January 20th, 2011, 06:40 PM | #1 |
ladyrocket
Join Date: Dec 2010 Motorcycle(s): 09 Ninja 250R Posts: 84
Cutting the stock pipe
Hey guys,
I'm thinking about cutting the stock exhaust on my bike. I want it to be louder and sounds less like a sewing machine. Any thoughts, suggestions, comments? |
January 20th, 2011, 06:42 PM | #2 |
Join Date: Apr 2010 Motorcycle(s): Yahama v star 650 classic Posts: A lot.
I wouldn't cut it off. You could always take it off. The muffler will come off from the pipe, but if you want it louder why don't you just but a slip on exhaust?
January 20th, 2011, 07:43 PM | #3 |
Resident Old Guy
Megan,
Sent you a pm... |
January 20th, 2011, 08:34 PM | #4 |
I wouldn't recommend it. It is hideously loud :P, and won't help performance. But yes, you can easily just take off the muffler and leave the pipe in place to see.
Factory Pro Jet Kit, K&N R-0990 Pod Filter, Sportisi VR Black Exhaust, BRT TIS Ignition, White Paint, and 16/41 Sprockets. Soon: Maybe a 37T Rear Sprocket if I get things running like I'd hoped. |
January 20th, 2011, 11:22 PM | #5 |
ladyrocket
I dont really want to do a slip on for two reasons 1) expensive 2) having to rejet the carb, as I have read many posts saying its a must with an aftermarket pipe
To clarify I was looking at pulling the baffles out and putting in a perforated pipe packed with fiberglass and cutting the muffler to make it shorter |
January 21st, 2011, 06:15 AM | #6 |
IC2(SW)
It's easy to do. We cut the end off, installed a 1 1/2" baffle. Then welded it back together. Sounds real nice
Cost like 30 bucks in parts........ |
January 21st, 2011, 06:20 AM | #7 |
Oldie but a goodie
Join Date: Nov 2010 Motorcycle(s): 08 Ninja 650r, 06 SV 650 race, 08 250r race, 03 Buell XB9s, 01 KTM 300 EXC Posts: 131
You don't need to rejet for a slip on, they don't flow that much better, they just make more noise.
Obnoxiously loud exhausts are triggering repressive legislation across the nation and will eventually do away with all after market exhausts. |
January 21st, 2011, 07:08 AM | #8 |
original mufflers seem pretty cheap, i'd say get another pipe and then go to town on it. I'd warn though, chances of needing a rejet from a hacked stock can are probably just as high as from installing a slip on.
a chick hacking her pipe ... just somethin' sexy about that
January 21st, 2011, 07:40 AM | #9 | |
But yeah, what you are asking has been done and if you have the fabricating skills can be a simple, cheap way to upgrade the exhaust.
January 21st, 2011, 03:02 PM | #10 |
IC2(SW)
Should re-Jet even with the stock pipe Getting that stock baffle out, you loose some compression braking(wife hated that). You need to cut 1/8 to a 1/4" in, so the baffle will slide out. What a butt plug that thing is
January 21st, 2011, 03:08 PM | #11 |
IC2(SW)
Oh, dont forget to pull the so called "catalytic converter" out
January 21st, 2011, 05:12 PM | #12 |
Join Date: Apr 2010 Motorcycle(s): '10 250R(sold); '10 ER-6F Posts: 152
January 21st, 2011, 11:28 PM | #13 |
ladyrocket
thanks guys!
sounds like hacking up my original and buying a slip on is about the same (only difference is the $$$$), gunna bid on a LOR and if I get it for a good price I will just get that and if not looks like doctoring up the pipe! I will let you guys know how it goes! |
January 22nd, 2011, 01:48 AM | #14 |
why do you want the bike louder?
January 22nd, 2011, 05:32 AM | #15 |
self wrencher
January 22nd, 2011, 07:33 AM | #16 |
Just removing the intake snorkel gives the bike a nice growl. If you haven't done that yet, try it. It definitely reduces the sewing machine factor. I feel no need to mess with my exhaust.
Kevin 2009 Ninja 250R |
January 22nd, 2011, 07:54 AM | #17 |
Resident Old Guy
January 22nd, 2011, 02:31 PM | #18 |
IC2(SW)
January 22nd, 2011, 02:55 PM | #19 |
January 24th, 2011, 08:29 PM | #20 |
ladyrocket
Well I decided to go big and just do it all. I bought a LOR exhaust, factory pro stage 3 jet kit, and K&N Pod air filters. Im going to remove the air box so i dont have to deal with it if i have to readjust the carbs after re-jetting.
Next project, big boy tires! Hope I dont break a nail!! |
January 24th, 2011, 09:15 PM | #21 |
Haha niiiccce!!
January 24th, 2011, 09:26 PM | #22 |
Sweet! Make sure to read all the DIY threads here. Tons of good info!
Stock pipe of 2013 300 | LittleRedNinjette | Motorcycle-related | 0 | March 14th, 2014 05:10 PM |
Stock Pipe... | bigrodge8 | 2008 - 2012 Ninja 250R Tech Talk | 1 | April 18th, 2010 09:42 PM |
stock muffler and slip on pipe | james250ninja | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 24th, 2010 07:40 PM |
