, 2010, 07:47 PM | #16 |
Great! When you finalize it, be sure to post up your results in the jetting database!
December 18th, 2010, 03:34 PM | #17 |
Ninja Dog
Thanks for the input everyone!
Looking forward to your results!
December 18th, 2010, 03:40 PM | #18 |
have you checked the jetting database for people that are in a similar elevation?
http://www.ninjette.org/forums/showthread.php?t=10208 |
December 21st, 2010, 10:39 AM | #19 |
Ninja Dog
Yeah I checked the jetting database. I only saw one person in the same elevation range as me. I will go over what he did as well when I am ready to start making adjustments on my carbs.
December 21st, 2010, 02:51 PM | #20 | |
Oldie but a goodie
Join Date: Nov 2010 Motorcycle(s): 08 Ninja 650r, 06 SV 650 race, 08 250r race, 03 Buell XB9s, 01 KTM 300 EXC Posts: 131
December 21st, 2010, 02:54 PM | #21 |
December 21st, 2010, 03:01 PM | #22 |
Oldie but a goodie
I have been riding it w/stock jetting (as I just found out) since I traded for it. I even tracked it and raced it at the end of the season like that.
Now it will be a race bike but it is a spec class that requires a stock airbox with snorkel in place. So I will be playing with the jetting but I doubt my numbers will do street bikes any good. |
December 22nd, 2010, 04:46 PM | #23 |
Along for the ride.....
That is approx. the altitude I start noticing a difference. The difference is significant at and above 5,000' ASL. I live at ~ 500, so I'm not tunning to high altitudes, but trips to Tahoe have given me these numbers (the pass is a bear at ~6,500' ASL). This was with a stock pipe & shimmed needles (at the time). I'm looking forward to the snow melting so I can try it with my Area P, re-jet, etc. I find it may actually help diagnosing tunning since it exaggerates everything at the same time... at least I think so.
Tuning factory carbs...yes or no? | not4sho | 2008 - 2012 Ninja 250R Tech Talk | 9 | February 5th, 2013 12:05 PM |
Tuning the carbs with FP jet kit; Is it possible I nailed it the first try? | rwheelz | 2008 - 2012 Ninja 250R Tech Talk | 26 | March 11th, 2011 07:47 PM |
What are your high altitude experiences? | headshrink | General Motorcycling Discussion | 5 | July 5th, 2010 05:07 PM |
high altitude power problems | alex.s | General Motorcycling Discussion | 6 | June 25th, 2010 01:23 PM |
At what Altitude | SteveL | Off-Topic | 23 | June 11th, 2009 02:45 PM |
