March 7th, 2011, 02:41 PM | #1 |
self wrencher
wide band A/F Gauge
why so cheap now? Used to be $400 or so...now 1/2 price shipped.
http://www.aemonly.com/gauges-uego-7...FRJY2godc0jLBg So dyno run is about $100 or so already..might as well get this and mount it...tune as you go... |
March 7th, 2011, 03:38 PM | #2 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
Old stock. The new units are getting ready to come out.
Sportisimoto USA is born. |
March 7th, 2011, 03:59 PM | #3 |
self wrencher
^^new units prob has more bells & whistles to interface with the AEM EMS which we prob never need?
March 7th, 2011, 05:06 PM | #4 |
ModMy250.com
They've been that price for a long time now. Maybe if you're only looking at the aem website they're more expensive, but their retailers don't sell it for msrp. Innovate sells their kits for $240.
The www.ModMy250.com guy |
March 8th, 2011, 07:00 AM | #5 |
Are these weather proof?
March 9th, 2011, 11:39 AM | #6 |
Join Date: Feb 2011 Motorcycle(s): 2009 Ninja 250R Posts: 66
I have the Innovate Motorsports LM-2 kit (got it for about $275 on amazon) with the RPM inductive clamp (another $30). They list the same kit on their site for $350ish. Once you get the inductive clamp, you're still looking at almost $400 for everything you need to data log your AFR and tune correctly (I don't consider installing a new carb jet, doing a WOT pull, and using your butt-dyno to tune, correct tuning... that's more of a "baseline" if you will). The difference between older WB setups and the new ones have a lot to do with sample rates and more input options (e.g., rpm, temp, etc., etc.). I had the LM-1 years ago (which was great in it's day), but the LM-2 is by far a superior AFR tool.
March 9th, 2011, 12:10 PM | #7 | |
March 14th, 2011, 12:06 AM | #8 |
LM-2 Setup
As requested... O2 bung welded on the stock header: I took the header and provided o2 bung (standard length) to a muffler shop and had them weld it on. Had I of known it was going to be the worst weld job I've ever seen, I would have definitely taken it else where. But oh well, at least it is hidden behind the fairings. Header installed: The o2 sensor barely touches the motor. If you decide to use the stock header, which already has a spot for an o2 bung to be welded on (thanks to the European FI model), make sure to try and offset the bung from the middle of the flat spot. RPM inductive clamp hooked on the spark plug wire: For anyone looking into logging AFR/RPM, I recommend skipping the inductive clamp and getting the analog input instead (tap the tach. signal). I find that the inductive clamp readings jump around a lot and it looks like it has a hard time picking up a solid signal. Power setup: The LM-2 is powered by a 12V source and via a cigarette socket. I bought a battery to cigarette socket hardwire kit from Powerlet and ran it under the seat and up through the "storage" compartment. I keep the power disconnected when it's not connected to the LM-2 (otherwise it will drain the battery). LM-2 hooked up and reading AFR/RPM: And the final product... all hooked up and logging the AFR (2GB memory card) Fairings back on and wiring tucked away. I keep the wideband unit in the bag when driving around so it can continuously datalog. After I get the carbs dialed in I remove all LM-2 and the o2 sensor (kit comes with a bolt to plug the bung) and tuck the power wiring away. Anyway, hope this helps. I opted not to get a permanent setup because I want to be able to easily transfer the wideband setup to another bike when the time comes to tune something else. Last futzed with by kogary; March 14th, 2011 at 12:09 AM. Reason: adding more pictures |
March 14th, 2011, 04:47 AM | #9 |
March 14th, 2011, 06:57 AM | #10 |
Nice writeup!
On the O2 sensor bung there's no reason why one can't grind a small bevel on the base before welding it in place. This would angle the sensor away from the motor a bit and not interfere with function in any way. |
March 14th, 2011, 09:23 AM | #11 | |
To RandomWalk101, if you're seriously looking at getting a WB setup, I would highly recommend getting a removable unit. It's so handy being able to do your tuning, then put everything away and not have to worry about the hardware. Last thing you want is to leave your bike unattended (driveway, store, local hangout, etc.) and 5 minutes later find your AEM gauge gone. Trust me, I've seen entire A-Pillar gauge pods yanked from cars with nothing more than a window slightly rolled down.... on a bike, it's like taking candy from a baby. |
March 14th, 2011, 09:54 AM | #12 |
Oldie but a goodie
Join Date: Nov 2010 Motorcycle(s): 08 Ninja 650r, 06 SV 650 race, 08 250r race, 03 Buell XB9s, 01 KTM 300 EXC Posts: 131
Hey Gary, looks like you got those tires swapped out huh?
