March 6th, 2011, 08:22 AM | #1 |
BT45 vs BT45G
I recently ordered a set of BT45 and received the BT45-G instead. The sizes are the same but I was wondering if they're still good to go? Are they made of a different compound than the regular BT45? The Bridgestone website doesn't list the "G" but I've shot them an email asking.
March 6th, 2011, 08:26 AM | #2 |
It looks like those were the OEM tires on the GS500F for awhile (link). I'd check the date code on them to make sure they aren't several years old, but if they aren't, they're probably fine. The OEM tires may be a smidge different here or there, but I wouldn't stress over it; they should be just fine.
March 6th, 2011, 08:46 AM | #3 |
PAF3110 and PAA3410. So, sometime in 2010...
March 6th, 2011, 12:40 PM | #4 |
self wrencher
If you click each, you get a different description for the BT45G lines, they say:-
"BT45 Sports mileage The UK's best selling H and V-rated bias-ply tyres Silica Rich compound for fast warm-up and secure wet road grip SACT technology means that the harder centre tread delivers economical mileage while the softer tread shoulders aid cornering grip" whereas the non BT45G desc only says: "Bridgestone Battlax BT45 Sport Milage (Rear) 130/70 -17H" The 'G' probably refers to a tyre that is original equipment for a bike at some time. Usually the 'original equipment' tyres have a slightly lower spec that the aftermarket ones. |
March 10th, 2011, 08:09 AM | #5 |
Bridgestone reply:
"The tires are the same, some manufacturers request a "OE Code" when fitting a tire as original equipment. " |
March 10th, 2011, 10:23 AM | #6 |
ModMy250.com
John is right. The G only means that the tire is oem on some bikes. They're identical to the non-G tires. I googled this when I was looking up tires.
The www.ModMy250.com guy |
March 10th, 2011, 07:46 PM | #7 |
Join Date: May 2010 Motorcycle(s): Current: '11 ZX-6R; Previous: '09 Ninjette; '08 ZX-6R (Ex-Wife '09 TU250X) Posts: 981
Well, when I was trying to decipher this riddle, I ran into information that stated the "G" tire is for the Suzuki GS500 and the F model. The same information also stated that the tire was specifically made for the GS.
I would personally be wary, regardless of what the manufacturer said. I would probably request to have the aftermarket-spec tire personally. |
March 13th, 2012, 05:52 PM | #8 |
Join Date: Mar 2012 Motorcycle(s): 2010 Kawasaki Ninja 250r special edition Posts: 286
bt45 battlax rear 140/70/17h go own clean? no modding needed to instal?wondering if they may be too wide. any ansers please.
March 13th, 2012, 06:35 PM | #9 |
People have used that tire on the rear before. It should be just fine.
March 13th, 2012, 08:15 PM | #10 | |
Join Date: Dec 2011 Motorcycle(s): 2010 Ninja 250r (RIP) Posts: 258
March 13th, 2012, 08:33 PM | #11 |
One pleasant thing about the rear BT45 is that it's a "wide" tire. For instance, my 130 rear is actually 138mm wide. It appears wider.
I imagine the 140 width would also be a "wide" 140, making it closer to 150mm wide? I dunno, but your bike looks great. You liking how they handle? I really like the grip from mine, but not the wear on the front. |
March 13th, 2012, 08:51 PM | #12 | |
March 13th, 2012, 08:58 PM | #13 |
Yeah I've found that the rear wears normally, but the front has scalloped badly quickly with hard use. They stick like glue though, wet or dry. From that aspect, I've been quite happy.
March 13th, 2012, 09:34 PM | #14 |
I LOVE my BT45s!
Anything else looks silly on the pregen if you ask me. I like the "wide" tire. It makes it look less scooter-ee and more like a motorcycle. lol |
March 13th, 2012, 09:44 PM | #15 |
Jono, they do look great, but tires aren't a decorative object my problem with the front tire is annoying.
My next set will be Pirelli Diablo Scooter tires 100/80-16 front and 130/80-16 rear. I'm not so worried about the wide rear look at the moment. It's a 250. |
March 13th, 2012, 10:03 PM | #16 | |
It all depends on what you are doing with your vehicle. For me... I don't do track days and will now go easy in the twisties, that is if I ever get my bike on the road again. I just want a good tire for commuting/easy backroad riding and the BT45s are the perfect tool for the job. And they feel more planted. Oh and the 90 profile raise the seat height (a plus for me since I am 6'1''.) |
March 13th, 2012, 10:07 PM | #17 | |
Those hellaflush guys also aren't on motorcycles... |
bt45 140-70 H | eddiekay | 2008 - 2012 Ninja 250R Tech Talk | 2 | August 5th, 2013 02:33 PM |
New Tires - BT45 s or Kenda k671 s | JustRidin | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 11th, 2013 06:27 AM |
BT45 or Diablo rosso II? | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 80 | January 27th, 2013 11:08 PM |
Bridgestone BT45 for ninja 250r???? | NinjaBoyEddy | 2008 - 2012 Ninja 250R Tech Talk | 8 | March 14th, 2012 07:57 AM |
FREE: Rear Bridgestone BT45 | ShishkaBOMB | Motorcycle-related | 0 | April 29th, 2009 05:37 PM |