We had a great day @ IMI Saturday, but I was the only Ninjette out there. And I pretty much finished off my front, now I need another |
March 14th, 2011, 10:54 AM | #13 | |
self wrencher
but A/F is just for tuning..after it's tune, ideally it should be removed cuz that wideband oxygen sensor will burn out. |
March 14th, 2011, 12:05 PM | #14 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
This is awesome info, thanks guys!
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
March 15th, 2011, 09:16 AM | #15 | ||
Yeah I got those BT-003RS tires mounted on Friday. So far I like them. They have a much different sensation when steering into a turn than the stockers did. These just really pull the bike through a turn, whereas the stockers felt like the bike glided through the turn. I put about 40 miles on them yesterday trying to scrub them before I hit IMI this coming Saturday (03/19/2011). Quote:
March 15th, 2011, 02:55 PM | #16 |
self wrencher
kogary,
what is your current A/F ratio reading and what is your current jet setting? Thx. |
March 15th, 2011, 08:16 PM | #17 | |
* Just a note: This troubleshooting stuff is the EXACT reason why I bought this setup. Can you imagine trying to accurately (well as accurate as you can get with a carb) do this by feel alone?!?!?! And at 13,000 RPM, small amounts of detonation equal catastrophic damage to your motor... Since I live in Denver, CO (~5280 feet ASL), I'm running rather rich under WOT. I'm going to do some more WOT data logs next week and will probably order some jets from www.JetsRUs.com in the near future. After I get it all dialed in, I'll do a few dyno pulls to see what it's putting down. ** I just realized I went off on a huge tangent to answer two simple questions. Sorry about that!! -Gary |
March 15th, 2011, 08:22 PM | #18 | |
Oldie but a goodie
I would rather scrub tires on the track it only takes a couple of easy laps to get it done. I went ahead and put the 98 jets in since my A/F was a bit lean on the dyno but I am going back to the 95's this week, she likes to run a bit lean up top. Doing the ride posted on CSC tomorrow on my Buell, we are meeting at the Morrison Conoco @ 11:00. |
March 16th, 2011, 05:10 AM | #19 | |
March 16th, 2011, 06:13 AM | #20 |
self wrencher
Thanks Gary. Looks like I'll get the AEM UEGO to play with after I get my custom faceplate for the Koso rx2. That bezel has a 52mm hole to mount the gauge. I have a mig welder & drilling tools to mount that oxygen bung.
Your WOT a/f is a tad rich...I would try to remove a washer and have it around 13. They recommended 12.8:1 -13.2:1 for NA engine. |
March 16th, 2011, 06:44 AM | #21 | |
Do you have the dyno plot printed out from your last session? I'm curious what your AFR looked like from 5k-redline. -Gary |
March 16th, 2011, 06:55 AM | #22 | |
Nice choice on the AEM. Those are great units. Make sure to post some pics of the Koso install! That gauge cluster looks awesome! I'm sure you're going to have one slick looking cluster with the Koso and AEM right next to each other -Gary Last futzed with by kogary; March 16th, 2011 at 06:57 AM. Reason: grammar |
March 16th, 2011, 07:43 AM | #23 |
Somewhat of a newbie question set:
Best place to weld an O2 sensor bung is immediately downstream of the Y-pipe joint (i've got an AreaP full system)? And thus a no-weld bung is a silly idea for us?
March 16th, 2011, 08:49 AM | #24 |
Join Date: Dec 2009 Motorcycle(s): 2009 Ninja 250R Black - Sold / 2011 Honda CB1000R Posts: 176
I've had alot of experience tuning using these gauges and on this bike, thought I'd give my 2 cents.
If you did get the AEM UEGO do no mount it permanently to the bike, it is not in the least bit water tight. Ask me how I know I used the AEM UEGO to tune my bike when I got my HMF slip on. I used (2) washers on the needles & everything else stock. The end result was absolutely perfect match with the HMF. My AFR's were stuck between 12.5-13.2 on WOT. Cruising and partial throttle are around 13.5-14.8 depending on RPM. Around 11k the bike would lean out a tad & reach 12.9-13.0 range which is still suitable and no detonation can be heard from the engine. Thus, my bike continues to pull from 11k to 13k. Over the years I've discovered the real need for a AFR and EGT devices because a leaner engine will actually make more power and "feel" better when it really isn't. This is why you never ever street tune and rely on your "butt dyno" Also, to add the AEM UEGO has no way of data logging unless you are running it in conjunction with a stand alone ECM ie.> AEM EMS, PCS, Hondata, Chrome, yadda yadda. So seeing as we don't have stand alone fuel injected car ecm's you cannot data log with it. I sold my AEM after tuning for this very reason. I mounted my for a few weeks and watched it like a hawk. It did rain on me once and water did get into the gauge face, not enough to ruin it but if I wasn't closer to home I'm sure it would have! I would pick up one of the new innovative units that uses a gauge/data log unit you can hook your lap top up to! However, the AEM works just as well!
2009 Black 250R - Stock and staying that way. No matter what you do it's still a 250 at the end of the day! Save your money for gear, riding lessons, & a 600cc |
March 16th, 2011, 09:35 AM | #25 |
MOTM - Oct '15
Quick question for you Gurus.... What's the "perfect" A/F ratio? I've heard number like 14.7 - anything lower and you're in the "lean" side of things, anything higher and you're on the rich side of things.... Is this old-school thought for old cast-iron V8 blocks and heads? What should be the goal?
Also a note for Gary and Bueller, although you guys probably already know, for the RMA 250cup, the guy who dyno'd the demo fleet said he got some really good results with the 94-96 (95) sized main jets... An innovate setup is so next on my list of things to get for the bike...
March 16th, 2011, 11:02 AM | #26 | |
self wrencher
March 16th, 2011, 11:15 AM | #27 |
Yes, as close to the Y-pipe intersection as possible, while still maintaining at least 12 inches away from any exhaust port (too close will overheat/burn out a sensor).
March 17th, 2011, 11:08 AM | #28 | |
14.7:1 is the ratio to achieve a stoichiometric burn. However, this is not the target ratio for maximum power (just an optimal burn). 14:7:1 is great for cruising down the highway or coasting along down a small decline, when there is very little load on the motor. But under WOT, you have a huge load on the motor. Temperature (and subsequently cylinder pressure) increases and can cause detonation. Adding more fuel (running rich) effectively lowers cylinder temperature creating a “cooler” and “longer” burn… this in turn creates more power per combustion stroke. For those who are wondering why this is, see below for more detailed explanation. Else, shoot for a 12.8:1 - 13.4:1 ratio. *Note: 13.4:1 should generally be targeted when using higher octane (e.g., 91, 93, etc.) due to the high RPM and high static compression ratio nature of our motors (higher RPM increases probability of catastrophic damage due to detonation). On to the detailed explanation of the “magic” AFR target number… When you go WOT, you start putting a large load on the motor. This load causes your cylinder temperatures to increase substantially. During this process, cylinder pressure starts increasing due to temperature increase and change in cylinder volume... remember your chemistry equations PV = nRT? So this means that Pressure = (n*R*Temp)/(Volume). So as volume decreases (on your compression stroke), pressure increases. Quickly compressing a gas causes temperature to increase too. So you've got two big things going on in your cylinder... - Increased cylinder pressure - Increased temperatures So what does this have to do with your AFR??? A lot actually... Energy: As molecules heat up, they gain energy... as they gain energy, electrons are more able to "freely" move around. This moving of electrons is what combustion is all about. So the higher the temperature, the more these electrons are prone to move around before you are ready for them to do so (aka- pre-ignition... aka- detonation). Now imagine packing more fuel molecules into the same given system as above (lowering your AFR... aka- running rich). Now you have a lot more of these molecules bumping around and hitting each other. As you know, you have to apply energy to get things to move, right? Well the more things you have in your cylinder (fuel molecules) the more energy you have to apply to make them move around (we feel this increase in energy in the form of heat!). So by adding more molecules (aka- running rich), you are decreasing the ability of the system to achieve a higher energy level (i.e., you're cylinder temperature is now lower!). So now that you’re cylinder temperature is lower (subsequently lowering cylinder pressure), your less prone to detonation (a very good thing!) Timing is key: But wait! Now you’re thinking, “Don’t we want more energy?!?! If we’re decreasing cylinder temperatures, and the energy of the system is lower, doesn’t that mean we won’t make as much power?” The answer is yes, and no. Yes, we do want more energy, but timing the delivery of energy is key! We want the energy from our combustion to be applied at a very specific time… if we apply it too early (detonation) you risk applying force to the rotating assembly (pistons, rods, crank, bearings, etc.) while it’s still in an early stage of the compression stroke. By the time the combustion finishes burning (happens in milliseconds!), your piston still may not have even reached top dead center, or if it has, cylinder pressures/temps are so high and HOT that you start breaking metal components (e.g., cracking pistons, burning valves, bending connecting rods, etc.)! By running more fuel (aka- running rich), you are helping to control cylinder temperature and pressure, thus controling air/fuel mixture combustion timing. Additionally, by having those extra fuel molecules floating around you create a longer burn. Any unspent fuel still in the combustion chamber after your primary combustion still has the ability to burn. Now since we don’t live in a perfect world, not every air molecule actually bonded and combusted with a fuel molecule. This means that we still have free air and fuel molecules floating around after the primary combustion that can actually have a post burn effect. This post burn effect usually happens on the down stroke of the combustion stroke and still creates a force on the piston! So while it doesn’t create nearly as much force as the primary combustion, it still has a positive effect. Now some may be thinking, “If adding more fuel suddenly makes more power than a stoichiometric mixture, why not just dump TONS of fuel into the mixture… like a 1:1 ratio?” Well unfortunately we do have to find a balance. There comes a point when too much fuel actually has a negative effect and prevents cylinder pressure/temperatures from achieving optimal conditions for maximum power delivery. Additionally, you can run into a reverse effect of creating a system that has so much fuel in the AFR and your exhaust gas temperatures start getting hotter than even an optimal burn temperature. Weird, huhh?!?! But this again has to do with post burn. If you ever get a chance to watch someone with an EGT gauge (exhaust gas temperature) play around with their AFR, you can see the EGT’s go down as you go from 15:1 to 14:1 to 13:1 to 12:1 to 11:1, but once you start getting down to the 9:1 ratio you can actually start seeing temps start rising again. So once again we have to find the correct balance. Lucky for us, people have spent the past 80 years or so, studying optimum AFR’s for particular engine loads. As a general consensus, our magic range just so happens to be the 12:8:1 - 13:4:1 range. So there you have it: AFRs explained! Recap: 1) High AFR under high load (e.g. WOT) = increased cylinder pressure/temperature 2) Increased cylinder pressure/temperature = increased probability of detonation 3) Decreasing AFR (running rich) = decreased cylinder pressure/temperatures (optimizing your ability to control the burn without detonation) 4) Optimized burn for specific engine load (e.g., WOT) = maximum power delivery for a given load Last futzed with by kogary; March 17th, 2011 at 11:09 AM. Reason: accidently hit "quote" twice |
March 17th, 2011, 02:30 PM | #29 |
MOTM - Oct '15
Awesome info, thanks Gary!
March 18th, 2011, 04:38 AM | #30 |
self wrencher
Kogary,
Is your LM-2 weatherproof? Also, generally, these needs to be around 600 or so to operate properly. Which means it sucks juice from your bike a lot. Does it drain battery much as you can see Gary? Last futzed with by randomwalk101; March 18th, 2011 at 06:11 AM. |
March 18th, 2011, 07:34 AM | #31 | |
The sensor is a heated sensor and usually is completely heated within 20 seconds (you let it heat before turning the bike on). The LM-2 is designed to work off a 12V system, with motorcycle charging systemsb kept in mind. I have noticed no ill effect on the battery while using this setup. I notice a slight voltage drop when I put my high beam on, but nothing with the LM-2, lol. |
March 22nd, 2011, 11:44 AM | #32 |
self wrencher
Cool. Ordered the AEM wide band...should be here Thursday. Still waiting on my faceplate from Indo though...I'm guessing another 2 weeks?
Anyhow, the AEM is not waterproof so I will use clear silicon at the gaps/bezel to hopefully seal it. |
March 29th, 2011, 09:25 AM | #33 |
self wrencher
Apparently I was wrong. The o2 sensor doesn't obstruct exhaust flow much if welded as such..I'll pull out my mig welder and will try to weld the bung in...hopefully I won't run my exhaust
Hooked up a wide band o2 on the 250 | cuong-nutz | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 29th, 2014 08:18 PM |
